Upgrading eMTB Motor to Newer Model: Is It Possible?
Hi all, motor PW-ST I'm on a yamaha.
Welcome to the forum, @ozoj. A Haibike with the PW-ST - solid choice to start your eMTB journey.
The PW-ST is Yamaha's trail-focused motor sitting at 85Nm torque. It's not the most powerful unit in Yamaha's lineup (the newer PW-X4 pushes 100Nm on a 48V system), but it's a well-regarded workhorse. @Pedec ran one to 2,000km and found it reliable, rating it better than the Bosch CX Gen 4. @Sherman described the PW-X3 (which shares a lot of DNA with the PW-ST) as having smooth pedalling with immediate response, fairly quiet in operation and no unwanted clunking.
A few things worth knowing about the PW-ST specifically: the power delivery tends to feel quite natural, which is one of Yamaha's strengths. It's not the most aggressive off the line compared to something like a Bosch CX Gen 5, but it rewards a steady cadence and doesn't feel like it's fighting you. @Hurre noted the PW-X3 can feel like power drops away on steep climbs then comes back just when you think it's given up, which seems to be a characteristic of how Yamaha manages thermal load.
On the practical side, @halbot mentioned that the Yamaha Display A can be swapped for the Interface X display on Raymon PW-ST bikes using the same connector, so if you ever fancy a cleaner cockpit look that's an option. Also worth noting that @offroad found the 36V circuit stays live whenever the battery is installed, so if you're storing the bike for any length of time, pulling the battery is good practice.
Reliability-wise, Yamaha motors have a strong reputation. @mustclime describes the PW-X3 family as bulletproof and rebuildable when they do eventually need attention, which is more than can be said for some competitors. There is one cautionary tale from @kalel whose PW-X3 failed after just two years and under 750km with a €1,850 replacement bill, but that appears to be very much the exception rather than the rule.
Was there something specific about the motor you wanted to know? I've got community data on everything from wiring, noise levels, display options, and ride feel comparisons if you want to dig into any particular area.
Can You Upgrade To Newer Model Motors
@INVISIBLE - short answer: no, not in any practical sense. Here's why. Yamaha don't sell motors as standalone retail units - they supply them to bike manufacturers, not end users. So there's no "upgrade kit" you can just order. Beyond that, there's a deeper problem: the PW-ST and PW-X motors don't share the same mounting points, which means swapping to a newer generation motor like the Yamaha PW-X3 (85Nm, 500W peak) isn't a bolt-on job - your Haibike's frame is designed around the PW-ST specifically.
There's also the display and electronics side of things. The PW display isn't compatible with the PW-X or SE and newer motors, so you'd be replacing the whole system, not just dropping in a new motor.
The realistic options for a PW-ST Haibike if the motor gives up are: • Like-for-like replacement - same motor, sourced via a Haibike-authorised dealer or occasionally second-hand. Expensive but straightforward.
Second-hand PW-ST - eBay and specialist breakers do sometimes have them. Worth watching. • Sell the bike for parts / cut losses - not what anyone wants to hear, but the honest option if the repair cost approaches what the bike's worth.
Given you've been troubleshooting a no-power fault, it's worth getting a definitive diagnosis first before assuming the motor's toast - we've been working through the battery and wiring side of things, and that's still the more likely culprit. A failed motor isn't your only explanation yet.
    670K
