notfub
After every ride do you guys fully charge or charge to 70% (4 lights), then fully charge when you know you are out on a ride?
Thanks Hakki. I can only get out on weekends usually due to work commitments so the battery will be left for 5 to 6 days at a time between rides.No. But i'm riding 4-6 times in week. For long time without ride it would be good to charge up to 70%. I haven't never do that.
Sorry, I can’t agree. The “weekend warrior” pattern that many of us have to adopt is one that can easily kill a battery prematurely if it is fully charged every time. I agree leaving it at full charge only once will do little damage, but doing that week after week means it’s staying at full charge for at least 70% of the time if you charge on Sunday and ride on Sat, ~85% if you charge on Sun and ride next Sunday. Here’s a real world instance of the effect that has...A week isn't an issue. If you're not out for a few weeks then consider leaving it between 50 and 70%.
Loss in battery life - EMTB Forums
The alternative pattern you suggest is far better - check your battery after the ride, and if it is 20% or lower pop it on charge for an hour. On the night before or morning of your next ride pop it back on and charge to full. Simples!
Yep, I agree with all that - to be getting 500-1000 cycles they have to be stopping shy of the 4.2V max at full charge. However, even LiFePO4 cells degrade faster when stored at over 4V/cell, so leaving them at "full" (as defined by the BMS) will still cause more damage in the long run than an indicated 60-70%.It certainly could be this way. I tend to think that out batteries aren't getting 4.2V as a full charge in most cases. So they're not being charged to "100%". This is only based on what I have managed to research very basically myself, as it's hard to find real information from the manufacturers.
On my bike, Shimano quote 1000 cycles. Assuming they're not just making that figure up, it would seem they're working off somewhere between 4V and 4.1V as a full charge from the smart charger, in order to achieve the 1000 cycle figure. That should mean *in general* it's somewhat less damaging to store a bike battery *fully charged* compared to, say, a LiPo pack I use in my commercial drones. Of course it's possible that Shimano are making that figure up as few of us have been able to test that longevity claims yet.
Also our bike are almost certainly using LiFeO4 cells. That's a more stable technology which is a bit better for both safety and cell damage. Not that it can't happen. It's somewhat less likely. SO based on that I tend not to worry if I have my battery fully charged for up to a week, although it tends to be less than this. I also didn't read in the post you quoted that the issue was on a weekly storage basis. It could be that the storage time included longer storage times than 7 days on a regular basis.
