Weight forward
Stevfro99
Huddersfield
Evening people. Been on the ebike for 5 months now. Not done loads of riding but I'm struggling with feeling too much weight forward like I'm over the bars too much, subsequently I've been getting numb hands....any suggestions greatly appreciated
I get the day thing from time to time, especially on a road bike. Posture helps a lot, shoulders rolled back, chest up so your not hunched over forwards.
A few things to look at - make sure the saddle is not tilted down sliding you forward, want to be pretty level or a *tiny* bit up at the front. Also play with saddle position fore/aft.
Try swapping spacers over to under stem if room, shorter stem, slightly higher rise stem (but difficult with very modern stems), rotation of bars can be altered to change sweep or as above maybe a riser with more rise.
What bar width are you running? The wider the bar the further forward your chest will be. Narrowing it slightly is another option alongside the others posted above.
It's a 780. Just been to the LBS this morning for a shorter stem and narrower bars. See if that helps
I started at 780 myself, but at 5ft9 with relatively narrow shoulders I was getting pain in my deltoid muscles on longer rides and that weight forward feeling on very steep sections. Narrowing it 10 or 15 mm eac side (can’t remember how much it was in the end) sorted out both issues.
Bar width should be at the press-up position.
As others have advised, look at raising the bar height, either by moving some stem spacers to below the stem, or by using a riser bar.
    Join 43,266
