2020 weight limits?
EbikeCurious
Does anybody know the weight limits for the 2020 models? The geometry looks better for a large person, but at 114kg, I’m well above the weight limit of the older models.
I just read that my 2017 is similar 120 K total so if bike is 25 it leaves 95 K for rider and gear. I guess 2020 will not change.
And the alu rear triangle version of the Levo is 120+ kg rider weight.
Karsten
Is that 2020 Haibike models or all comers?
2020 Haibike is unfortunately also max 120kg total weight (bike+rider+gear).
The Giant Trance E+ is rated at 132kg total weight. But the XL is just 479mm reach, combined with a very low 611mm Stack, this bike doesn't sound that big.
The 2020 Merida eOne-Forty comes in an XXL frame, only 490mm reach though, 140kg total weight. I was under the impression this was rider weight, but you're right. Upon closer inspection it seems most brands are listing total weight.
Mondraker emtbs have pretty long Reach, over 500mm on the XL, but unfortunately max 120kg total.
Moustache claim 150kg total for the 2019 Samedi. For 2020 there's a size XL available, and I can only assume the weight limit hasn't been changed. Still not a very big bike with its 470mm Reach.
The YT Decoy in size XXL with 495mm Reach is among the bigger bikes, don't know about rider weight limit, you would need to contact them I guess.
