Bosch vs Bafang: native app reliability vs customization options
Hi, besst software
Right then. "Best software for eBikes" is a bit like asking "best tool for the job" without mentioning what the job is, but I'll have a crack at the main options since your profile suggests you're on a Bafang-powered setup.
BESST Tool is Bafang's own diagnostic and parameter software. The standard version covers most settings on mid-drives like the M510, but if you're on an M820 you'll hit a wall fast - @txemaker worth knowing that the Pro version requires dealer credentials (or a Python bypass, if you're feeling adventurous) for motor parameter tuning.
For Shimano motors, E-Tube Project is the go-to on PC for detailed diagnostics and configuration. eMax miniMax from eMax-Tuning is the third-party option worth knowing about - it can shift the EP801's gear mode from mechanical to electronic (fixes E903), and with a licence you can adjust the speed limiter between 25 - 50km/h and power up to 600W.
For Bosch Smart System, it's the Bosch Flow app for day-to-day use, and OEM diagnostic software for deeper region/speed changes. Which motor are you actually running? That'll narrow it down considerably.
Honestly, "best software for eBikes" is a bit like asking "best software for cars." It depends too much on your bike and what you want from it.
For example, on my Bosch system, I hardly touch the software at all—everything lives in their native app, at most I check the battery level and update it. It's not super flexible, but it works reliably and doesn't break anything.
On the other hand, my friend with his Bafang constantly tinkers with it—there's a whole thread about customizing the motor behavior using third-party utilities. But that's a bit of a hobby, where you can easily make things worse than they were.
If you’re building content or running sessions around comparing setups or teaching this kind of customization, tools like integrate webinargeek can help you package it into webinars so people can actually follow along instead of just reading scattered forum posts.
Honestly, "best software for eBikes" is a bit like asking "best software for cars." It depends too much on your bike and what you want from it. For example, on my Bosch system, I hardly touch the software at all—everything lives in their native app, at most I check the battery level and update it. I...
@Alst1958 - welcome to the forum, and that's a genuinely well-put summary of the landscape.
You've nailed the core split. Bosch's ecosystem is closed-ish by design - the Flow app does what it does, it does it reliably, and for most riders on a Cube Stereo that's honestly fine. Set your assist modes, check your battery, update the firmware, done. No rabbit holes.
The Bafang world is different DNA entirely. Your friend's experience is pretty typical - @pxl666's post in our Bafang M560 thread puts it well: the older UART-based units had loads of community software and cheap USB cable access, but the newer CAN-bus stuff is locked behind the BESST tool which costs proper money and needs an account. So the tinkering has got more expensive and less accessible over time, even for Bafang.
The other axis worth mentioning: what you want software to actually do. There's a difference between: • Diagnostics/servicing - reading error codes, checking motor health (Bosch's dealer tool does this; end users don't need it)
Mode customisation - adjusting assist curves, tuning response (Flow app handles the basics; dealer software goes deeper)
Range management - the Flow app is actually decent here, as @Shark58's post on range estimation explains For a Bosch-equipped Cube, you've already got most of what you need in the app. The only time you'd want more is if you felt the stock mode tuning didn't suit your riding - and even then, a good dealer with the dealer portal can adjust that without you needing to buy any software yourself.
    Join 42,835
