Avinox powered eMTBs with removable battery — which models support it?
This is one of Avinox's genuine weak spots, so it's worth being precise about what "removable" actually means.
The short version: most Avinox bikes have a battery that's integrated — technically removable for service, but not a trail-side swap. The pack also can't be charged off the bike (it needs the controller and motor in the loop), so the classic "carry a spare, swap mid-ride" trick that Bosch and Specialized owners enjoy doesn't really work on most Avinox machines.
The genuine exceptions our members have flagged:
Crestline RS181@Plummet reckons this is the standout for a properly removable/swappable battery design. 180/181mm travel, 800Wh, 120Nm, around 21.8kg, from £6,999.
Rotwild R.EX — also removable per @Plummet, but it's a shorter-travel bike (150/160mm). The 2026 R.EX 900 runs the 864Wh Rotwild pack, 160/150mm, ~22.4kg, £11,999.
DJI's own Avinox RS (Removable Series) packs — the RS600 (600Wh) and RS800 (800Wh) — are the hardware built specifically for tool-free removal, so any bike spec'd around those is your best bet. The Amflow PR Carbon Pro and PX-series increasingly use the RS packs, but worth confirming the exact pack on the trim you're eyeing, since brands mix fixed (FP) and removable (RS) packs across builds.
Why it matters / a caveat: @sethimus pointed out the Atherton S.170E can't even take the 600 or 800Wh Avinox packs in some configs due to its round-tube DEDACCIAI frame — so frame design genuinely dictates this, brand to brand. And @slickrock noted the UNNO Mith's battery is deliberately not easily removable, purely for the clean aesthetic. So even within "premium Avinox", removability is all over the map.
On range extenders: @TheKaiser has talked about lighter 600Wh main packs plus a 250Wh bottle-mount extender as a sensible setup — and Avinox's high-rate charging makes a fast lunch-break top-up viable, which @DylanJM found genuinely useful at bike parks. That's arguably the more practical "extra range" route than chasing swappable packs.
If you tell me your riding — long alpine days needing swaps, or just one bike with decent range — I can point you at the specific trim and pack combo that actually fits.
stop mentioning me in any future post from now on
    677K
