Sold 2019 Specialized Levo S-Works (Medium): 6500
Coff-E
Munich
Bike / Product Year: 2019
Manufacturer: Specialized
Model: Levo S-Works
Asking Price: 6500
Location Munich, Germany
Description Selling this medium 2019 Levo dream build in used but excellent condition, currently bike is in Munich but happy to ship worldwide at buyers expense
The bike was taken to the Munich concept store in Feb-20 for a full e-bike service, new brake pads, rear tyre, and the 2020 firmware update and 2020 motor compartment rubber seal installed. In effect making this identical to the 2020 model.
The standard spec is as per below but the upgrades that are included with the bike are:
Fox 36 E-bike fork upgrade to 160mm internals (from 150mm)
Fox Transfer Performance (black) 175 dropper - not pictured
Race Face dropper lever
Hope Disc rotors F/R
Hope Chainring
Hope pulley wheels
Hope seat tube clamp & fork tube spacers
Tyres upgraded to HillBilly Front and Butcher Rear both with Diamond Black Casing and Victoria Air-liner inserts
Pro Saddle
FRAME S-Works FACT 11m full carbon, 29 Trail Geometry, Integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel
SEAT BINDER Specialized Ti-bolt-type, alloy, 38.6mm
FORK FOX 36 Factory, GRIP2 damper, 29" Boost™, 150mm of travel
HANDLEBARS Specialized Trail, FACT Carbon, 6-degree upsweep, 8-degree backsweep, 27mm rise, 780mm, 31.8mm
STEM Deity Copperhead, 31.8mm
SEATPOST Specialized Command Post, 34.9mm, 130mm of travel (Size: Small), 160mm of travel (Sizes: M/XL)
SADDLE Body Geometry Phenom Expert, hollow titanium rails, carbon fiber base, 143mm
GRIPS Specialized Sip grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
REAR SHOCK FOX FLOAT Factory DPS, 210x52.5, 150mm of travel
REAR DERAILLEUR SRAM XX1, 11-speed
CRANKSET Praxis, full carbon ISIS, custom offset, 165mm
CHAIN SRAM XX1, 11-speed
CASSETTE SRAM XG1199, XD, 11-speed, 10-42t
SHIFT LEVERS SRAM X01, single-click lever
CHAINRINGS 32T, custom steel
REAR BRAKE SRAM Code RSC, 4-piston caliper, hydraulic disc, 200mm
FRONT BRAKE SRAM Code RSC, 4-piston caliper, hydraulic disc, 200mm
FRONT HUB Roval Traverse SL, sealed cartridge bearings, 15mm thru-axle, 110mm spacing, 28h
RIMS Roval Traverse SL, hookless carbon, tubeless ready
INNER TUBES Standard, Presta valve
FRONT TIRE Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
SPOKES DT Competition Race
REAR HUB Roval Traverse SL, DT Swiss Star Ratchet, 54t engagement, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h
REAR TIRE Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
BATTERY Turbo M2-700, fully integrated w/ rock guard, 700 Wh
MOTOR Specialized 2.1, custom Rx Trail-tuned motor, 250W nominal
UI/REMOTE Specialized TCU, 10-LED state of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, handlebar remote with walk-assist
WIRING HARNESS Custom Specialized wiring harness
CHARGER Custom charger, 42V4A w/ Rosenberger plug
Bike has done about 1500km and the battery health is 100% with about 30 charge cycles only.
As shown in the pictures there is some wear, the rear derailleur has some surface scratches and the fork decals have some tearing, which can be easily replaced
526K
