Haha no I don't but I do like the idea of duel crown. Looks like the steering should be super direct.Do you weight 200+ and send 20ft drops?
If not then single crown is best.
Sooo good for down hill.Double crown forks are good for downhill only. Period.
Considering the weight of an e-bike, not a bad optionDouble crown forks are good for downhill only. Period.
Hiya OrangieDouble crown forks are good for downhill only. Period.
Rubbish Ive been riding them for yearsDouble crown forks are good for downhill only. Period.
Cheers. Thanks for the advice. I will talk to Jonno at suspension lab and see what he recommends but so far it's doing the job pretty dam well so I am pretty excited to think it can be dramatically improved. I have a mate who i ride with regularly just fitted a boxxer ultimate to his levo so it will be interesting to feel the difference when we swap bikes one day in the futureWait until your Select damper starts acting up then get a custom one. It will blow your mind how much better it can be.
I would not get a charger 2.1 or whatever best damper they offer. For the same price you can get something tuned to you.
As the owner of a Kenevo Expert( comes with the Boxxer in the USA) I think I might have some input. I took the bike out for 10 rides and realized the really bad increase in the turning radius with a duel crown fork was an issue on the trails. I did 2 things, I bought a rockshox Domain 29er 180mm fork and I picked up a 200mm air shaft for the Boxxer. Now I have a full size Boxxer for the bike park and a very stiff single crown 180mm fork for trail riding. Is the Boxxer stiffer than the Domain? Yup. Which do I prefer to ride? The Domain, I think the thicker 6061 alloy fork legs add a degree of damping In the chatter just like high end handle bars ride better than super stiff stock bars. JMO.Just thought I would update. Boxxer is a revelation. So direct and so much control. Almost like having a get out of jail free card. Highly recommended. No idea what the knockers are on about. Imo superior in everyday although did take a bit to get them set up the way I like. Select damper works fine but it is critical to get the volume spaces correct. I am running 3. Quite easy to have too much rebound also but once sorted it's magic
