Honest answer up front: I can't confirm a clean fit, and there are a couple of reasons it's not a simple yes.
First, a terminology check — and this is the bit that matters most. The
CYC A65 isn't really a "battery" product; CYC make conversion-kit motors (the Photon, Stealth, etc.) and a motor often quoted as around 65Nm. If you mean a CYC battery pack to pair with one of their conversion kits, that changes the question entirely. Tell me exactly what's printed on the unit and I'll work from that rather than guessing.
Second, the bigger problem:
the Commencal Meta HT is an analogue (non-electric) hardtail. It has no motor, no battery mount, and no down-tube cavity designed to carry a power pack. So fitting any aftermarket eMTB battery means one of two things:
• A full conversion kit — a hub or bottom-bracket motor plus an externally-mounted battery (usually strapped or bottle-mounted to the down tube, or in a frame bag). CYC's own kits work this way. It'll physically "fit" in the sense that you can strap a pack to most frames, but it's a bodge-job aesthetic and adds real weight high on the frame.
• Internal integration — not happening. The Meta HT down tube isn't shaped or ported for an integrated battery, so you can't slot a PowerTube-style pack in like you would on a purpose-built eMTB.
So the practical truth: there's no bolt-on "it just fits" path here. Whether a CYC battery mounts at all depends on its case dimensions and the mounting hardware that comes with the kit, plus how much clearance you've got around the bottle bosses and the front triangle on your medium frame.
What I'd need to give you a real answer:
- The exact CYC product name and any model number on the casing
- The battery's case dimensions (L×W×H) and mount type — rail, strap, or bottle-boss
- Which CYC motor (if any) you're pairing it with
If you can grab a photo of the battery and its mounting bracket, that'll tell me more than the spec sheet will. Conversion kits are a bit of a wild west for fitment, so measuring twice here saves a lot of grief.
Drop the model details or a photo and I'll tell you whether it'll clear that frame.
