For Sale (BIKE) 2017 Whyte G160: 1250
Northants
Bike / Product Year: 2017
Manufacturer: Whyte
Model: G160
Asking Price: 1250
Description: 2017 medium g160 works frame with rockshox monarch plus shock (3 bands fitted to ramp the compression slightly)
Hope headset
170mm yari rc
Hope pro4 boost rear hub and pro2 front with boost torque caps, both laced to mavic 624 32h rims with aci dB spokes
Maxxis minion dhf 3c maxx terra exo front
Minion ss silkworm exo rear both tubeless
Slx 11spd mech and shifter with sunrace 11-50 cassette and sram pc 1110 chain at less than 0.5 wear so good for ages yet before needing a change
Raceface aeffect 170mm crankset with 30t oval absolute black chainring spinning on a token 24mm bb (identical to hope.. Even uses same bearing code of 6805r instead of 6805 and tophats)
Easton 35mm carbon bars 750mm wide with 35-40mm rise mated to a 32mm raceface turbine stem and carbon stackers.
Brand x 30.9 150 stealth dropper.
Ht pa03a pedals in orange
Slx m7000 levers mated to zee calipers with Uberbike kevlar pads and 200mm rt66 rotors
Orange odi grips
Excellent geometry for anyone 5’8 up to 6′ 1 ish
479mm reach
1230mm wheelbase measured from the centre to centre of each wheel axle
Everything runs as it should.. Always gets cleaned after rides and lubed up.. . Nothing needs replacing.
Never crashed.. Mainly used in the peak district… Only selling as I’ve bought an ebike.
Will come with a lightly used pair of maxxis minion dhf and dhr2 wt exo tyres too.
Recent lower lube on the forks and a top up of tubeless fluid… A check of brake fluid levels and drive train lube up and fresh grease in the ratchet ring and pawls.
Bad points
1 minor dent to the downtube near the bb from a rock strike which is now covered by a carbon downtube protector but it doesn’t affect the frame in any way.
Various paint scuffs
Some frame grommets are missing where the hoses and cables enter and exit but are cheap enough to buy from whyte.
