Sorry, I was half asleep when I posted that last night.Just curious, how much do you weigh, who laced up the wheels to begin with and what rims were they laced up to? I’m asking because I’ve had a completely different, (positive) experience with mine. However mine are 27.5 and they’re on stiff enduro layup 40i carbon rims and they were laced up by Berd and I’m 175lbs kitted up.
Ah, that’s too bad that they didn’t workout. Sorry to hear. I think me being lighter and using smaller stiffer wheels probably helps. Also I know that when Berd builds their wheels, they take 3 days because they tighten, let them stretch, then retighten for 3 days until they reach their max stretch and tension. I’m sure Nobel does something similar but I’m not sure. Luckily I haven’t had any of those issues on multiple wheelsets built by Berd. Anyway glad to hear your getting on with your new set.Sorry, I was half asleep when I posted that last night.You’re right—details matter.
I’m riding an MX set of NOBL TR37s with non-flanged Onyx Vesper hubs. NOBL built the wheels themselves and, to their credit, they’ve been great to work with throughout all of this. I’m 215 lbs with all my riding gear on.
A couple things that are probably worth mentioning. First, some people will probably say I should have gone with the TR41s. I actually had TR41s on my Levo and found them a bit too stiff. That said, I also wasn’t riding park or hitting jumps anywhere near as aggressively as I am now. With the steel spokes, the TR37s actually feel really good.
The biggest factor in my experience, though, was reliability rather than ride feel. About 10 miles into my first trail ride, one of the Berd spoke inserts pulled out of the rear hub. NOBL repaired it quickly and sent it back. Then, only about 6 miles into the very next ride at the bike park, another insert pulled out on the same rear wheel, just on a different spoke.
The wheel has since been rebuilt with steel spokes and the updated inserts, and so far it’s been holding up great.
NOBL also sent my original Berd spokes back. If anyone happens to have a compatible MX wheelset and wants to experiment with them, I’d let them go pretty cheap. I’m not sure exactly what spoke lengths they’d fit, though.
This was just my experience. Most people I’ve talked to have had much better luck with the Berd setup than I did.
I would think you can pull it through, but even if you have to drop it, you only need to loosen the rear two bolts and remove the front two. It’s pretty quick and simple. Oh, and the motor cover.Has anyone with the Speed Shop Team Edition removed the One Up Dropper?
I plan on swapping it for a SRAM AXS Wireless Dropper and wondering if I have to drop the motor to allow the wire to be pulled from seat tube?
