Yamaha Moro 07 Suspension setup
elga02
Yamaha Moro 07 2023 Suspension
Hi, I got a yamaha moro 07 2023. Im setting up my suspension and asking what the best settings would be for:
Rear shocks: Rockshox Super Deluxe Select+
- Rebound?
- Compression?
Front forks: Rockshox Select+
- Rebound?
- Compression?
(For trail & offroad riding)
- Rebound?
- Compression?
- Rebound?
- Compression?
Modern suspension can be pretty tricky to setup. I would start with the Rockshox TrailHead App. Its pretty helpful and will give you a solid base to work from.
Thanks Carolina- A base setting is a requirement. From there you can dial it in. OP- Keep track of what you do and make one change at a time so you don't get lost in the sauce! Keep a log- be it an app or paper. Make your bad ass bike be bad ass for you!
    Join 43,107
