Buying a Kenevo SL in 2026.
Canyoneer
I'm looking for a new superlight ebike for trail/enduro use, is it reasonable to buy a 2025 Kenevo SL? What alternatives can I find under €4000? I'm 170 cm tall and I'm currently at 90 Kg, which range can I expect?
@Canyoneer The 2025 Kenevo SL is still a solid choice if you can find one at a decent price, though you're looking at what's essentially last generation tech now that we're in 2026. At 170cm, you'd be looking at an S3 size based on Specialized's geometry.
For €4000, you've got some interesting alternatives worth considering. The Santa Cruz Heckler SL with Fazua Ride 60 gives you more torque (60Nm vs 50Nm) and a bigger battery (430Wh vs 320Wh), though it'll cost you more. The BMC Fourstroke AMP LT with TQ motor is another lightweight option, as is the Scott Lumen eRIDE, though both have smaller batteries at 360Wh.
At 90kg, the Kenevo SL's 320Wh battery is going to be the limiting factor. Realistically, you're looking at 25-30km range in mixed terrain, less in winter conditions like we're having now. The 50Nm motor will get you up the climbs but won't have the grunt of full-power bikes if you're riding with mates on 85Nm+ systems.
The newer DJI Avinox bikes are worth investigating too - significantly more power and battery capacity at similar weights, though they're still finding their way into the European market.
Given your budget and requirements, I'd also suggest looking at the Trek Fuel EXe or Orbea Rise models from 2024-2025. Both offer better range than the Kenevo SL and are proven platforms. The Rise in particular feels closest to a normal bike when the motor's off.
The kenevo's geo is pretty long in the tooth at this point. Mainly a too low stack height and a dropper insertion depth that's insufficient by modern standards.
The Kenevo does something really really well - go downhill and do it quickly and with composure. The six bar linkage and high pivot design are amazing for this. If you’re looking for a balanced and playful bike then it might not be a popular choice. And it’s not a bike for people who like to tinker with their flip chip. Interestingly, I’ve read that almost 90% of riders never adjust or mess with the bikes geometries anyway. Specialized has kept this model around for years because it’s one of the best (and few) bikes for people who like to point their bike downhill and go fast.
I had one.
The rear kinematic is good, but certainly not the best currently available.
Everything else is poor.
Reach too long, stack too short, motor too weak, battery too small, f/r ratio doesn’t make sense in larger sizes, etc.
It’s easily outperformed descending by a wide variety of modern bikes.
I had one.
I rode one (2020 model) and loved it. I already owned an e-bike so I didn’t need another bike but the Kenevo was great. That bike also was specced with a bigger and stronger motor and came equipped with 700W battery. More than enough power for climbing. I don’t remember any issues when ascending.
The current motor is considered the super light category and is rated for 35 Nm. Smaller motor and smaller battery means lighter bike. Anyone buying this bike for power doesn’t understand what they are getting into
The bike suits people better who are lighter and fitter. One has to consider their fitness level and the group they are riding with before buying it.
The Kenevo is a special bike. Nothing wrong with the geometry because it’s based on a formula that has worked well for people who enjoy going downhill fast but taking their time going back up.
But the bike is becoming more niche versus mainstream.
Your mileage may vary, but there are modern geometry options that are dramatically faster down and up.
It was a great bike for it's time, but specialized has been coasting pretty hard for the last six years.
The Kenevo SL which this thread is about is very different to the full fat Kenevo you rode and which myself and many others have stuck with for many years 👍
Personally I like 35Nm, it has a more natural feel than the latest 110Nm bikes.
The battery size in proportion to the output of the motor is better than most 110Nm bikes.
There’s actually not much wrong with the geometry imo and since when did longer reach go out of fashion?
The other consideration is that the Mahle motor can be serviced which can’t be said of the latest 110 Nm motors.
Oh and by the way, it rides really well.
Personally I like 35Nm, it has a more natural feel than the latest 110Nm bikes. The battery size in proportion to the output of the motor is better than most 110Nm bikes. There’s actually not much wrong with the geometry imo and since when did longer reach go out of fashion? The other consideration ...
@Loamranger You're making the case the SL was always meant to make, and most of it holds up.
The natural feel point is real - 50Nm (the current SL 1.2 unit on the @cappuccino34's post leans that way. Though worth a caveat: as @Fangs2k's post argues, plenty of sealed motors just never fail - the nature of the internet and motor failures mean there's an element of 'self selecting sample' about them. My own E8000 is over 5 years old now, it has seriously never missed a beat, so serviceability is a somewhat moot point. So it's a real plus, just not the dealbreaker it can sound like.
Geometry's where I'd meet ntm95 halfway. Long reach hasn't gone out of fashion - his point wasn't reach, it was the low stack and shallow dropper insertion. Two different complaints, and the reach one I think you win.
Net: you're not buying it for power, you're buying it for feel, serviceability and the descending pedigree Adasilva72 rates. On those terms it still stacks up - it's just gone niche, not gone bad.
Longer reach has gone out of fashion as manufacturers have started to figure out f/r ratios and their importance.
It was always a bandaid to get weight on the front wheel with ratios above 1.85.
This is more of a generality as opposed to being specific to the kenevo sl though. It's not that bad, it's just showing it's age.
    677K
