How are you lot washing your bikes without contaminating your pads and rotors?
Don't you get dust and particles into the drivetrain with waterblasting? I would be careful.
Probably. I just drop a bit of lube on the chain when it gets noisy and easily get around 2000kms out of a chain and 4000 out of sprockets so can't really complain and no point over analyzing it. Rather go ride 😃
Bucket of water with 3 drops of Fairy Liquid - cheap and easy & never had a problem.
Same. Washing up liquid is a great degreaser. Hot water and Fairy Liquid gets your bike shining. I then rinse off with the hose, and wipe down with a towel.
I use foaming chain cleaner on the drivetrain first - work it through the gears etc then get the above washing up liquid all over it.
I pat down the drivechain as much as I can to remove surface water. I'll use GT85 to drive out any other water, but before I do I stuff a rag behind the rear disc brake to protect it from overspray. Has worked for years, I just make sure no disc is visible behind the rag.
Then I relube with Squirt wax gently cycling through the gears.
Contamination is largely overblown - even if you do get some overspray of lube/GT85 a few quick sharp braking moments will heat up the disc enough to burn off anything on the surface.
Never had a contamination promblem from cleaning.
However, I carry my bike on the back of the car on a towbar rack and I used to have road contamination as my tyres are roughly in line with the discs. To stop that happening, I put zip-top plastic bags over them. Just zip up as much as you can and fold the surplus down between the disc and the spokes No other fastening is required, even at high speed. I use the 200mm bags that my wife buys for kitchen stuff, so they are basically cost free! I cut a diagonal slot into one side of the bag down from the top. (You'll soon work it out). I have never had a contamination problem since. The discs have to be facing the back of the car, or the bags will inflate and get blown off. The bags last for hundreds of miles before getting too raggy to use.
As for cleaning, I use the cheapest car wash shampoo/cleaner that I can buy from Halfords (a motor parts place). Five litres is quite cheap and lasts for ages. a couple of good glugs in 10 litres of hot water and I'm good to go. It generates a solid lather. I wet the bike all over with some rainwater from the butt, using a watering can with the rose. For the oily bits I use a bike friendly degreaser from HOPE (yes, that one) diluted 5:1. I deliver it from a hand spray bottle. You can spray the discs and calipers with this stuff, and its safe. Rinse off with the watering can. Wipe down with an old towel. Never had a contamination problem.
I've had tons of bikes in the past with all sorts of different brands of pads and rotors and as I'm always paranoid of pad and rotor contamination I'm super careful to not get anything other than plain water anywhere near them. Even so I've had my fair share of contamination issues in the past which more often than not has led to having to replace the pads and rotors as cleaning and sanding etc has never really worked for me.
I've just bought some new Magura rotors and Galfer pads so would like to know if there are actually any MTB cleaning products out there for cleaning the bike that are genuinely safe around brakes? I have Muc-Off rotor covers already which I put on when washing but they don't completely seal off the rotors so water and whatever else inevitably gets in, and I always wash by hand and a low pressure hose. I see people on YouTube spraying their whole bikes all over including brakes with cleaners from Muc-Off, Hope and Peatys etc but I'm still sceptical that these cleaners don't have any ingredients in that will contaminate the brakes.
Currently during the Summer I put the bike on stand, remove the wheels and pads so I can wash the bike without worrying, then I carefully wash the wheels by hand, let it all dry then put the wheels and pads back on. It's a faff and doesn't really work too well in the winter when the wheels are caked in mud to a point where a low pressure hose just isn't enough so a cleaning product and is required.
Dawn dishwashing soap , warm sudsy water ,, and flower sprinkling setting on the hose.
i just hose mine off if it starts to get heavy, Hose chain and oil when dry, wipe stantions and dropper with a rag , cant say I've ever had any issues with contaminated pads or rotors yet!!
@RipGroove Given that many on this thread have zero problems at best and minimal at worst, then maybe the problem is more connected to you, how you clean your bike, and how you transport it. Is that a possibility? :unsure:
That would usually be a logical assumption yes, but if you knew me and how damn OCD I am about things like that you wouldn't have assumed that 😂 My only guess is maybe the odd rogue airborne spray in my garage maybe while I've been doing something else non MTB related. I've only had contaminated pads once on this particular emtb but I did ride it to work quite a bit last summer (engineering company) and didn't really have a proper safe place to store it away from the workshop areas so maybe again some rogue airborne oil got near it.
Maybe you are over sensitive to it? I don't like noisy brake either and on the odd occasion that I suddenly get brake honking - probably from something off the trail, I just pull the brake on the affected disc until the honking stops. Getting some heat into the pads and disc seems to burn off whatever it was. It does not always work, but it does most of the time. I believe that most people are affected by brake noise at some time or other. No matter how scrupulous you are with your cleaning regime, you probably ride through some proper crap on the trails in the UK. Who knows what you are riding through? You are certain to get some contamination at some time. It is not your fault, just apply the brakes and burn it off.
