Can I install a Bosch gen 4 625 Wah battery into a Bosch gen 4 500 Wah bike?
Sidepod
584
395
Oxford
I'm sure there are others with more knowledge of these things but I guess the theory is ok given the voltages are the same. There could be some internal BMS software issues I guess. If the connectors match then go for it. Only one way to find out.
Doomanic
🛠️Wrecker🛠️
8,479
9,958
Is your bike available with the 625 battery or only the 500? If it's the latter then it's pretty unlikely as the 625 is longer than the 500.
bluewater87
135
55
Canada
The 625 is longer than the 500. The 500 uses a spacer block (not sure the name of it) to fill the void.
bluewater87
135
55
Canada
Not sure if it bike specific or not, but I know the trek rail for example fits a 625 or a 500 with the spacer. So in this example, yes if you buy a 625 it would fit.
whatbike do you have?
Tubby G
❤️‍🔥 Hot Stuff ❤️‍🔥
Dec 15, 2020
2,594
5,196
North Yorkshire
When I ordered my bike they could only order the 500Wh battery version but I wanted the 625 so I paid the extra and the LBS fitted the 625 battery when the bike arrived by removing the 500 spacer block, so yes it can be done
Doomanic
🛠️Wrecker🛠️
8,479
9,958
On your bike, yes. We don't actually know what the OP rides.
Doomanic
🛠️Wrecker🛠️
8,479
9,958
In that case I have no idea other than to ask if your 500Wh battery has a spacer fitted, sorry.
Blakey
90
82
Mid Sussex, UK
Interesting! I'm on a Canondale Moterra 2020 with 500Wh (see sig for full details). I'd love to know the same question for my bike?
Doomanic
🛠️Wrecker🛠️
8,479
9,958
Probably...
Does your 500Wh battery have some sort of spacer to make it fit the aperture properly?
Feb 5, 2019
163
28
Wales
I haven’t got the bike yet. But if I can’t fit the 625 in it, I probably won’t bother.
The Hard Seven 9 comes with 625 battery.
Blakey
90
82
Mid Sussex, UK
I believe the 2021 model of my bike has the 625 battery and I know the shop I bought it from told me the 625 would fit, but that was before I found out the 625 was bigger. Maybe there is a spacer inside the tube. Interesting! I'm going to go and ask again...
Jimbo Vills
805
1,429
Kent
There is mate, as @bluewater87 says and shows in the pic above ??
Blakey
90
82
Mid Sussex, UK
I just went and looked at the bike and, yes, there is definitely space to put a bigger battery in the tube. It's got a spacer which is bolted into the frame. The spacer seems to have all the wires and contacts running through it, so not just a lump of plastic. Possibly something I would ask the LBS to do rather than doing myself though I think...
Worth knowing!
Planckus
69
59
Denmark
As stated earlier: On my Cube Stereo Hybrid, I can move the bracket inside the tube to the 645 watt battery position:) or the other Way around.
DMS2610
24
19
Lichfield UK
I can confirm this for the Trek Rail since I have done it and if you remove you 500 battery you will se whether there is a spacer at one end, its obvious if you are looking for it
kbass24emtp
41
21
St. Louis
Yes you can. You will have to move the upper battery mount up. Here is a link to the owners manual. You just have to remove the battery rail and move the upper mount to the upper holes. https://www.cannondale.com/-/media/.../019_137373_oms my20 habit neo moterra_en.pdf. I have the 625 in my Moterra and all the Moterra share the same battery rail. There is just different mounting holes for the upper mount.
