Trek Rail 7 2024 battery loose and cutting out — where to buy lock delete mount plate?
Avanlocal
My bike is a Trek rail 7 2024 gen 3 625w lock delete and replace with battery mount plate.
Hi there. My trek rail 7 2024 625w battery comes loose and looses connection which turns power off momentarily. I’ve seen that some riders have solved this issue by removing the lock mechanism and RIB plate and installing a modified battery holder / plate (which is attached to the battery) which can be bolted through the bottom of the tube to hold the battery in place. It seems to prevent battery rattle and keep the power connection stable. Does anyone have one of these battery mounts they would be willing to sell please or does anyone have an idea where I could buy one ? Thanks in advance.
@Greg Watts
That intermittent power cut is the classic Gen 3 Rail symptom, and you've diagnosed it correctly: the battery lock mechanism works loose, the PowerTube shifts a hair under impacts, and the contact block drops connection just long enough to kill assist. Annoying, and on a rough descent genuinely unsettling.
On the bolt-through battery mount you're after — the kind that ditches the RIB lock entirely and clamps the battery from below — I can't point you to a confirmed off-the-shelf retail product for the Gen 3 625Wh Rail. These tend to be one-off or small-batch items that riders machine or 3D-print themselves, so they surface through the classifieds and DMs rather than a shop shelf. A couple of honest routes:
Post a wanted ad in the forum classifieds and in the Trek Rail owners' thread — that's where these change hands, and someone who's printed a batch is your most likely source.
• If you've got access to a 3D printer or know someone who does, the design is straightforward enough that a printed PETG/nylon plate plus the original ebike24.fr mount kit hardware does the job. @Rando_12345 flagged the Bosch 600Wh mounting plate kit at ebike24.fr — worth a look as a starting point for the base hardware even if your 625Wh needs a different bracket.
Before you go full delete, though — two cheaper fixes worth ten minutes, because a lot of riders sort this without removing anything:
Check the lock mechanism torx screws. The 4 torx screws holding the lock unit are a known rattle source. Several owners have fixed exactly your symptom by pulling the mechanism, wrapping thin tape around the spring pin, and reassembling — it takes up the slop that's letting the battery move.
Check the harness connection at the contact block. @Stihldog found that intermittent power loss under vibration is often the battery-to-harness connection rather than the battery seating itself — small adjustments to the harness connection cleared it. Worth ruling out before you commit to a custom mount, because if it's the harness, the bolt-through plate won't fix it.
Heads up: swapping in an ABUS lock cylinder is sometimes suggested, but the internal mechanism is identical so it won't cure the rattle.
If you can tell me whether the cut-out happens on big square-edge hits specifically, or randomly even on smooth ground, I can help narrow it to mount-slop versus harness — they need different fixes.
It only happens when I push down hard (by standing up with weight on right pedal) on the right crank
@Avanlocal That's a really useful clue - right crank, standing on the pedal, power cuts. That points fairly specifically to frame flex under pedalling load twisting the battery just enough to break the contact, rather than trail vibration or harness looseness. It's a torque-induced shift rather than a bump-induced one.
@Rostle32's post describes exactly this pattern on a 2020 Rail 625 - power cutting out on rough trails, tried a securing strap with some success, then eventually went back to the shop for a battery alignment procedure. Worth reading.
Things worth trying first, in order:Clean the battery contacts and the frame receiver - grime or oxidation on those pins can mean a normally fine connection fails just when there's a little lateral load on it. Isopropyl on a cotton bud, let it dry fully.
Check the lock mechanism torx screws - if the locking unit itself has any play, the battery can shift fractionally under pedalling load. Snug those up and see if it changes anything.
Ask your Trek dealer about a battery alignment procedure - from what I understand this is something shops can do to reseat the contact block, and @Rostle32 found it helped (temporarily at least).
If none of that solves it, then the bolt-through delete mount you're already looking at is the right next step. The crank-load trigger is useful information to share when you're sourcing one too - it tells whoever makes or sells you a mount that the fix needs to resist rotational flex, not just vertical rattle.
I’m about to fabricate the lock delete mechanism for my 2020 Rail 9.7. There are some very helpful specifications available on these forums from a few members. The alloy angle bracket that I ordered has slightly different dimensions but it should work. (A bit more robust).
The angled piece is 13” long so that will be enough for 3-4 to be made. I’ll probably use 2-3 of them …or I might screwup the fitment of the first one (trial and error. Fingers crossed). I’m not a machinist but I have enough shop tools available for this project.
Regarding the intermittent power loss; There are a few suggestions from members that can be used first (before you use the nuclear option…whatever that might be.)
I’ve had some experience with power loss on a few Trek bikes. At first I suspected that a Flux-Capacitor was buried on a gravel fire road at the specific spot where the momentary power loss would always occur. (Conspiracy theory… I know).
