2026 Reign e+
Bar57
Looking for owner experience on the new 2026 Reign e+1 in particular but either model. Considering buying.​
Welcome to the forum, @Bar57. The 2026 Reign E+ is a fairly significant departure from the outgoing model. The headline changes are a full-carbon frame, 180mm front / 170mm rear travel (up from 170/160mm), and the new Yamaha SyncDrive Pro 3 motor. The motor is suspected to be based on a new Yamaha PW-Link system with a CAN-Open architecture, which is what enables the integrated TPMS on the top tube display. Battery is a 560Wh integrated unit, and usefully the package apparently includes a 280Wh range extender as standard. The whole thing is reportedly around 4-5kg lighter than the old model, with a full-carbon frame doing most of that work.
The E+1 specifically sits in interesting territory. @Redlemon reported that the first batch of E+1s in Canada sold almost immediately, which suggests Giant aren't flooding the market with them. Worth factoring in that availability may be tight depending on where you are.
On the geometry, I have verified numbers for the Reign Advanced E+ in size Large (reach 480mm, stack 667mm, 63.5° head angle, 450mm chainstay) and our database also shows an unverified LG High entry at 485mm reach and 665mm stack, though I'd cross-check those against Giant's own site before making any sizing decisions.
Long-term owners of the 2022 model were broadly satisfied. @Wallybean has 3,000+ miles on theirs doing 35+ mile rides with serious elevation, regularly using all the travel. The 2026 design is said to be more playful and agile than the previous generation, which was already well-regarded for its downhill manners.
What size are you looking at, and where are you based? I can dig into the geometry comparison more specifically, or pull up what owners have said about range if that's a concern.
Would be looking at Medium and located in Rossland BC. Canada.
Rossland is excellent choice of location for a bike like this. Seven Summits alone justifies the travel, and Red Mountain's terrain is exactly what the Reign E+ was designed for.
For Medium, here's what the geometry looks like across the flip chip positions:
PositionReachStackHead AngleSeat AngleChainstayWheelbaseBB DropHead Tube
MD High465mm651mm63.9°77.9°450mm1261mm10mm105mm
MD Mid460mm654mm63.5°77.5°450mm1261mm5mm105mm
MD Low456mm656mm63.1°77.1°450mm1261mm10mm105mm
Those are verified numbers from the Advanced E+ geometry. The standard Reign E+ runs slightly different numbers (it uses a 442mm chainstay vs the Advanced's 450mm, and slightly less stack), so worth confirming which model you're after before making any decisions.
The 460mm reach in the mid position is a solid number for a bike meant to charge down technical terrain. Rossland's trails tend to reward that kind of geometry rather than punishing it.
One thing worth flagging on the E+1 specifically: confirmed specs indicate the 560Wh battery can take a larger 840Wh pack, and the range extender arrangement may differ between trim levels. Worth asking your dealer exactly what comes with the E+1 versus the higher specs, because the battery situation is a meaningful part of the value calculation given the riding up there.
The 48V/90Nm SyncDrive Pro 3 motor is the headline piece. @Le_fabulero75 noted it's based on the Yamaha PW-X4 architecture with the 48V system being the meaningful step up from the previous generation's efficiency shortcomings. The old SyncDrive Pro 2 was never particularly efficient for its battery capacity; the new 48V system addresses that directly.
Category 5 frame rating means it's park-legal if you find yourself over at Whistler on a day trip, which from Rossland is not exactly an unreasonable proposition.
I can pull owner feedback on long-term reliability of the SyncDrive motors, or dig into what the E+1 spec sheet looks like versus the Advanced E+ if that comparison would help narrow it down.
    668K
