2020 E-Sommet Headset/fork creaky cracking noise
Scaff
rh7 6lw
Anyone know what this could be, bike only 1 month old, happened after cleaning it first time using normal cleaning technique, no jet wash etc...
makes cracking noise when you stoppie or on impact, I've taken fork out and cleaned up bearings and regreased and still the same
hopefully the vid ive tried to upload works..
Click here for vid
Scaff
rh7 6lw
Google fox 36 csu creak. Also search the same on YouTube. You will find all your answers.
Thanks, I remeber watching a vid about this a while back, now ive watched again i reckon its gotta be my problem.
a set of zebs it is then.. :)
Dave_h34
78
42
Warwick
Take the wheel and axle out, push one leg backwards, the other forwards; then repeat in the opposite direction. If it cracks then it's likely to be CSU, but you need to do the same with the fork out to be 100% sure.
500K
