Does the Rogue frameset come with the Avinox 104BCD spider? The Velduro website isn't clear...
Curious why you're looking for a direct mount chainring, the lack of spider would make sense. Are there benefits to direct mount vs 104BCD?
Yes. Comes with spider and chainring and cranks.
Benefits: Aesthetics and weight. And I'm starting with 36T out the gate so changing the chainring anyway.
THIS IS FOR UK AND IRELAND ONLY, for other areas please consult your local dealer.
All "full build Rouge X bikes**" that have landed in the UK and Ireland so far came with 203mm rotors and all "frameset" kits should be fitted with 203mm rotors.
** Regarding Rogue R complete bikes only.
The first delivery of Rogue R full builds to the UK and Ireland on container one came with a 200mm rotor, this was an error. The 200mm rotor should and must be changed to a 203mm rotor which we will supply FoC to our customers in the UK. If you have purchased a Rogue R full build please contact your dealer or us directly through our website and we will arrange to supply you with a 203mm Rotor FoC.
All Rogue frames coming into the UK and Ireland from May 2026 onwards have been updated to accept either 200mm or 203mm rotors (with the correct spacer).
just to confirm the framesets arriving with the M2S in the UK take 203mm rotor, is that with a 3mm shim or is it bolt on rotor 203mm with no shim or adapter?
Does anyone know the function of the red ring? This o ring was in a pocket with my frameset.
For the people running 36t chainrings: what chainlength did you use? Did you stay with 124 or go up to 126?
    676K
