2019 Base Levo going tubeless
chrisdut
30
17
Chester
Hi all,
I've tried searching the forum for definitive answers but came up short so hope people don't mind the post
Is there a kit form product I can buy that will include all the bits I need to make my Levo tubeless?
Or a list of parts I require?
I know they are 29" 30mm rims, just lost of tape thickness, make of valves, type of sealant etc etc
Thanks all
Mcharza
E*POWAH BOSS
Aug 10, 2018
2,516
4,801
Helsinki, Finland
Actually Specialized tubeless valves are good and the rims already have tapes. So buy valves and some tubeless sealant. Much cheaper. But don't buy Stan's normal sealant, it dries very quickly. Pro is good and Schwalbe's also
escrs
283
260
My 17 Levo and 18 Kenevo came with the 2bliss tubeless rim strips already fitted to the rims and the Specialized tubeless valves were in a bag with the warranty book/user manual, i would of thought the 19 Levo would be the same so all you need to do is fit the valves and buy some sealant
davarello
305
360
New Zealand
I don't think you'll get a definitive answer on the sealant, but I haven't had any problem with Stan's, I've topped it up a couple of times in the last 10 months but otherwise all good (an no flats). Also running Cushcore which I expect is helping as well.
KennyB
824
562
Taunton
I also like Stan's, the normal stuff, the race type dries out very quickly. For valves, I use Milkit. Much easier and less messy as filling, checking and topping up all done with the tyre pressurised via a syringe through the valve body - no need to get the bead off. You will also need a compressor or something like Airshot (I think, it's a canister you pump to 130 psi to get the tyre seated on the rim). And don't forget to check the sealant every 3 months, more often of you are in a hot climate.
KennyB
824
562
Taunton
Oops, it's the tyre that is pressurised, the syringe and plastic needle squirts the stuff in.
chrisdut
30
17
Chester
Thanks for the replies all
I didn't get any tubeless valves in my paperwork with my 19 levo from Evan's cycles
I've ordered some muc off sealant and valves from eivlbay and will sort then out when they arrive and post an update
chrisdut
30
17
Chester
So I went tubeless
Muc-off valves and sealant
Things to note haha
Ensure once you refit the tyres, that you check the rotation is the correct way before sealing the beads and filling with the sealant. It makes a bit of a mess when you have to deflate the tyre, break the bead, remove, turn it around and then refit haha
The muc-off sealant smells lovely too
All in all pretty easy to do
8,676
@chrisdut Did you get your train tracks parallel?
Train tracks are the moulded lines close to and parallel to the bead (sometimes connected by lines so they look like train tracks!) The moulded line should be parallel to the rim to ensure that the tyre is properly positioned. Sometimes the line can disappear under the rim. To reposition the line, let out a lot of air so that the tyre is very soft. Then grab the wheel with both hands close together and heave. Sometimes waving tyre about will provide extra heave! This will move the tyre on the rim. Keep going until the train tracks are parallel. Don't forget to restore your tyre pressure.
Why bother at all? This fits the tyre as best as possible on the rim and reduces wheel wobble. Hold the bars lift the wheel off the ground and give the wheel a spin, you'll soon notice any wobble.
chrisdut
30
17
Chester
Yep quickly noticed on the first tyre that it hadn't seated, I could squeeze the side wall with the tyre inflated and air would come out
Luckily I have a small compressor at home so pumped up some more and the tyre popped on
8,676
I have taken my tyres up to 60 psi until they stop banging and popping, and still found the train tracks were not parallel! Now I always check before pumping up to high level to ensure that the bead is seated.
