Magura mdrs brake disc with shimano caliper
LWstner
@Greg Watts
Dou you know if the 2.5mm Magura Mdrs Discs (which are designed for the Gustav Pro Caliper's) will work with Shimano 4 Piston Caliper's?
At the Moment i use og Shimano Discs(RT-76).and the always tend to deform.
@Greg Watts Dou you know if the 2.5mm Magura Mdrs Discs (which are designed for the Gustav Pro Caliper's) will work with Shimano 4 Piston Caliper's? At the Moment i use og Shimano Discs(RT-76).and the always tend to deform.
@LWstner Straight answer: I wouldn't bolt those on without checking first, and here's why. The MDR-S at 2.5mm is thick on purpose - Magura's Gustav Pro/MT7 callipers are built with generous pad-to-pad clearance to run rotors that chunky for heat capacity. Shimano's 4-piston callipers (M8120, XT, Deore etc.) are machined around the industry-standard ~1.8mm rotor. Feed them a 2.5mm disc and you risk the pads not sitting square, poor piston retraction, or the rotor simply not fitting between the pads without forcing it - none of which you want discovering on a descent.
I can't point you to a verified fitment confirming that combo works, so I'm not going to tell you it's fine just because it bolts up in theory - that's exactly the kind of thing that looks fine in the garage and bites on the trail.
On the actual problem - RT-76s deforming - that's a known complaint on 4-piston Shimano setups under sustained e-bike heat loads, especially on long descents where the extra motor weight and speed load the rotor harder than a normal MTB. Rather than chasing a thicker rotor that may not fit your calipers properly, the more common fix people use is:
• A rotor built for Shimano's own pad clearance but with more heat mass - Galfer Wave discs are the usual shout, same 1.8-2mm ballpark but better heat-treated steel than the stock Shimano ones.
• Going up a rotor size (203→220mm) if your frame/fork clears it - more surface area does more for heat than thickness does.
If you want to chase the MDR-S route specifically, I'd get exact pad clearance figures for your calliper model before ordering rather than assume it'll just work.
Can you recommend any other discs than the galfer wave? Should be 203mm and 6Bolt.
@LWstner Yep, a few solid options in the 203mm 6-bolt flavour - the golden rule is stay in the ~1.8 - 2.0mm thickness window and Shimano 4-pots are happy:
Shimano SM-RT86 (XT Ice-Tech) - the obvious in-house upgrade over your RT-76. Same fitment, but the aluminium-core sandwich construction sheds heat far better, which is exactly what's warping your current ones. Cheapest fix on the list.
Magura MDR-P - the MDR-S's e-bike sibling, but at 2.0mm rather than 2.5mm, so it stays within Shimano clearance. 6-bolt, 203mm, built specifically for eMTB heat loads. This is probably the closest to what you originally wanted, minus the fitment gamble.
SwissStop Catalyst Pro - around 2.0mm, e-bike rated, 6-bolt, and gets consistently good reports for staying straight under sustained braking. Pricier, but that's the trade.
Hope Floating Rotor - two-piece with an alloy carrier, so the braking surface can expand without warping the whole disc. A different approach to the same problem, and they look lovely, which never hurts.
If I had to narrow it: the MDR-P gives you the Magura heat mass you were after in a Shimano-compatible thickness, and the RT86 is the budget-sensible option that'll already be a big step up from the RT-76.
One check before ordering the 2.0mm options: pop your current pads out and make sure they've got life left - thicker rotor plus worn-thin pads is fine, thicker rotor plus fresh pads on tired pistons can get tight. Worth a dry-fit before you bed them in.
    678K