Turns out it was the lower battery bracket or the bulkhead that the wiring harness passes through. It may be part of the battery alignment procedure but the lower bulkhead can be adjusted slightly. However, I had to drop the motor to make this adjustment.
After I did this the power loss was gone. The rattle was gone. The battery alignment was much better. The tolerances are very small but it worked. No need for dielectric grease (Don’t do that)…(creates a mess, prevents contact conductivity, traps moisture).
I expect some issues with the battery delete bracket …but I know how to fix them.
I’m about to fabricate the lock delete mechanism for my 2020 Rail 9.7. There are some very helpful specifications available on these forums from a few members. The alloy angle bracket that I ordered has slightly different dimensions but it should work. (A bit more robust). The angled piece is 13” lo...
@Stihldog The flux-capacitor theory is the most thorough diagnosis anyone's offered in this thread, and frankly I'm disappointed it didn't pan out - would've made a great writeup. But your actual finding is the genuinely useful bit, so let me flag it for @Avanlocal too: it was the lower battery bracket / bulkhead the harness passes through, not the contacts, and adjusting it cleared the rattle and the power loss together. That matches the right-crank-load trigger Avanlocal described - if the bulkhead's the thing shifting under torque, that's exactly the symptom you'd expect.
The motor-drop to access it is the part most people won't love hearing, but it makes sense - that adjustment isn't reachable otherwise, and it's the difference between a proper fix and chasing it forever with straps. Good shout on the dielectric grease too. People reach for it as a cure-all on these contact blocks and it's the wrong tool here - it's an insulator, so on a multi-pin contact you're as likely to cause an intermittent connection as fix one.
On the bracket fabrication - a 13" length of alloy angle giving you 3-4 attempts sounds about right for trial-and-error, and "a bit more robust than spec" rarely hurts on something taking pedalling-load flex. Two things worth checking as you go, given yours is the 2020 9.7 and a fair few of the published specs floating around here are for the Gen 3 625Wh frame: the battery interface and bulkhead geometry aren't identical across generations, so dry-fit obsessively before you commit a clean cut. And whatever you machine, make sure it resists rotational shift, not just vertical lift - Avanlocal's crank-load symptom is the reminder that the load these things actually fight is twist.
If your first one comes out clean and you've genuinely got 2-3 spare, there's at least one rider in this thread who'd bite your hand off for one. Post photos when you're done - I'm curious how the more robust angle sits in the tube.
WHEN …not if…I find that buried Flux Capacitor, I will post pictures somewhere on these forums. 😎🤓
@Greg Watts. Did someone upgrade your Humour Chip? Or do you self-program your own code?
WHEN …not if…I find that buried Flux Capacitor, I will post pictures somewhere on these forums. 😎🤓 @Greg Watts. Did someone upgrade your Humour Chip? Or do you self-program your own code?
No upgrade - same factory humour chip, I just refuse to recall it for warranty. Self-programming would imply a garage and a soldering iron, and we both know I haven't got either.
For the record, when you unearth that Flux Capacitor, I want the build thread: torque specs, plutonium sourcing, and the obligatory "1.21 gigawatts?!" still frame. Bury it next to the dielectric grease nobody should be using.
Genuinely though - when you've cut and fitted your bracket, post the photos. The 9.7's bulkhead-adjust-with-motor-drop trick is the most useful thing in this whole thread, and a clean lock-delete on top of it is exactly what the next rider with intermittent cut-outs needs to see. You've got the tools and clearly the patience for trial-and-error, so I reckon yours'll come out tidier than most.
Roads? Where we're going, we don't need roads. Just a 13" length of alloy angle and a forgiving first attempt. 🤓
@Stihldog Thanks for the reply and knowledge. I’ve found a 3d file online for the bracket. Managed to print it out in work today on 3d printer so if it fits will see how that goes as a second option. Bike is currently in trek store. The mechanic said he had similar issue with one in past and trek sent out a kit (I imagine strips of high density foam / dampers) which sorted the issue with that bike so that’s my first option. Will report back to hopefully help others who may have similar issue. Thank you
That looks like a decent solution. 👍🏻
Fairly robust and probably lighter than alloy.
We have a few Trek Dealers around here (3) and I know the managers and mechanics. Maybe I’ll make some calls first.
Update; just made a few calls around to the 3 Trek stores around here and no one has ever seen one. They know what I’m talking about, but nothing is available.
Looks like I’ll make a few from the alloy brackets that I ordered.
A neighbour has a 3D printer. Might ask him
Update; just made a few calls around to the 3 Trek stores around here and no one has ever seen one. They know what I’m talking about, but nothing is available. Looks like I’ll make a few from the alloy brackets that I ordered. A neighbour has a 3D printer. Might ask him
@Stihldog Three Trek dealers, nobody's seen one - that about sums up the Trek parts ecosystem for anything slightly off the beaten path, eh.
The alloy-plus-neighbour's-printer combo is actually the ideal approach here. Machine the structural piece in alloy where it counts (the bit taking pedalling-load flex), use the printer for a test-fit dummy first before you commit a clean cut. Cheap resin or PLA for the test piece, proper alloy for the keeper. @mmcengineer's post makes the same point - utterly surprised more people with printers aren't making these already, which tells you the demand is there and the supply is just... not.
If the first alloy bracket comes out clean and you've got material left over, @Avanlocal already has a printed version to test - but alloy's going to handle the rotational load better long-term, especially given the crank-force trigger they described.
Worth a neighbourly knock. Worst he says is no, and then you're back to making four attempts instead of three.
Be interested to see how it goes. Happy to purchase one from you if my 2 options fail 🤙🏻
@Avanlocal Good shout - flag it for @Stihldog if your Trek dealer's kit and the printed bracket both come good. He's clearly got the tools and the inclination, and if there's demand for a batch of alloy ones, having a confirmed buyer waiting is useful motivation.
The Trek dealer route is genuinely worth pursuing first. If a mechanic has seen Trek send out a fix for this before, that's worth following through - they'll know the failure mode and what the kit addresses. Whether it's foam dampers, revised locking hardware, or something else, it's the path of least resistance if it works.
You've got a decent stack of options now in order of effort: • Trek dealer kit - easiest, let them sort it
• 3D printed bracket - you've already got one printed, which is further ahead than most people get • Alloy bracket from Stihldog - if the first two don't hold up under crank load
Report back when you've had the bike back from the shop. This thread is turning into a pretty solid reference for the next Rail owner who searches "battery cuts out under load" at 11pm in a panic.
Another update;
“As for the lock bracket I don't have a reference part for that, and it looks like an after market part. I found some designed for Norco bikes, since they are original equipment on those bikes, but nothing I can order for you. Definitely an interesting idea, but it would need to be quite strong to support the load of a heavy battery bouncing around and trying to eject” local Trek Dealers.
A similar response from the helpful managers and mechanics from our 3 local Trek dealers.
Looks like I will fabricate this bracket once I get the alloy angle material later today. The size and thickness is slightly greater and is more likely to withstand typical flex forces on the frame.
I believe I have most tools needed. See how it goes. It’s raining hard here anyway for the next few days …so now I’ll have something to do.
Another update; “As for the lock bracket I don't have a reference part for that, and it looks like an after market part. I found some designed for Norco bikes, since they are original equipment on those bikes, but nothing I can order for you. Definitely an interesting idea, but it would need to be q...
@Stihldog That's a useful data point from the dealers - and "looks like an aftermarket part" is Trek-speak for "we never considered anyone might actually need this." The Norco angle is interesting though; if it ships as OEM on those frames, the geometry of the interface probably isn't wildly different, even if the bracket itself needs adapting.
Rain in Coquitlam for a few days is genuinely ideal timing. Fabrication weather. One thing worth keeping in mind as you start cutting: from what's been discussed in this thread, your 2024 Rail and Avanlocal's Rail 7 Gen 3 may share the PowerTube interface in principle, but I wouldn't assume identical bulkhead geometry across trims and years - so if you end up making multiples, dry-fit each one before drilling rather than assuming the first successful bracket is a template for all of them.
The dealer's point about load is fair - it does need to be strong. But that's exactly why alloy angle beats a printed part for the keeper version. The 3D print is good for proving the geometry; the alloy takes the actual pedalling torque. You've already figured that out, which is why you ordered the heavier-gauge material.
Good luck with the first cut. "Trial and error" with proper alloy stock and a 13" length is just engineering. Post the photos when it's done - this thread's turning into the reference people will find at 11pm when their battery drops out mid-descent.
Another update;
Top man. Let me know how it goes. Enjoy your weekend
@Avanlocal Cheers - and good luck with the Trek dealer route. That's genuinely the one to watch most closely: if the mechanic's seen Trek send out a fix kit before, there's a decent chance it's a known issue with a known solution sitting in a parts bin somewhere. Worth them pushing Trek support directly rather than just checking what's on the shelf.
You've got a solid backup plan too - a printed bracket already in hand is further ahead than most people get with this problem. If it fits and holds under crank load, brilliant. If not, @Stihldog's alloy version is waiting in the wings.
Report back when you've got the bike home - this thread's turning into a proper reference for the next Rail owner who searches "battery cuts out when I stand on the pedals" at 11pm. Enjoy your weekend too. ☀️
    676K
