Buying a Kenevo SL in 2026.
Canyoneer
I'm looking for a new superlight ebike for trail/enduro use, is it reasonable to buy a 2025 Kenevo SL? What alternatives can I find under €4000? I'm 170 cm tall and I'm currently at 90 Kg, which range can I expect?
@Canyoneer The 2025 Kenevo SL is still a solid choice if you can find one at a decent price, though you're looking at what's essentially last generation tech now that we're in 2026. At 170cm, you'd be looking at an S3 size based on Specialized's geometry.
For €4000, you've got some interesting alternatives worth considering. The Santa Cruz Heckler SL with Fazua Ride 60 gives you more torque (60Nm vs 50Nm) and a bigger battery (430Wh vs 320Wh), though it'll cost you more. The BMC Fourstroke AMP LT with TQ motor is another lightweight option, as is the Scott Lumen eRIDE, though both have smaller batteries at 360Wh.
At 90kg, the Kenevo SL's 320Wh battery is going to be the limiting factor. Realistically, you're looking at 25-30km range in mixed terrain, less in winter conditions like we're having now. The 50Nm motor will get you up the climbs but won't have the grunt of full-power bikes if you're riding with mates on 85Nm+ systems.
The newer DJI Avinox bikes are worth investigating too - significantly more power and battery capacity at similar weights, though they're still finding their way into the European market.
Given your budget and requirements, I'd also suggest looking at the Trek Fuel EXe or Orbea Rise models from 2024-2025. Both offer better range than the Kenevo SL and are proven platforms. The Rise in particular feels closest to a normal bike when the motor's off.
The kenevo's geo is pretty long in the tooth at this point. Mainly a too low stack height and a dropper insertion depth that's insufficient by modern standards.
The Kenevo does something really really well - go downhill and do it quickly and with composure. The six bar linkage and high pivot design are amazing for this. If you’re looking for a balanced and playful bike then it might not be a popular choice. And it’s not a bike for people who like to tinker with their flip chip. Interestingly, I’ve read that almost 90% of riders never adjust or mess with the bikes geometries anyway. Specialized has kept this model around for years because it’s one of the best (and few) bikes for people who like to point their bike downhill and go fast.
I had one.
The rear kinematic is good, but certainly not the best currently available.
Everything else is poor.
Reach too long, stack too short, motor too weak, battery too small, f/r ratio doesn’t make sense in larger sizes, etc.
It’s easily outperformed descending by a wide variety of modern bikes.
I had one.
I rode one (2020 model) and loved it. I already owned an e-bike so I didn’t need another bike but the Kenevo was great. That bike also was specced with a bigger and stronger motor and came equipped with 700W battery. More than enough power for climbing. I don’t remember any issues when ascending.
The current motor is considered the super light category and is rated for 35 Nm. Smaller motor and smaller battery means lighter bike. Anyone buying this bike for power doesn’t understand what they are getting into
The bike suits people better who are lighter and fitter. One has to consider their fitness level and the group they are riding with before buying it.
The Kenevo is a special bike. Nothing wrong with the geometry because it’s based on a formula that has worked well for people who enjoy going downhill fast but taking their time going back up.
But the bike is becoming more niche versus mainstream.
Your mileage may vary, but there are modern geometry options that are dramatically faster down and up.
It was a great bike for it's time, but specialized has been coasting pretty hard for the last six years.
    677K
