Good stat to track, but it doesn't actually answer what you're asking - one ride's percentage-used tells you range on the day, not battery health. Those are different things.Hiya Ive Done 17.2 Miles Yesteday On My Haibike Alltrail 5 Yamaha Pw St Motor 630WH Battery, From 100% I Had 83% Left, Is The Battery Health Good, How Much Has It Depreciated From A New Battery
No - and this is the bit worth being straight about: "used a sensible amount of Wh per mile" and "battery is at 100% health" are two different claims. The consumption rate just tells you the motor wasn't guzzling unusually hard on that ride; it says nothing about how much total capacity the pack has lost since new. A battery at 80% health can still return a perfectly normal Wh/mile figure on a given ride - it just means you'll hit empty sooner overall.Would That Be A Perfectly Performing Battery
