2020 Kenevo blown Boxxer.
Kenebeau
15
26
I'm 4th ride in on my brand new 2020 kenevo expert and "crack!!" Went the fork on rebound. It topped out super hard sending me into a pretty sketchy nose dive. It happened when i was at spawn pulling up to hop over a big devil root. I pulled over and bounced on the fork a few times, there was no resistance to the for returning back to full extension. No doubt that this is a warranty issue, but has anyone else experienced anything similar in theirs??
Im also getting a pretty loud rattle/clunk from the rear linkage. Everything is tight??.
ScottWest
123
76
Oregon
That is nasty! is the rebound adjuster still on the bottom of the fork leg? If so, Remove the damper and check it for function/leaks..
Rob Rides EMTB
Administrator
Staff member
6,164
13,305
Surrey, UK
Keep blowing through all the travel on mine and bottoming out. Running about 18% sag and 3 out of 4 tokens. Going to add the last token to see how it runs.
Might change to the 2.1 damper after that.
ScottWest
123
76
Oregon
Big huck'n to flat or normal aggressive ridding? The service manual says 6 tokens maximum.
Rob Rides EMTB
Administrator
Staff member
6,164
13,305
Surrey, UK
Big huck'n to flat or normal aggressive ridding? The manual says 6 tokens maximum.
Normal aggressive riding. 4 ft drops / gaps to slight declines etc.
Didn’t realise up to 6 that’s good to know. Best stuff a couple more in, might even be able increase sag a bit.
Kenebeau
15
26
I'm pretty handy, but ill take it back to the shop before I touch anything to be sure I dont void the warranty. The knob is still in tact.
Kenebeau
15
26
They seem very liniar. I'm running 170psi 4 tokens and still find the bottom (112kg, im husky ?.) I was thinking about putting push HC97 dampner in. Theres no no shims in their system to blow.
In comparison the rear with standard spring rate s4=550ibs seems to be a perfect fit! I have found the bottom a few times but only on the really big hits.
Kenebeau
15
26
Just an update! Sram Australia replaced the fork damper with an upgrade rc2 2.1 without promoting! Was actually a pretty sweet surprise!
MPalli
7
Styria
Hey Rob, I bought the Kenevo just a couple of weeks ago and have the same problem: it just keeps bottoming out.
Your review about the bike was not mentioning the tricky suspension setup process… Did you figure it out in the end?
And did anyone ever have problems with zinging rotors? I mean, riding on the street at 25 kmh and the back rotor is constantly zinging… checked for straightness - all parts straight…
Alexbn921
545
506
East Bay CA
I added 2 spacers to mine to help with bottom out. If you ride aggressive more spacers helps.
My rotors zing too. the hubs seem to have so play in them. Doesn't seem detrimental, but is annoying.
MPalli
7
Styria
Maybe it’s just me - but a constantly zinging rotor is really annoying on a brandnew bike costing 7,500 Euros!?
It’s funny how the rattl
Here’s a recording for your listening pleasure:
