Shenzhen Zhaosheng Carbon CEF52 using Shimano EP801 motor
Finally, it’s completed. It’s a ‘cheap’ build with used or ‘new old’ kit. I Have only been out for a few non technical rides, it rides well, but I have to put quite a bit of effort in to get the best out of it. It’s noisy compared to either of my Bafang motors (M510/M820). It weighs 23 kilos.
How is the battery mount on that frame? Is it just bolts holding it from the bottle cage area like the cef50/cef55 frame?
Im Interested in this build also.
The battery is attached to a bracket which is then bolted to the frame
Another thing to consider, I wanted cables externally routed, but was supplied with an ICR headset, the top bearing did not have a seal fitted on one side of it and there was no seal to go under the top cap assembly, not ideal for wet, gritty and muddy conditions often encounter here in the UK. So ensure you are supplied with the appropriate headset.
Can anyone recommend a ZS56/66 headset that won’t break the bank?
Funn
