Sold 2018 Specialized Turbo Levo Comp (Large) Upgraded Rear Shock with Extras: £2900.00
NigelW
Bike / Product Year: 2018
Manufacturer: Specialized
Model: Turbo Levo Comp (Large) Upgraded Rear Shock with Extras
Asking Price: £2900.00
Description: Hi
I am selling my 2018 Turbo Levo (Large) this was purchased from Berkshire Cycles last year with an uprated rear shock. The original shock was upgraded to a Rockshox Monarch Plus RC3.
I have since then installed 2.6" Tyres and retained the 2.8" also changed the Stem and in have a Turbo Connect Display additionally the original dropper post was temperamental so this was replaced with a more reliable 150mm dropper.
The bike is in excellent condition and has been well looked after, only just had a service after returning from Southern Ireland, normal full serives carried out and had new chain fitted along with bearing changed in the hubs front and rear.
I will be changing to a different bike, so will also give the new owner some shorter cranks and spare pads along with a bleed kit and DOT5.1 fluid.
Asking Price is 2900.00, bike is still in warranty and will come with original reciept.
Below is the original spec...
Built from a sturdy M5 Premium aluminium, the 2018 Turbo Levo Comp has improved on what many considered to be the perfect all-round emtb. The frame seamlessly integrates the newly updated Specialized 1.3 motor, which features 15% more power than the previous model and with fine-tuning of the software from Specialized, it is more efficient on battery levels. The Turbo Levo motor has always been admired for its silent operation due to an internal belt drive, which can often mislead fellow cyclists in to thinking you aren't riding an eBike! Combined with an upgraded 504Wh battery, the Levo is capable of powering you further than you have ever been before. Another innovation for 2018 is the bar-mounted remote which allows you to change between the assistance levels of the motor, as well as featuring a handy walk-assist mode and a turbo button which pushes you up to the maximum assistance mode at just a single touch of the button.
The perfect combination of a RockShox Revelation 150mm fork and Monarch RT 135mm rear shock gives ample cushioning over the roughest of singletrack. The Revelation fork has been updated for 2018 with a beefy 34mm stanchion which makes the bike feel extremely controlled when taking on sharp corners or berms. The AUTOSAG feature of the Monarch takes the frustration away from getting your suspension set-up dialled in perfectly and also includes a rebound and 2-position compression adjust to make sure each individual rider gets their tuning exactly to their liking.
SRAM's 11-Speed GX drivetrain has quickly become regarded as the go-to for gravity-focused riders, who want a cost-effective solution that delivers durability and dependability. Complete with an 11-42t cassette, the 2018 Levo Comp has enough range to take you faster than ever before, whilst still providing enough lower gearing for those riders who do not want to heavily rely on the assistance from the motor. The GX drivetrain has been German engineered and incorporates the same championship winning 1x technologies as the industry leading X01 drivetrain.
The 2018 Levo rolls on 27.5" Roval Traverse rims fitted with chunky 2.8" wide Butcher tyres which perform like no other on the trail, offering unparalleled levels of grip and control. The wheelset works in combination with the SRAM Guide RE brakes which have been engineered specifically for eBikes to give you increased confidence when out on the trail. The Guide RE brakes are capable of handling the additional speeds that eBikes reach, as well as the additional mass due to the presence of the motor and battery. The 4-Piston design provides extreme amounts of control when speeding down, or even up the trail.
A dropper post is included as standard on the Levo Comp and has quickly earnt its place as one of the must-haves for trail riding. The Command Post IRcc comes with 12 position, micro height adjustment and internal cable routing with up to 125mm of travel dependant on frame size.
  • Specialized 1.3, custom Rx Trail-tuned motor, 250W Nominal
  • Specialized M1-504, integrated Trail Display, ANT+/Bluetooth® module, 504Wh, Mission Control App connectivity
  • Trail Handlebar Remote, motor mode switch & walk-assist
  • RockShox Revelation RC, 150mm travel fork
  • RockShox Monarch RT, 135mm travel rear shock
If you have any question please feel free to drop me a message.
Regards
Nigel
hiView attachment 15058
Description: Hi
Regards
Nigel[/QUOTE
Hi Nigel , I,m new to the site and would be interested in your levo...
Is it possible to give you a call or email?
thanks
Graham.
Hi Nigel, I,m new to the site and would be interested in your levo...
Graham
    675K
