For Sale (BIKE) 2019 Specialized Turbo Levo Comp FSR Small: £3950
DarrenCC
59
21
Hertfordshire
Bike / Product Year: 2019
Manufacturer: Specialized
Model: Turbo Levo Comp FSR
Size Small
Asking Price: £3950
Location Hertfordshire UK
Description
2019 Specialized Turbo Levo FSR Comp Small E-mountain bike. Includes TRANSFERABLE WARRANTY! Proof of purchase will be provided to the next owner
Firmware all up to date, battery health 100%, 8 charge cycles, odometer 452km!
Absolutely fantastic condition, barely used!
Fully Invisiframe protected from new.
This is my wife’s bike and it has spent it’s very few ridden miles with it’s wheels firmly on the ground and a basket on the handlebar…
I have plenty more photos, there are only a few tiny storage marks but you have to really look for them!
My wife just doesn’t need this and she would prefer a hybrid type e-bike so this is a genuinely honest and all but showroom condition Levo with no abuse whatsoever and a complete original spec (apart from a WTB SpeedShe Saddle). I have added a custom SiCom rear mudguard and a Zefal front mudguard.
Charger and original Specialized manual all included
The motor/battery cable was replaced under warranty by Specialized due to a batch of poorly kinked cables inside the motor housing. No other issues
***ASK QUESTIONS, VIEWING RECOMMENDED, MORE PHOTOS AVAILABLE ***
I will box and send with Parcelforce as they are trustworthy and I have used them for a number of bikes and frames OR I will consider delivering myself (depending where you are) at £1 per mile. Please ask first though!!
Tech Spec
Frame
Specialized M5 Premium Aluminum, 29 Trail Geometry, integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel
Fork
RockShox Revelation Charger RC, 29" Boost™, 150mm of travel
Rear Shock
RockShox Deluxe RT w/ custom air valve, 150mm of travel
Front Hub
Specialized, sealed cartridge bearings, 15x110mm thru-axle, 28h
Rear Hub
Specialized, sealed cartridge bearings, 12x148mm thru-axle, 28h
Spokes
DT Swiss Industry
Rims
Roval Traverse 29, hookless alloy, 30mm inner width, tubeless ready
Inner Tubes
Standard, Presta valve
Front Tyre
Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
Rear Tyre
Crankset
Praxis, 2D cold-forged alloy, custom offset, 165mm
Chainrings
32T, custom steel
Shifters
SRAM S700, single-click lever
Rear Derailleur
SRAM GX, long cage, 11-speed
Cassette
SRAM PG-1130, 11-speed, 11-42t
Chain
KMC X11ET, 11-speed w/ Missing Link™
Front Brake
SRAM Guide RE, 4-piston caliper, hydraulic disc, 200mm
Rear Brake
Handlebars
Specialized Trail, 6061 alloy, 8-degree backsweep, 6-degree upsweep, 27mm rise, 780mm, 31.8mm clamp
Grips
Specialized Sip Grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
Stem
Specialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise
Saddle
WTB SpeedShe
Seatpost
X-Fusion Manic, 34.9mm, 125mm of travel (Small), 150mm of travel (M/XL)
Seat Binder
Alloy, 38.6mm
Motor
Specialized 2.1, custom Rx Trail-tuned motor, 250W nominal
UI/Remote
Specialized TCU, 10-LED state of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, handlebar remote with walk-assist
Battery
Turbo M2-500, fully integrated w/ rock guard, 500Wh
Charger
Custom charger, 42V4A w/ Rosenberger plug
Wiring Harness
Custom Specialized wiring harness
524K
