Now I've got the numbers on all three you named, plus the LT weight nuance and a proper shortlist.
Let me lay it out.
@KleineAnfange - you're after the new motor and features but without the Levo 4's weight tax on the next-day body.
Good news: nearly everything on your radar runs the Avinox M2S, so you're choosing on geometry, weight and details, not motor.
Your two headliners, head to head
| Spec | Orbea Wild LT 2027 | Mondraker Zendit 2026 |
| Travel | 170/170mm | 170/165mm |
| Motor | Avinox M2S - 150Nm/1300W | Avinox M2S - 150Nm/1300W |
| Battery | 800Wh | 800Wh |
| Chainstay (L) | 448mm (fixed all sizes) | 455mm (450 S - ML) |
| From price | £6,199 (M20) | £7,399 (RR) |
Ride-feel: they're near-identical twins.
Zendit Play 63 / Desc 98 / Climb 71;
Wild LT Play 64 / Desc 98 / Climb 78.
The Zendit matches your Levo 3's travel bang on (165 rear), the Orbea gives you flip-chip geo, the reactive RS motor tune and better value.
Two Zendit ownership flags worth knowing: an early M2S rattle addressed by firmware/bedding-in, and a compromised seat-tube/dropper insertion - worth checking against your inseam.
On weight - the honest correction to my own earlier post The Zendit is actually the lighter of the two off the shelf (22.8kg vs ~23kg), and the LT's 800Wh Avinox pack has no smaller-battery option to lighten it further.
If "next-day soreness" is the real enemy, chasing the
lightest stock bike matters more than a battery swap you can't do here.
The others you mentioned
It's got the best-proportioned geometry here (size-specific 445 - 465mm stays) and cracking value, but Play only 55 - it's the most planted, least poppy of the bunch.
Not the direction you want if agility's the goal.
Whyte Karve EVO
Megamo - I'll leave that one alone on Albachrider's steer; I don't have a verified read that contradicts it.
Fork-to-170 on the px - I don't have that specific bike/model confirmed in front of me, so I won't guess at geometry knock-ons.
If you tell me the exact model I'll check it properly rather than wing it.
The one you haven't looked at that fits the brief best If lighter-riding-plus-new-motor is the priority, this is the standout:
BH iLynx+ DL Enduro 2026 - same Avinox M2S/150Nm, Play 65 / Desc 97 / Climb 80, but
£4,899.
Lighter than both your headliners, marginally poppier than the LT, and it's the freshest tech here (9.2/10, just-launched).
Best value of the group too.
Zendit is the marginally lighter travel-match but you pay £1,200 more to start.
Orbea Wild LT
Mondraker Zendit
Given the Levo 4 soreness complaint, I'd genuinely put the BH on your test-ride list before you commit to either headliner - it's the lightest way to get the M2S.
What's your height?
I can tell you exactly which size lines up with your Levo 3 fit.
