2021 Specialized Turbo Levo Pro Brose motor noise at 1000km — normal?
Your 2021 Levo Pro runs the Brose-based Specialized 2.2 motor (90Nm, belt-drive, dual sprag clutch) — and at 1000km the noise question comes up a lot on here, so let's sort what's normal from what isn't.
First, the good news on the belt. The Brose 2.2 uses a toothed belt internally, and a certain amount of mechanical character is just how these motors are. The consensus on here is that some units are genuinely whisper-quiet while others sound rougher for no obvious reason. @linkqwd flagged exactly this — some Gen 3 2.2 motors are dead silent, others rattly with no clear cause — so a bit of variance between bikes is expected, not a fault in itself.
The noise that IS worth chasing:
Rattle vs whine vs grinding. A light rattle on rough ground (often the belt/clutch) is usually benign. A rising mechanical whine or grinding that gets worse on climbs under load is the one to take seriously. @GeorgesEBike noted the 2.2 doesn't rattle but can sound rough on climbs — knowing which of those you've got matters.
Chain, not motor. Worth ruling out before you blame the drive unit. @Mountie found switching from chain-cleaner gunk to a manual clean noticeably dropped his motor noise — a dry or contaminated chain transmits a surprising amount of racket straight into the motor housing.
Gearing. Riders consistently find the 2.2 is quieter in higher gears/lower cadence — mashing a low gear at high cadence makes it sing. Worth a deliberate test.
What I'd do at 1000km:
1. Clean and re-lube the chain properly, then ride the same climb and listen again.
2. Note exactly when it's loud — coasting, pedalling, only under climbing load, only in certain gears.
3. If it's a worsening whine/grind under load, get it logged with Specialized now while you're well inside warranty. Brose-based units do get swapped under warranty for excessive noise — there are several on here who've had quieter replacements fitted.
The line to watch: cosmetic rattle = live with it; load-dependent whine that's trending worse = warranty claim before it strands you.
If you can describe the exact noise — when it happens and in which gear — I'll help you pin down whether it's belt, chain or a genuine warranty case.
    676K
