Unanswered Centrelock rotors
hainman
72
41
Glasgow
So I’ve been using the Magura storm CL rotors but bent the rear and wondered if there was anything else in 2mm thickness that I could run
Or safe to run centrelock to 6 bolt adapters
Also is the TRP 2.3mm rotor too thick for the Magura calipers
VWsurfbum
🤴King of Bling🌠
Jan 11, 2021
1,376
2,043
England
the 0.3 of an mm won't make a difference.
Personally, I don't like centre lock or the adapters, find you get too much movement?
Can you not get actual centre-lock discs to do away with the adapters?
VWsurfbum
🤴King of Bling🌠
Jan 11, 2021
1,376
2,043
England
Yes they are fine but you do get additional movement that most people wouldn't notice. (I do as I'm a bit like that, I don't like Shimano brakes either for their pad movement)
hainman
72
41
Glasgow
I had Shimano XT but swapped them
Out for Magura MT5 Fabio wibmer ed with single finger levers
Great when they work
Bastard when they don’t,They hold air really badly
Jaspy
113
108
Bea Sea Canada
Old post but… pic says it all so depending on what size your rotors are (I would guess 203) you maybe outta luck for the back max size is 160mm.
I do have these new if interested let me know.cheers 😎
524K
