I expect that if battery regeneration is light, reliable, reliable and uncomplicated to maintain it might be the useful in some scenarios. But non of these are likely.
You could have 2 tensioners, one for each direction?the mere presence of chain tensioner disqualifies reverse tension on the belt/chain that is essential to battery regeneration
That would be exactly what you don't want. The point is to have zero-tensioned slack on the chain/belt to drive power transfer. The top half of the chain loop is completely handled by pedal or motor slack take-up (for what little there is) and as long is there's forward momentum, there is zero-tensioned slack. Tensioner up top just wouldn't make sense.You could have 2 tensioners, one for each direction?
That they are rare is an indication that either they have undesirable/suboptimal characteristics or that other designs are better or both. Please elaborate so I can address each issue.there is a reason why there were so little mtbs with concentric pivots and the brands who built them were not successful
most of them were used on slopestyle bikes lately only, because they pedal like shit. and they wont be used on ebikes either because there is no way to mount the chainstayThat they are rare is an indication that either they have undesirable/suboptimal characteristics or that other designs are better or both. Please elaborate so I can address each issue.
Not if they are high-pivot. Elevated chainstays help (like the Mondraker prototype), but is not required for chain. But if using belt, you would need either elevated chainstay, or Horst Link to separate the chainstay from seat stay during installation. For folks with a belt fetish, VPP and DW Link style suspensions will fall out of favor.most of them were used on slopestyle bikes lately only, because they pedal like shit. and they wont be used on ebikes either because there is no way to mount the chainstay
Sethimus may have his own ideas about what made them bad, but from my experience on concentric pivot bikes, the pedal bob was insane, due to the lack of antisquat. This was back in the day, when bike designers/engineers were still figuring out what made a bike pedal well, and some of them latched onto the idea that, because there was no chain growth on the concentric bikes, there could be no loss of energy, because the suspension was unaffected by chain tension.That they are rare is an indication that either they have undesirable/suboptimal characteristics or that other designs are better or both. Please elaborate so I can address each issue.
I guessed you missed my point about High-Pivot. Those bikes your rode were low pivot pretty much at BB Level, and as you say nearly zero anti-squat. Besides this kind of pivot location is pretty much impossible with any mid-motor EMTB.Sethimus may have his own ideas about what made them bad, but from my experience on concentric pivot bikes, the pedal bob was insane, due to the lack of antisquat. This was back in the day, when bike designers/engineers were still figuring out what made a bike pedal well, and some of them latched onto the idea that, because there was no chain growth on the concentric bikes, there could be no loss of energy, because the suspension was unaffected by chain tension.
Early Pole bikes were actually concentric and there were threads on MTBR (you may be able still find them) where Leo from Pole was arguing with people, with him taking the above mentioned stance (although he didn't originate it), and saying that bikes with what would come to be called anti-squat (I don't think the term was yet in common use in regard to bikes, if memory serves) were actually the ones losing energy, because some of the chain tension was being wasted "holding the suspension up" rather than going toward forward propulsion. He also thought that, as long as the movement was basically undamped, no energy would be lost to heat, so he advocated against trying to reduce the movement with increased compression damping. It kind of makes some intuitive sense, from an armchair theory standpoint. What I think he and the other concentric advocates were forgetting was the pulsative nature of a rider's power application, and the need for the rider to have a platform to "push against" especially when pedaling standing or sprinting.
I spent a fair bit of time on a Rotec like in the attached pic, and WOW did it feel terrible when pedaling, even when compared to other bad pedaling downhill bikes of the era, and it cycled deep into the travel with each pedal stroke.
Now having said all of that, on an eMTB, the motor is reducing the pulsative nature of the power application substantially, potentially making concentric more viable. Also, just having the motor makes a bad pedaling bike less of a concern, which is what makes our 50lb bikes with enduro/DH tires tolerable on an XC ride. The lack of anti-squat would still mean it would bob a lot from rider body movement when pedaling, particularly when standing, but, if that proved to still be intolerable, it could potentially be minimized with either some sort of electronic suspension like Flight Attendant or Live Valve, or simply a more sophisticated damping tune (bikes in that Rotec era had nearly no compression damping). You might lose some rear suspension sensitivity as a result, but maybe the improved sprung/unsprung mass ratio from the MGU/MTU would offset that. I'd be willing to give one a try, but without throwing a leg over one, I dunno how all those factors would balance out., vs. the status quo.
now replicate that with a motor, only possible with 2 chains/belts like pivot‘s dh bike…I guessed you missed my point about High-Pivot. Those bikes your rode were low pivot pretty much at BB Level, and as you say nearly zero anti-squat. Besides this kind of pivot location is pretty much impossible with any mid-motor EMTB.