On more than one occasion/thread I've noted some use "Simple Green" as a cost effective whole-bike cleaner - however I can't speak to if it has any ingredients which could contaminate brakes. Perhaps someone here could speak to that.
I'm in the desert - I usually just hose off and use a cordless leaf blower to get rid of any water - the lack of humidity in the desert quickly takes care of any remaining moisture the blower doesn't get.
Definitely not, talking brake squeals loudly and simply doesn't work, even after riding and spraying with water etc, like permanently. To a point the wheel won't lock at all.
I spray mine liberally with muc off/loam foam and hose it down without any caution towards the brakes, never had an issue with contaminated brakes from washing. Even with degreaser on the drivetrain
The only time I would get contamination is with the bike on tbe back of the car on a rack. Covers sorted thag but I just fit it in the car now to save any potential issue. Especially with all the salt on the roads up here through the winter months.
I wax my chains now, so the risk of lube impacting the rotors or pads is almost zero. I also clean my rotors with isopropyl alcohol wipes after washing the bike (once the rotors are dry). I rough up the pads with 400 grit sandpaper about once a month also.
If you're having issues, perhaps you're putting too much chain lube on and not properly wiping it off?
Also never had any issues with Fenwicks Bike Cleaner Concentrate which is diluted 10:1 with water. Buy it in 5 litre cans.
About once a week, I pop mine on an Enduro Engineering stand and use the shower setting on the garden hose.
Then take it off the stand, bounce it a few times, use a microfiber to wipe off any visible water, ride it up and down the driveway a few times using the brakes and running through the gears.
That's it. I wax my chain so it's always pretty clean, no special care there. Might give it a quick wipe with the same microfiber.
This has worked well for 20 years. If it's been a while and it's extra muddy, I'll spray the whole bike down with a bit of that pink Muc-Off bike cleaner first.
Any soap or degreaser without added "shine", "enhancers" or "waxes" works fine... I've never had issues. I generally use automotive soaps, as their more versatile and less expensive than bike specific cleaners.
Never have gotten contamination from washing (let alone normal use). Generally will use a bit of Dawn in warm soapy water with a brush, don't particularly hit the brakes with it but it certainly would get on both pads/rotor but also gets rinsed off.
You know how they say " bad brakes never stopped anybody " 😤 I am able to have brakes that suck all on my own. Code R new with stock pads made grinding sounds beyond belief. And now I cook pads and rotors on 8120's decending mountain passes to a glaze that have zero braking , with time they come back. Need thicker rotors to help out with the thermal load and about to go 220 mm
Don’t change your pads because of a little contamination. Chuck em in the oven at 200 degrees for 20 mins then give them a light sanding. Clean your rotors regularly with brake and parts cleaner for cars, it’s cheaper than bike versions.
It’s super dusty where I live in Wyoming right now. Dirt goes everywhere.
I have never even thought of such a thing. I wash my bike after every ride as it’s been super dusty here this year. I have found that washing cleans things out and makes the brakes quieter if any change is noticed at all.
Had a hose leak at a caliper over the winter and it dripped onto my rotor. I wiped that off and went riding.
Bottom line - ride fast and take chances, but also, ride more and worry less.
I spray my bike with diluted Dawn dish soap, including the discs and pads. Then I rinse with a hose. I've never had contamination in this process. I've been using this process for over 20 years, with numerous brake, disc and pad combos. The brake swill squeal while they're wet of course, but once dry, they're fine.
I have a video on my playlist showing how I wash my Giant Trance EMTB with only plain water and a chamois: captainchipowen 5184
I had 8120’s. Heavy fade on long descents. Tried all the things. Bit bullet and bought Mavens. I’m very satisfied.
Simple method that works well… first off, wipe the chain clean, keep it clean, lube often, wipe some more. That’s the main component that needs to stay clean. But everyone likes a shiny bike, so…
Put a few ounces of dish soap in a spray bottle. Hose the bike down. Spray the soap liberally trying not to blast foam from the cassette onto the rotors through the wheel. Brush off bike. Hose to rinse (like before, mind blasting dirty water from cassette onto rotors though the rear wheel). Dry with microfiber cloth.
Take care of wax lube and grease build up with a dry cloth. Use the soap to wash away dirt. You’ll be fine!
Also like others said. Take the wheels and pads out for a deep clean if you’re worried.
One more thing. Brake contamination is for sure real and sucks. We’re talking something unavoidable like a leaking piston. But minor contamination from washing or transport usually burns off the first time the brake reaches operating temperature. So not worrying about that and worrying more about brake alignment and bleed quality will get you the best operating brake.
Cheers!
    676K
