Singletrackmind
Right on!Received tracking on my team build overnight…. Arriving next week️
I have a brand new AXS Extension Cord that's compatible with Shimano EP8 motor.Sram Power Cable… does anyone have one they don’t intend to use? Mine was damaged upon arrival and doesn’t work. Sadly we can’t get a new one as Sram is saying October. Hoping the Crestline community is kind and is willing to help me out. I’m in California.
I'm using a 34.9mm Oaks Components Seat Post Clamp on my Crestline S180. It should be the same size as RS181.2 since they both run a 31.8mm diameter dropper post.
Can you provide info on how much assembly is required. Hoping to do my own. Thanks!View attachment 187103Hot delivery today! Will unbox it tomorrow
This is a forged frame, not a completeCan you provide info on how much assembly is required. Hoping to do my own. Thanks!
Wow! Looks awesome! A lot has changed in 20 yearsFirst mtb in 20 years. Pretty excited for this CSS team edition.
Assembly was super easy for those that are curious. Swapped to a set of carbon 760mm oneup bars / added oneup clip in pedals plus a few other small tweaks.
20 yrs? You're going to shoot your eye out.First mtb in 20 years. Pretty excited for this CSS team edition.
Any pics to share?View attachment 187103Hot delivery today! Will unbox it tomorrow
Have you taken it for a spin yet?First mtb in 20 years. Pretty excited for this CSS team edition.
Partially assembled and cables routed.Can you provide info on how much assembly is required. Hoping to do my own. Thanks!
Yes - spent a couple of hours on it today. Bikes have changed a lot! Very impressiveHave you taken it for a spin yet?
I have one. PM’d you.Anyone not using their SRAM Power Cable to connect an axs derailleur to the motor? I’m looking for one on my 181.2 Plaid
Your cable listed fits the M1 motor connection. The new M2S motors connection is different but thanks for responding.I have one. PM’d you.
155lbs running 400lb now and probably 25-27% at the shock.Anyone 160lbs running a coil? What spring rate are you on?
Dt350For thiose that have received Team bikes, what hub is on the reserve wheels of the delivered team bikes? I'm assuming it might be a DT350, but it's not real clear. Thanks and congrats.
Got frame 1/50!
Didnt come with a guide cable for the axs power plug. Been trying stuff for 3 hours. Probably going to have to give up on that
Hit up a LBS and have them feed a line with a park tool magnetic cable then shrink wrap the magnetic end with the power cable to pull back through. Make sure the magnetic end and cable end are equal diameter to eliminate snagging edges on the pull through. Or give up and send me your power cableGot frame 1/50!
Didnt come with a guide cable for the axs power plug. Been trying stuff for 3 hours. Probably going to have to give up on that cable. Bummer.
Seems like an issue with the head unit, reach out to support at amflow and Crestline. I don't think there is a factory reset we have access to
Yeah I emailed TroydonSeems like an issue with the head unit, reach out to support at amflow and Crestline. I don't think there is a factory reset we have access to
