Popeye_rides_again
- Feb 22, 2026
- 7
- 0
@Greg Watts Hi Greg, please compile a list of known and rumoured emtbs that will use the avinox drivetrain (m1 or M2) and have full alloy frames. Similar to the Atherton s170e.
Welcome to the forum, @Popeye_rides_again. Good timing on this question, actually, because the alloy + Avinox space is more interesting than it was even a few months ago.@Greg Watts Hi Greg, please compile a list of known and rumoured emtbs that will use the avinox drivetrain (m1 or M2) and have full alloy frames. Similar to the Atherton s170e.
| Bike | Travel (F/R) | Battery | Weight | Price | Status |
| Atherton S.170E (various builds) | 170/170mm | 800Wh | 22.5 - 23.5kg | £6,999 - £8,999 | Pre-order, June - July 2026 delivery |
| Commencal Meta Power SX DJI | 160/160mm | 800Wh | 22.4kg | £7,995 | Pre-order, delivery July 2026 |
| Orange Phase Evo DJI | 160/155mm | 800Wh | 19.5kg | £7,500 | Confirmed, Halifax-built alloy |
| Megamo Reason AL / Reason AL Air | 160/160mm or 140/140mm | 800Wh / 600Wh | TBC | From ~€4,999 | Confirmed, Europe only |
Thanks @Greg Watts, is that Atherton battery spec confirmed?Welcome to the forum, @Popeye_rides_again. Good timing on this question, actually, because the alloy + Avinox space is more interesting than it was even a few months ago.
Here's what's confirmed or credibly rumoured for alloy-framed Avinox eMTBs:
Bike Travel (F/R) Battery Weight Price Status Atherton S.170E (various builds) 170/170mm 800Wh 22.5 - 23.5kg £6,999 - £8,999 Pre-order, June - July 2026 delivery Commencal Meta Power SX DJI 160/160mm 800Wh 22.4kg £7,995 Pre-order, delivery July 2026 Orange Phase Evo DJI 160/155mm 800Wh 19.5kg £7,500 Confirmed, Halifax-built alloy Megamo Reason AL / Reason AL Air 160/160mm or 140/140mm 800Wh / 600Wh TBC From ~€4,999 Confirmed, Europe only
The standouts deserve a bit more explanation. The Atherton S.170E's centrepiece alongside the Avinox M1 is its frame made of 7075 aluminium
- specifically, Orange's full suspension frames are handcrafted in their Halifax factory, starting life as a sheet of aerospace-grade aluminium, making the Phase Evo a genuinely compelling British option.
Megamo also offer an alloy-framed version called the Reason AL and Reason AL Air, lopping around €1,000 off the carbon pricetag, with the cheapest Reason AL 07 coming in at just €4,999
- though those are Europe-only for now. The Commencal Meta Power SX is a 160mm enduro eBike with an alloy frame, 800Wh battery and MX mixed-size wheels.
It's arguably the most mainstream of the bunch given Commencal's distribution network. On the rumoured side, there are strong whispers of more brands following suit, particularly as
Sea Otter 2026 kicks off on April 16th at Laguna Seca, and it's likely to bring wall-to-wall Avinox announcements.
Worth keeping an eye on that. There are also strong rumours of a significantly more powerful Avinox variant coming very soon, which may influence which frame materials new bikes are specced with - but I can't share specifics until it's official.
I've also got data on the Steppenwolf Tundra Alloy at £5,199 if budget is a factor, though that's a 2025 model so availability may vary.
Yes, the 800Wh battery is confirmed across all three builds in our database. That's consistent across the board regardless of which build level you go for.Thanks @Greg Watts, is that Atherton battery spec confirmed?
Good shout, @Petrex. Confirmed - the Crussis ONE-Full/e-Full 11.11 is very much real and absolutely belongs on this list. The 11.11 runs an aluminium frame with the DJI Avinox M1 motor, with 150mm rear travel and 160mm up front.@Greg Watts Crussis ONE-Full/e-Full 11.11 out soonish. €4790
Cheers @Petrex, the EDIT on my previous post has been updated to reflect the corrected pricing. Much appreciated.@Greg Watts €4790 is the 800Wh Crussis 11.11 list price €4490 for 600Wh version![]()
@Greg Watts, I can't see that 800Wh has been confirmed anywhere, more like a rumour or an assumptionYes, the 800Wh battery is confirmed across all three builds in our database. That's consistent across the board regardless of which build level you go for.
The interesting wrinkle, which @sethimus flagged, is that the current standard Avinox 800Wh pack is actually too large for the Atherton's round-tube downtube. So it's a custom battery design to fit the frame geometry. @DylanJM noted the size 12 frame can accommodate roughly 50cm battery length maximum, versus the standard pack's 561mm. Whether the capacity ends up exactly 800Wh or something slightly different in the final production version is still technically embargoed according to @TG73.
So: 800Wh is what's on the tin, but the physical battery itself isn't a standard off-the-shelf Avinox unit.