I'm referring to high-pivot concentric pivot suspension like this bike:
You get your anti-squat , with no pedal kickback and no chain tensioner (yah!). And the main pivot is above where the mid-drive MGU would be where there is room. IMO, this is the cleanest suspension design for future ECVT bikes. And you get battery regen too.
A significant portion of the energy you spent going uphill is burned up as heat going downhill. If your terrain is at all steep you're bleeding most of your energy as heat in the brakes, rather than to rolling resistance/wind resistance.Regen is kind of dumb on MTB because are we really slowing down that much downhill to be worth the squeeze on this? Why not just toss on a little alternator so you can recharge on manual mode while you ride not under power? Sure it will take up more room but endless range. I'm mostly kidding here except for the first part.
I'm not sure an electric car recovers more energy from regen proportional to its size than a bike. Yes, there's way more energy available, but it also requires way more energy to accelerate.One of the primary reasons I am a fan of the concept of regen is to take the load off of my sore hands and arms on decents, having said that... there is a bit of a headwind to consider.
The core idea is that regenerative braking recovers kinetic energy, and kinetic energy scales with mass so the heavier the vehicle, the more energy there is available to recover.
The physics: A loaded heavy vehicle carries a lot of kinetic energy at speed, so when it decelerates, a meaningful chunk of energy can be converted back to electricity instead of being wasted as heat in the brakes. That recovered energy is large in absolute terms, and it's also large relative to the vehicle's total energy budget per trip, so it noticeably extends range.
An eMTB and rider together might total somewhere around 90-110 kg, versus a car at 1,500+ kg or an e-cargo bike hauling groceries at 150-200 kg. At comparable speeds, that's an order of magnitude less kinetic energy to recover. On top of that, several other factors stack against regen gains.
Trail riding involves frequent, low-speed, short decelerations rather than the long, high-speed braking events (highway-to-stop, downhill runs) where regen shines. Each regen event on an eMTB recovers a small absolute amount of energy.
There are real losses in the regen path itself / motor and controller conversion inefficiency, plus drivetrain/mechanical losses and those losses eat a fixed-ish percentage regardless of vehicle size, so they take a proportionally bigger bite out of a small recovery event.
Regen on a heavy vehicle is recovering a big fraction of a big number, while regen on an eMTB is recovering a small fraction of a small number, and that small number is also a small fraction of the eMTB's total energy. It's not that regen "doesn't work" on a light bike, it's that the physics of mass scaling combined with how/where the energy actually gets spent (climbing, not cruising) makes the payoff marginal compared to the engineering complexity and added weight/cost of including it.
easy, stop using shit brakes and shit suspensionto take the load off of my sore hands and arms on decents
In sethimus snarky prose: "Read my OP again, but this time read it slowly. "now replicate that with a motor, only possible with 2 chains/belts like pivot‘s dh bike…
plus you get issues with packaging everything as motor spindles are still wider. which means you can just use an idler and be done with it, as the extra resitance will probably be lower than using 2 chains/belts anyways, so what exactly did you gain?
Here is a ECVT patent diagram that I grabbed from @Ndanger on another thread:I guessed you missed my point about High-Pivot. Those bikes your rode were low pivot pretty much at BB Level, and as you say nearly zero anti-squat. Besides this kind of pivot location is pretty much impossible with any mid-motor EMTB.
Yeah, what you're suggesting makes sense to me, in theory. As long as you can achieve an eCVT where the drive sprocket is offset from the rider input, then it doesn't seem too difficult to design a frame around it. For example, these Effigear gearbox bikes used a tensioner free concentric pivot design, offset upward from the crankset: SOC 14: Effigear Calls in the Cavalerie for new Gear Box Bikes in the USHere is a ECVT patent diagram that I grabbed from @Ndanger on another thread:
The pedal axle needs a way to gear into the planetary cluster either by the sun gear or planetary carrier via a spur gear. After that, the final power gear could be be routed anywhere. In this case extra mechanical gearing design is required to get power to the large chainring that is axial to pedal shaft.
I hacked this diagram to illustrate what I'm talking about:
Here the planetary cluster, above the pedal axle can ostensibly drive a final drive shaft directly outboard. It's not a accurate depiction, but you get the idea that the design is simpler and more direct. A design such as this would allow you ditch the large chainring, open up concentric HP to allow regen, and obviate the tensioner. And if that's a bridge too far, then at least you do way with the idler, but still get a HP suspension.
Yes. A devolution/normalization of sorts for all those Rube Goldberg designs out there and suspension IP born from meatbike MTB roots.that means every bike would have the same pivot location
Yes, although vehicles accelerate mildly on flat ground and brake more aggressively in general. The energy toll climbing is huge and requires huge recovery, over-generalizing of course.I'm not sure an electric car recovers more energy from regen proportional to its size than a bike. Yes, there's way more energy available, but it also requires way more energy to accelerate.
