Another Bosch Gen 5 range data point for a heavy rider
Jbone5000
My Santa Cruz Bullit C70 XL is sick and range hasn’t been an issue. That’s the only thing I worried about before buying as I’m heavier than average.
I’m 230 lbs with gear and water. I mostly ride fire road up and steep trails down. On a full charge of the internal 600 Wh battery I get at least 1000’ of climbing for each 25% of battery life. My average ride is about 3500’ climbing and I’ll end with around 20% battery life remaining.
I’m using AUTO mode detuned to 70 Nm/600 W for most of the climb unless it’s a relatively flat section and then I’ll use TURBO with settings turned all the way up. I use standard EMTB+ on singletrack.
So at my weight I’m easily getting plenty of elevation for a couple of hours of riding. This is what I really need.
I bought the range extender for longer rides and by my back-of-the-napkin calculations I could get about 5500’ climbing with plenty of juice to get me back down the hill.
I could go on and on about the rest of the bike. Best bike I’ve ever ridden in 30 years of riding. First ebike tho 😈
Oh yes and one caveat, I rode an all singletrack up and down rocky chunk fest one day and the battery burned itself up at a much faster pace. So YMMV!
Also, I spent about $60 to buy an extra 4A smart charger for the range extender. It’s nice to charge both batteries at the same time. 🤓
It is a very efficient motor. I'm an a Gen 4 CX-R and I am 175 lbs bodyweight so in the middle of the range. I do not run it on stock setting usually since I find it too easy and effortless. My main setting (Tour) is not down to 35 nm and -5 Assist. eMTB is stock but I need to probably tune it down like you to 70 and maybe soften the Assist a bit. In my normal riding with let's say 80% on the detuned Tour, I can get 5,000 ft of climbing and still have 20% remaining. If I use eMTB stock tune, I can get 4,000 ft and have 15% remaining.
I do have a range extender but keep it for the really big mountain backcountry rides. If I think I will climb 6K+, I will definitely take it. I need more Assist above 9,000 feet of elevation. Above 10,000 ft, I am needing stock settings on eMTB if I want to keep a normal pace (I do not ride fast). The Bosch Gen5 is a great motor and I'd get it over anything else if I were to upgrade my Gen 4 Pivot Shuttle AM to another full power eMTB.
Wow! You didn't pay much for that extra charger...! They are around $200 in Canada.
    668K
