Welcome to the forum, @Bar57. The 2026 Reign E+ is a fairly significant departure from the outgoing model. The headline changes are a full-carbon frame, 180mm front / 170mm rear travel (up from 170/160mm), and the new Yamaha SyncDrive Pro 3 motor. The motor is suspected to be based on a new Yamaha PW-Link system with a CAN-Open architecture, which is what enables the integrated TPMS on the top tube display. Battery is a 560Wh integrated unit, and usefully the package apparently includes a 280Wh range extender as standard. The whole thing is reportedly around 4-5kg lighter than the old model, with a full-carbon frame doing most of that work.Looking for owner experience on the new 2026 Reign e+1 in particular but either model. Considering buying.
Would be looking at Medium and located in Rossland BC. Canada.Welcome to the forum, @Bar57. The 2026 Reign E+ is a fairly significant departure from the outgoing model. The headline changes are a full-carbon frame, 180mm front / 170mm rear travel (up from 170/160mm), and the new Yamaha SyncDrive Pro 3 motor. The motor is suspected to be based on a new Yamaha PW-Link system with a CAN-Open architecture, which is what enables the integrated TPMS on the top tube display. Battery is a 560Wh integrated unit, and usefully the package apparently includes a 280Wh range extender as standard. The whole thing is reportedly around 4-5kg lighter than the old model, with a full-carbon frame doing most of that work.
The E+1 specifically sits in interesting territory. @Redlemon reported that the first batch of E+1s in Canada sold almost immediately, which suggests Giant aren't flooding the market with them. Worth factoring in that availability may be tight depending on where you are.
On the geometry, I have verified numbers for the Reign Advanced E+ in size Large (reach 480mm, stack 667mm, 63.5° head angle, 450mm chainstay) and our database also shows an unverified LG High entry at 485mm reach and 665mm stack, though I'd cross-check those against Giant's own site before making any sizing decisions.
Long-term owners of the 2022 model were broadly satisfied. @Wallybean has 3,000+ miles on theirs doing 35+ mile rides with serious elevation, regularly using all the travel. The 2026 design is said to be more playful and agile than the previous generation, which was already well-regarded for its downhill manners.
What size are you looking at, and where are you based? I can dig into the geometry comparison more specifically, or pull up what owners have said about range if that's a concern.
Rossland is excellent choice of location for a bike like this. Seven Summits alone justifies the travel, and Red Mountain's terrain is exactly what the Reign E+ was designed for.Would be looking at Medium and located in Rossland BC. Canada.
| Position | Reach | Stack | Head Angle | Seat Angle | Chainstay | Wheelbase | BB Drop | Head Tube |
| MD High | 465mm | 651mm | 63.9° | 77.9° | 450mm | 1261mm | 10mm | 105mm |
| MD Mid | 460mm | 654mm | 63.5° | 77.5° | 450mm | 1261mm | 5mm | 105mm |
| MD Low | 456mm | 656mm | 63.1° | 77.1° | 450mm | 1261mm | 10mm | 105mm |
