After finding my Leatt protection shorts have saved me from hip impacts at least three times, I figured I wanted another pair. Only thing is I'm not crazy about the Leatt's fit, so I ordered a pair from Alpinestars to try. They have an Independence Day sale going on so I also picked up a jersey and a pair of closeout shorts. I already have the short sleeve version of the jersey and know I'm fond of their mesh fabric. Mesh fabrics make a difference in the heat so I'm always on the lookout for reasonably priced mesh jerseys and shorts.
1650525-12-ba_a-impact-plasma-protection-shorts_4005f4e9-1923-459a-914f-1ca430a47ff0.png.webp
View attachment 188021View attachment 188020
you might want to get a size up in the shorts as well
those protection shorts can add quite a bit to your waist
seem to remember Leatt have quite thin pads
I usually buy size 34 shorts and I always need to tighten the adjustment as much as possible. Figured for $51 I'll take a swing at the 32s since they were the only size available. I don't always run a padded liner anyway.
Circling back to share that the Alpinestars protective shorts fit a lot better than my Leatt equivalents. The hip pads are a much more hi-tech 3DO style, but the hip pads themselves are smaller in diameter, so the better pad covers less area. Considering them a win for fit; and a push for protection.
The 32 shorts fit perfectly. Makes me rethink buying 34s. 🤔
Not really what I bought, but a birthday present for me from a drinking buddy. Apparently he went to great trouble and expense to get EXACTLY this item. He almost had a nervous breakdown to see if his final bid was accepted. All fitted and in pride of place.
I think he was hinting that I was a dinosaur. :eek:
Wow. I’m surprised that sedan has a heavy enough hitch available.
For the BMW i4 M60, the factory-installed retractable tow bar limits your maximum towing capacity to 1,600 kg (approx. 3,500 lbs) for braked trailers, with an unbraked limit of 750 kg. The vertical tongue weight is capped at 75 kg, which safely accommodates most hitch-mounted bike racks and small trailers.
That's why I didn't bother with the 3-bike variant of the Epos. The rack itself weighs quite a bit, so 3x emtbs would end up being almost exactly 100 kg.
(EDIT: Seems like the factory-installed retractable tow bar is not an option for the North American market for some reason)
    Join 43,096
