Fitnord Ranger 800FS error W292 with pedals spinning freely — any fix?
Freewheeling pedals plus an error code almost always point to one thing: the motor has dropped out of assist and disengaged, so you're spinning the cranks with nothing driving the wheel.
The tricky bit — W292 isn't a code I can pin down for the FitNord Ranger 800FS with any confidence, and I'd rather tell you that than invent a meaning. FitNord bikes typically run a Bafang mid-drive, and the exact fault table varies by motor generation, so the safe move is to check the specific cause rather than guess it.
Here's the order I'd work through, cheapest and most likely first:
1. Power cycle it properly. Turn the system fully off, wait 30 seconds, turn it back on. A surprising number of transient "W"-prefixed warnings (as opposed to hard "E" errors) clear on a reboot. If it comes back and stays gone, it was a glitch.
2. Check the speed sensor. The most common cause of a warning code paired with lost assist is the speed sensor magnet on the rear wheel — if the spoke magnet has slipped, rotated, or the sensor's drifted out of alignment, the motor loses its speed reading and cuts drive. Spin the wheel and check the magnet passes close to the sensor on the chainstay (usually 2–5mm gap). Free check, two minutes.
3. Check the battery-to-motor connection. Make sure the battery is fully seated and locked, and the main power cable into the motor isn't loose. Intermittent power will throw a warning and drop assist.
4. Check the crank/spindle is actually driving. "Pedals spinning freely" can mean two different things — either the motor's cut out (electronic, per above) or something mechanical has let go (a stripped crank bolt or a failed freehub). If the chain still turns the rear wheel when you pedal but there's just no power, it's electronic. If the chain isn't moving the wheel at all, that's mechanical and a different job.
That last distinction is the one that tells us which road we're on, so it's worth checking first.
If reboot + sensor + connections don't bring assist back, W292 is a motor-side fault that wants FitNord's dealer diagnostics — internal motor work isn't garage territory and you don't want to be poking around inside a sealed drive unit.
When you pedal, does the rear wheel still get driven at all, or is the chain turning with no drive to the wheel? That'll tell me whether we're chasing electronics or hardware.
the rear wheel does not move
That answers it - no drive at all means we've found the actual fault, and it lines up neatly with the code. W292 on Shimano's STEPS system means the drive unit isn't getting a speed signal from the sensor, and the bike responds by cutting assist.
Given the wheel's completely dead rather than just under-assisted, the most likely culprit is the same sensor issue, gone further:
Speed sensor magnet - check the little magnet on a spoke near the chainstay-mounted sensor. If it's slipped, snapped off, or the wheel's been in for a puncture and gone back in slightly off, the sensor sees nothing at all and the system can lock assist out entirely rather than just reducing it.
Sensor cable - follow the wire from the sensor back to the motor. A pinched or chafed cable (common where it runs near the chainstay/dropout) can drop the signal completely rather than intermittently.
Any recent wheel or tyre work - did you have the wheel out recently for a puncture, tyre swap, or service? That's the classic way a magnet ends up rotated out of range or gone missing altogether.
Worth noting: FitNord badge these bikes with their own branding but this fault code and the response pattern are pure Shimano STEPS behaviour, so I'd treat it as a STEPS-system issue regardless of the FitNord decals.
Have a look at the magnet and sensor gap first - that's a genuinely free two-minute check. If the magnet's present and aligned but you're still getting nothing, it's the sensor or cable itself, and that's a dealer job rather than something to chase further yourself.
the cogset is moving when I back the pedals though
That detail changes the diagnosis, @Bjorn Ivar. Backpedalling on any hub will spin the cassette regardless of health - the freehub is designed to disengage in reverse, so cogset movement there doesn't confirm anything's working.
But combined with "rear wheel doesn't move" when you pedal forward, this now points away from the sensor/motor and towards the freehub itself. If forward pedalling drives the chain and cassette but the hub shell still isn't turning, the pawls or ratchet mechanism inside the freehub aren't catching - a straightforward mechanical failure, not a Shimano STEPS fault at all.
The decisive check: lift the rear wheel off the ground and turn the pedals forward slowly. Watch the wheel itself, not the cassette.
• Wheel spins immediately, tracking the pedal input = freehub's fine, and we're back to looking at the motor/sensor side.
• Cassette and chain turn but the wheel lags or doesn't move at all = freehub's not engaging. Worn or gummed-up pawls, snapped ratchet ring, or a freehub body that's given up.
If it's the freehub, the good news is that's a wheel/hub job rather than internal motor work - a freehub body swap is common and nowhere near as fraught as opening up a drive unit. The W292 code may simply be honest: if the wheel genuinely wasn't turning, the system would correctly report no speed signal, sensor and magnet innocent all along.
I suppose it's the freehub. Sounds right and the wheel does not move when lifted and pedals are engaged forwards. Is this a job I can and should do myself or should I rather get a shop doing it?
A snapped or worn-out freehub is honestly one of the more DIY-friendly jobs on a bike, mechanically it's just: wheel out, cassette off, freehub body swaps out, cassette back on. No motor internals, no torque-critical carbon, nothing scary. If you've done a cassette change before, you've got 80% of the skills already.
Two things that push it toward "get a shop to do it" on your specific bike though:
Warranty. How old is the Ranger 800FS? If it's still inside its warranty period, get it done through your FitNord dealer regardless of how easy the job looks - opening the hub yourself can complicate a warranty claim on what's likely a component failure, not wear and tear.
Parts sourcing. Budget direct-sale bikes like FitNord's often run generic OEM hubs rather than a big-name brand, and that's the actual sticking point - not the spanner work, but finding out whether the freehub body is separately replaceable or whether the whole rear hub needs swapping. I can't confirm what hub is actually laced into the 800FS's wheel from here, so before you commit either way, pull the wheel and have a look at the hub shell/freehub for any stamped brand or model markings. If you can get a photo of that, I can chase down whether it's a serviceable design and what the replacement part actually is.
If it turns out to be a sealed, no-name unit with no available spares, that becomes a "whole wheel" job rather than a "freehub" job - which tips it back toward the shop simply because of parts access, not skill.
    Join 43,137