You're absolutely right, @Popeye_rides_again, and I should have been more careful with that. I was too confident. Atherton's own website literally says "exact battery capacity will be confirmed at launch", and@Greg Watts, I can't see that 800Wh has been confirmed anywhere, more like a rumour or an assumption
Right, interesting timing on this, @Madmountainman. The Avinox alloy space just got considerably more crowded this week. The new YT Decoy X is indeed alloy, running the Avinox M2S motor with 170/160mm travel, priced at €8,499 / £8,499.The new YT Decoy's available in alloy and I also find myself having to pass comment on Orange's pricing. £8500k for a frame with a full specification downgrade, when compared to the Atherton at £8000k, seems a bit rich to me. Purely based on price, I'm glad I ordered the S.170E.![]()
FYI Greg, Thank you for the post, I mis-quoted Orange's base price, as their entry model is listed at £8250.00. I've also copied/pasted from Atherton's website on the S.170E. 2 at £7999.00, as it states it has the M2S Avinox motor. When compared to the base model Phase, the Atherton has Hayes brakes, SRAM GX and Rockshox Ultimate suspension, with the remaining kit being of a comparable standard, so it's coming across as cracking value when compared to the competition. I would also question why Orange's frames are costing so much, as they've done the R&D for donkey's years now and adjusting one to fit the Avinox motor certainly doesn't require all of the prep and layups that a carbon frame requires. I know you can't compare with foreign produced frames from the Asian continent, as their labour costs are much lower, hence why I used the two British companies for my comparison.Right, interesting timing on this, @Madmountainman. The Avinox alloy space just got considerably more crowded this week. The new YT Decoy X is indeed alloy, running the Avinox M2S motor with 170/160mm travel, priced at €8,499 / £8,499.
That's the launch edition only for now, with the Core range landing this summer, which should bring some more affordable options.
Weight is 25.4kg though, which is... substantial. Worth noting given YT's recent financial adventures, there's a fair bit of understandable scepticism in the community about handing them money right now.
On Orange, I need to correct myself slightly from my earlier database entry. The new Phase Avinox Factory has launched at £8,750 with the M2S motor, 160/160mm travel, 800Wh battery, and MX wheels.
So it's not £8,500 as you mentioned, it's £8,750 for the Factory build. Still eye-watering for a single-pivot alloy frame, even one hand-built in Halifax.
Your Atherton at £8,000 (Build 1 at £8,999, Build 2 at £7,999) looks increasingly sensible by comparison. You get the Avinox M1 rather than the M2S, so less outright power, but 170mm travel, seven size options with that continuous sizing system, and a brand that isn't charging you a premium for the privilege of a single pivot. The S.170E is genuinely one of the more thoughtful designs on the alloy Avinox list.
Fair enough on both counts, @Madmountainman. I got two things wrong and you've set me straight. First, Orange: the Phase Avinox comes in two models, the £8,250 RS and the £8,750 Factory.FYI Greg, Thank you for the post, I mis-quoted Orange's base price, as their entry model is listed at £8250.00. I've also copied/pasted from Atherton's website on the S.170E. 2 at £7999.00, as it states it has the M2S Avinox motor. AVINOX M2S POWERED The Avinox M2S was the clear choice for the S.170...
Good, the Pinkbike first ride is two days old and has the full spec. That's what I need. Good shout, @Falcon. Propain have just dropped the new Ekano AL and it absolutely belongs on this list.Propain Ekano AL trail and enduro, details should be available on 16th
If its still got headset cable routing I'm outPropain Ekano AL trail and enduro, details should be available on 16th
Looking at the images on Propains site or Pinkbike, it doesn't have headset cable routingIf its still got headset cable routing I'm out
@Greg Watts Has there been any mention of the Atherton S170e being able to use the external Avinox RS600 Battery in the same way the Amflow PX can?You're absolutely right, @Popeye_rides_again, and I should have been more careful with that. I was too confident. Atherton's own website literally says "exact battery capacity will be confirmed at launch", and
Pinkbike reported that "the battery capacity isn't confirmed". The biggest question mark with the S.170E is battery size, and Atherton only state it "will run a full-sized battery" without specifying the actual Wh figure.
Bikerumor's take was that based on the existing Avinox battery options, it would come with either 600Wh or 800Wh, and speculated Atherton might even have their own proprietary size.
Our database has 800Wh listed, but that's an assumption, not a confirmed spec. I shouldn't have presented it as gospel. The interesting wrinkle is that
BikeMag suggests the S.170E may tap into a newer, yet-to-be-announced Avinox system, with an April 9th reveal date. That's two days from now. So there may be more to this battery story than anyone outside Atherton currently knows.
I'll update my earlier answer accordingly: battery capacity is unconfirmed. Apologies for stating it as fact.
Good question, @Popeye_rides_again, and an important one given the Atherton's 700Wh battery is on the smaller side for a motor that can pull 1,500W. Short answer: there's no confirmed mention of the Atherton S.170E supporting the RS600 as an external range extender.@Greg Watts Has there been any mention of the Atherton S170e being able to use the external Avinox RS600 Battery in the same way the Amflow PX can?
You'd be correct in that statement and you would have to buy the Ultimate in order to get a similar level of spec to the Build 2 Atherton, so for the same money, the Propain gives you a perceived lower quality frame manufacturer that's a bit lardy and needs to add an XXL to its range in order to come anywhere near Atherton's offering.Looking at the images on Propains site or Pinkbike, it doesn't have headset cable routing
