Sure, here's the TLDR:Please post the summary here. What is your conclusion?
Southern UK: Last winter used rear High Roller 3's (DD, Maxxgrip) on both my and my wife's bikes (2022 alloy Trek Rails) inflated to 25psi. Worked great in damp/ wet/ muddy/ mucky conditions but absolutely NOT dry weather tyres. Also pretty draggy but that's to be expected.
Paired with front Shortys (DD, Maxxgrip) which work great in the above conditions.
As soon as it dried out a bit replaced the HR3's with Maxxgrip DD DHR2's and Shorty fronts with Maxxgrip EXO+ Assegais.
HR3's stashed in the garage for next winter but if reasonably dry won't bother with them. Oh, did I say they were draggy?
Smooth Sections: On flowy, less technical parts of the trail, the two tires performed almost identically, with only a marginal 0.06-second difference
The key question is why are you not tempted by the WTB Vigilante?Interesting. I would have thought the Assegai might have been slower on the smooth stuff. On the rough stuff, your results are as I would have expected. How does the High Roller recover after it starts to wash out? It's not that I'm going to give up my Assegai, but I'm curious.
Tried to use a Trail Boss on the rear to pair with my Vigilante on front, on hard pack bermed flow trail it would skid with any sort of braking force before slowing bike, unfortunately I am a brake dragger so I had to swap to a Butcher Grid Gravity(27.5x2.6) which will actually slow the bike before sliding. Vigilante works well on front(29x2.6) in the same hard pack situations, but I am old so I tend to load the front with the rear brake rather than weighting the front to get bike to turn. In my mind I am going fast….The key question is why are you not tempted by the WTB Vigilante?
I only mention this because I used to have a Vigilante Trail Boss on the rear of my last bike. It was removed from my grandson's new bike as it was too draggy for him. After several years hanging about in the garage, I gave it a try on my emtb as I was unhappy with the stock rear (Maxxis Aggressor DD). The difference was amazing and I've had one ever since.. Since then I have been tempted to try the Vigilante in favour of the Assegai, but always bottled it at the last minute. I was unaware of @RoJo's work at the time.
I have just changed my bike and the front is an Assegai, so it could be a while before I get to try a Vigilante and Trail Boss combo.
If it's firm I'll stay with DHR2 rears. If it's muddy shite then HR3s. If it's in between and I think the DHR2 won't pack out I'll stay with it.Yeah, maybe just not soft or loose enough where I tested it. It was far from a glorious day starting 6C with a little snow at the side, but still fairly firm underneath. I imagine an Assegai rear would fill with mud during winter, but do you think the HR3 rear is noticeably better than DHR2 rear in this weather?
Maybe the compound of the rubber was the problem, becasue I've never had the Trail Boss skid out, not even on a hard dry trail. Well OK, maybe on the layer of sand on the dry hard trail, but that is slipping sideways not skidding out under pressure.Tried to use a Trail Boss on the rear to pair with my Vigilante on front, on hard pack bermed flow trail it would skid with any sort of braking force before slowing bike, unfortunately I am a brake dragger so I had to swap to a Butcher Grid Gravity(27.5x2.6) which will actually slow the bike before sliding. Vigilante works well on front(29x2.6) in the same hard pack situations, but I am old so I tend to load the front with the rear brake rather than weighting the front to get bike to turn. In my mind I am going fast….
I have a Kenda Hellcat that I bought the on sale for like $30 that I keep hesitating to try out![]()
NGL, I do love the Vigilante 29x2.6 Tough/High Grip. The volume means you can run slightly lower pressure without rim strikes.The key question is why are you not tempted by the WTB Vigilante?
