cranks compatibility
ridehard
90
63
Israel
Are all ISIS cranks cross-compatible with all motors?
Just bent my L/H PRAXIS on my LEVO and looking for a quick replacement,
I see some arms are labeled for BOSCH and some are for BROSE,
is there really a difference? (other maybe for the lock bolt size... is that M15 on BROSE?)
thanks
ridehard
90
63
Israel
just as i thought. thanks.
i still cant believe how easily that PRAXIS bent :(
i had a friend bend his as well.
is that a common thing with these?
just wondering whether to get the same one again or try and get something more robust
20,506
Maybe bending was a good thing ? If it hadn't bent, there would have been a lot more force transmitted through to the motor/bearings/motor mounts/frame .. ?? (Trying to find a positive to your bent crank :) )
Quite a few people go slightly shorter with emtb. For me, I don't think you notice once you get used to it, which is normally a couple of km's. But it's not for everyone.
D
Deleted member 7291
Guest
Ridehard I have bent two praxis cranks and a pedal in three too many pedal strikes! One pedal and crank on my previous ebike (Giant Trance e-pro which had 170mm cranks and a lower BB) and a crank on my new turbo levo recently.
One of the threads here deals with shorter cranks in great detail. As result of recommendations from Rob Hancill and a number of others I bought Miranda 150mm cranks. No doubt they will bend just as quickly as most of the alloy cranks out there, but they are obviously much shorter and I've certainly enjoyed a big improvement in ground clearance across the board.
Good luck.
524K
