Buying a Shimano EP8 motor from AliExpress for a Santa Cruz Bullit — anyone tried it?
Worth a quick reality check before you click "buy" — and one that matters specifically because your Bullit doesn't run a Shimano motor.
The Bullit is a Bosch bike. The 2025/2026/2027 Bullit runs the Bosch Performance Line CX Gen 5 (120Nm, 750W claimed peak on current firmware), with a 600Wh internal PowerTube. So if this is for your own bike, an EP8 from AliExpress won't drop in — wrong mounts, wrong battery interface, wrong wiring entirely. If it's a project build or a mate's Shimano bike, read on.
The big AliExpress trap — DU-EP800 vs DU-EP801. @Backflip flagged this clearly: the older DU-EP800 and the late-2022 DU-EP801 are completely different units — mechanically, electronically, firmware and software — despite both wearing the "EP8" badge. Plenty of AliExpress listings just say "EP8" and ship you the old DU-EP800. If your frame/battery expects an EP801, that's a problem.
Two specific gotchas Backflip raised:
• You can't simply swap a DU-E8000 bike to an EP801 — the EP801 needs a Gen 2 battery that often won't physically fit older frames.
• New units ship with wheel circumference maxed at 3000mm, which throttles you to roughly 20km/h until you reconfigure it.
Destination/region settings. These are software, not a hardware "restriction chip" (despite the rumours). @Backflip confirmed country destination settings can be changed with eMax-Tuning software — which is also the tool the Orbea Rise crowd reach for when servicing or tuning. So a grey-import motor isn't necessarily bricked, but you'll want that software and the patience to configure it.
Price sanity check. AliExpress isn't the only route. @Astro66 paid ~£600 (AUD$1200) for an EP801 replacement at retail in Australia. Factor in the AliExpress risk — no warranty, possible counterfeit internals, the EP800/801 mix-up, customs — and the saving often isn't as big as the listing suggests once it goes wrong.
And worth remembering EP801 reliability isn't bulletproof even from official channels — @Winford went through 3 motors in 14 months. Buying grey-import only removes your recourse when one fails.
If this is for a second bike or a build, tell me which frame and which EP8 variant the listing claims — I'll help you check it'll actually fit before you commit.
That´s correct, however, there are earlier Santa Cruz Bullit´s which were equipped with Shimano STePS drive units.
See e.g. here in the Santa Cruz archive.
The Bullit 3 MY22 was equipped with the DU-EP800 from Shimano.
The Bullit 3 MY23 was equipped with the DU-EP800 from Shimano.
The Bullit 3 MY24 was equipped with the DU-EP801 from Shimano.
I'm on a Santa Cruz Bullit.
Has anyone bought a Shimano EP8 motor from AliExpress?
Ideally please don´t use the wording "EP8" and exactly specify the model year of your Santa Cruz Bullit bike to avoid any misunderstandings and confusion.
Unfortunately Shimano has branded the newer DU-EP801 (released end of 2022) and the older DU-EP800 (released in 2020) on the right side motor cover with the same “EP8” signature.
However, the older DU-EP800 and the newer DU-EP801 are completely different types of drive units in mechanical, electronical, firmware and software aspects.
To visually distinguish these two motor types, you can have a look at this German forum post or also this or this one.
Also ideally please give some more information and details regarding your question to make it easier for anyone else who might be able to help you to understand your intention.
So, I assume you want to get a new (replacement) drive unit for your bike (because maybe your current drive unit is broken or you want a spare unit)?
There are a lot of (online-) shops who are selling (brand-new) Shimano STePS drive units (see e.g. here for a DU-EP800 and here for a DU-EP801) and for sure you also can buy from Asian sellers (like AliExpress).
Most Asian shops deliver good (brand-new) quality drive units, we only have heard from very few complaints due to broken packages, damaged drive unit housings and also additonal high taxes. However, most sellers will deliver perfect products. Just check the ratings of the shops.
Also it is very important to know that any brand-new Shimano STePS drive unit will be delivered in the initial factory production state and so e.g. has a programmed max. wheel circumference value of 3000mm which will result that a bike with a real rear wheel circumference of around 2200mm (which is typical for a 27,5" rear wheel) with this drive unit only will give you a max. motor support speed of approx. 20km/h (and the bike display already will indicate 25km/h at this speed).
For programming the correct configuration of such a brand new drive unit you should contact the guys from eMax-Tuning via email, because they have all the tools and knowledge to configure such a new drive unit correctly. :)
    677K
