Waterproof Trousers
LeightonD
South Wales
HI, can anyone recomend a pair of Waterproof trousers( with enough room for knee pads underneath )cant decide between 3/4 length or full length.
Don't forget "fit terribly and have a saggy crotch" in the MODs list of features ;)
3/4 cycling specific waterproof shorts aren't massively expensive and are actually cut for cycling in rather than trudging about on foot trying to stay hidden in wet fields while carrying gear for killing people.
Get some that actually fit and don't require taking a pair of scissors to.
Try Madison/Altura/Endura etc.
Full length waterproof trousers are harder to find in a good fit (especially with knee pads) so definitely need trying on.
For commuting rather than proper riding I'll happily wear (Cheapish) generic walking waterproof trousers from the likes of Blacks/Millets/Outdoorwearhouse.
Ground Effect stuff is good and I reckon these would go ok as the opening at the bottom of the leg is adjustable - leave it loose with pads and tighten if you're not wearing them and need a closer fit.
Helter Skelters
Tbh I've never had a problem with them as long as you get the right size and not what the QM would issue you with ??
The ones I got issued was a lot better than the old pvc ones I got given back in the day, also desert cam will be kinda better looking than DPM
? True, get the ones without the cutouts to access your pockets and tbh one they get wet and muddy a bit of dpm doesn't really matter ? at less than £20 they're great, I've had a pair for yonks ?
Altura......great fit. So good I use them whenever I need waterproofs whether on the bike or not. My G Form knee pads fit underneath OK. In the winter I use them with Underarmour leggings underneath. Warm and dry. Once I year I wash them in Nikwax which keeps them water proof.
Endura MT500 Spray Baggies, 3/4 length. Worn with knee and shin guards and Sealskinz mid-length waterproof socks.
Endura also do full length.
