chris edwards
Hi all, can anyone please advise how to best derestrict a Shimano EP8 motor ? Bike Thok TK01R .
Check out STunlocker.........Hi all, can anyone please advise how to best derestrict a Shimano EP8 motor ? Bike Thok TK01R .
I’m not having any luck finding the info on their site….do you know if STunlocker can adjust the torque settings as well? I’ve got an Orbea Rise w/ the EP8 RS….I’m wondering if the STunlocker can essentially turn it into the full power EP8 motorCheck out STunlocker.........
A number of users have discovered that if you use the Shimano Etube app to upgrade using bluetooth then you get the full power ep8 software. The app is apparently unable to distinguish between and EP8 RS and an Ep8 motor. This assumes you are not or do not wish to derestrict as updating to the latest firmware would not be for you.I’m not having any luck finding the info on their site….do you know if STunlocker can adjust the torque settings as well? I’ve got an Orbea Rise w/ the EP8 RS….I’m wondering if the STunlocker can essentially turn it into the full power EP8 motor
No won’t connect at all…weirdWon't connect at all? On the E8000 with the latest firmware it will connect but won't adjust the settings for wheel circumference or country.
You need to install an earlier firmware.
Yeah Bluetooth on….thanks for the pointer on operating power mode switch…I’ll try that!It should still connect but not allow you to make changes with the latest firmware. Is Bluetooth on your phone turned on and working. Also suggest you try operating the switch that selects power mode on the bike while trying to connect.
Yeah did that several timesAs above, open the app (with the bike turned off) and tap "connect" then turn on the bike
YesWill the bike connect to the Shimano E-tube app ?
