2022 Rail 9.8 XT tires???
DeeP
12
I am very torn which direction to go. Schwalbe Super Downhill Big Betty and a Super Gravity Magic Mary front in 2.4, or DHF Exo+ and DHR Exo+ in 2.6. I know both are killer options. I am leaning to the 2.6 I think...tho I have ALWAYS run 2.4s and like them a lot. Thoughts??
Jhagst
75
64
California Bay Area
I went 2.6 Magic Marry trail in front and 2.6 Big Betty Trail w/ Cush Core in the rear. Works well
Had 2.5 Assegai DD max grip front and 2.4 DHR II max grip rear. Tried with/without Cush Core. Excellent on the drops, but horrible rolling resistance. Felt like the brakes were on or I was towing a parachute.
beej
28
12
Melbourne, AUS
I assume Maxxis DHF or DHRs in 29 x 2.6 fit in the rear triangle with a bit of space to spare? I'm shortly about to pull the trigger and my methodology on tyres over the past 2 decades has been: One you go Maxxis you never go baxxis.
Doug Stampfer
736
752
NZ
Seriously? You could actually feel difference in rolling resistance even with a 2.4 on the back of an emtb? You sir are a highly tuned test pilot. There would be a job for you on Loam ranger
beej
28
12
Melbourne, AUS
... almost thought my bike was broken or my brakes were dragging
I usually attribute that to the 10 extra kilos I've put on since having kids and my riding dropped to near zero. I reckon a motor under my balls will render such things as heavy tyres non-existent. At least, that's what it feels like on test rides so far.
irie
2,016
1,961
Chichester, W.Sussex, UK
Looked at Maxxis Assegai front and DHR rear but decided to go Bontrager SE6 front and SE5 rear. Both 2.5" and both roll nicely given their grip. Don't seem to have any vague grip areas, very predictable. Made by the same company who make Maxxis.
JP-NZ
1,032
778
Christchurch - New Zealand
Those are the factory tyres on a 9.8XT are they not?
Doug Stampfer
736
752
NZ
That would be a very economical choice. They're just about given away on the local fb for sale page, usually in a bundle with the Code brake sets.
My first reaction was that you've prob gone from the best tyre setup I've tried to the worst however that is for the tracks I ride, I could see on long flowy dry tracks where traction isn't as important they would certainly be fast rolling.
irie
2,016
1,961
There's nothing like a good old fashioned brand snobbery putdown, eh Stumpy? ;)
Doug Stampfer
736
752
NZ
😁 I'm not really a brand snob (there are no brand labels to be seen on my bike), but Yes gotta be honest I'm not taken with Bonty stuff (& never ridden with Codes so can't really comment on them) but there is an element of truth in my jibe- the maxxis that come up for sale on FB are usually pretty worn & the bontys are always brand new. Almost everyday there is a new or nearly new set of codes. I find it a bit amusing more than anything, especially one comment on a set of bontys for sale that said something to the tune of " nothing unites people more than the hatred of bontrager tyres"
I'm loving the Assegai up front - I'd be truly amazed if there is a better front. We don't really have the range of tyres easily accessible over here than I think you guys do in the UK so Maxxis is the usual default.
JP-NZ
1,032
778
The one I always liked is "friends don't let friends ride codes" :ROFLMAO:
urastus
⚡The Whippet⚡
May 4, 2020
1,548
993
Tasmania
that's my winter tyre selection :). I'm kind of enjoying dhf front and rear through the drier months.
I have formed a theory peculiar to maxxis tyres - maybe to other tyres too. I had a rear dhr in maxterra compound - I got 2,500km out of that. It still has some tread. I don't slide around corners or brake traction on purpose - I rarely lost traction with that tyre.
I thought I'd try a new dhf in dual compound (harder than maxterra). I seem to be sliding a lot more. Of course I can modify my riding and skill, but the dhf in dual compound always catches me out. That tyre is wearing very quickly. The previous dhf in maxterra did not do this - in fact I didn't feel much difference with that and the dhr (better rolling on the dhf, better mud clearing on the dhr).
My theoretical takeaway from this is that maxterra is more economical than dual compound for me. It lasts longer because I lose traction much less.
beej
28
12
Melbourne, AUS
Noted. This tyre wasn't around last time I had to buy some.
This was my go-to setup all year round. I don't ride in mud or extreme wet - our local trails don't really respond well.
Think I might explore Assegai up front (prob 3C) and DHF rear - 2.6 for both. Back in the day I used to run a DH casing in the rear to compensate for my extra mass (100+ kg), but it was a wire bead and weighed like 2kg. Is there a good folding solution for heavy folk wanting to run as low a pressure as possible these days? I see lots of jargon for each tyre on the Maxxis site, with some descriptions, but nothing that says "Use this if you used to run DH casings".
Doug Stampfer
736
752
NZ
Interesting, I didn't know the dual compound was harder than max terra. It must be bloody hard then. I just took off a max terra DHR after 300+ kms & looks hardly worn. I'd like to say I rarely lose traction with my rear tyre but all the Ben cathro videos still haven't helped me.
I couldn't go back to a DHF after riding my Assegai, I find them great for the local tracks however we don't get a lot of mud so I could see why a more spaced out pattern would be desirable over them. Def love maxx grip up front & maxterra out the back
Doug Stampfer
736
752
NZ
I was running cushcore on the back with exo+ but since mulleting am just running a DD, not sure if I'll put a cushcore in as they are really supportive. I'd try one of those if I was you. I usually run 19-20 on front & 18ish rear & I ride mostly tight techy style tracks with narrow cut off at just above ground level tree stumps & rocks that like to rip tyres & not many speed sections.
beej
28
12
Melbourne, AUS
I have been researching these in the background for the past hour or so. I've never run them, but this is/will be the first new MTB in over a decade, so there's going to be a lot of firsts. Chief of which will be the motor under my balls.
Currently watching a Chshcore vs Nukeproof ARD vs MegaNorriss YT vid
