Shimano BT-E8016 battery fully charged but won't power on Veo Velo — how to fix?
Zarazar
I ride a Veo Velo.
My bt-e8016 buttery is fully loaded but can't start ebike. With another battery everything works fine. How to fix that?
@Greg Watts
Right, classic BT-E8016 sulk. If the bike runs fine on another battery, the motor and wiring are fine — the fault is in the battery or the interface between it and the bike. Work through this in order:
1. Clean the contacts
Pull the battery, inspect the spade terminals in the frame and the corresponding tabs in the battery. Look for corrosion, blackening, or bent/splayed contacts. A drop of contact cleaner and a careful reseat fixes a surprising number of "dead" batteries. @Wookie_73 documented exactly this failure mode on the related E8036 — internal tabs deform, the bike cuts out, and charging behaves oddly: → view post. The 8016 uses the same general arrangement.
2. Check it's actually "fully loaded"
The charge LEDs on the battery report what the BMS thinks is there, not necessarily what's available. If the BMS has tripped into a protection state, the gauge can still show full while the output is disabled. Try a full charge cycle from the charger — if the charger refuses to engage or finishes suspiciously fast, the BMS has latched off.
3. Reset attempt
Take the battery off the charger, leave it out of the bike for 10–15 minutes, then reinsert. Some BMS protection states clear with a cooldown. Worth trying before spending money.
4. Diagnostic at a Shimano dealer
Get it plugged into E-Tube. The diagnostic will read battery cell voltages, cycle count, and any logged errors. This is the only way to know definitively whether it's the BMS, a cell imbalance, or just a contact issue. Costs little to nothing and saves you guessing.
5. The grim option
If E-Tube shows cell imbalance or a tripped BMS that won't reset, you're into battery replacement or a specialist rebuild. The 8016 is an older 504Wh pack, so weigh repair cost against just buying a current battery — though check frame compatibility first, the 8016 isn't a drop-in for every mount.
Most likely culprit: dirty or damaged contacts. It's cheap, common, and explains exactly your symptom — one battery works, the other doesn't, despite both reporting charge.
What bike is it in, and does the display show anything at all when you press the power button with the 8016 fitted — flicker, error code, total silence?
It is a VEO Velo (Swiss brand from Basel) with shimano Ep8 motor and shimano SC6100 display.
The display shows the starting screen for 1 ceconds or two and turns off afterwards again.
It is a VEO Velo (Swiss brand from Basel) with shimano Ep8 motor and shimano SC6100 display. The display shows the starting screen for 1 ceconds or two and turns off afterwards again.
@Zarazar - that symptom is actually very helpful. Display flashing the startup screen then dying within 1-2 seconds is a well-documented EP8 behaviour, and it narrows things down considerably.
That's not a dead battery. That's a BMS shutdown. The BT-E8016 is showing "full" on the LEDs, but the moment the system tries to draw real current to boot, the Battery Management System trips and cuts output. The display gets just enough juice to light up, then - nothing. Classic.
There are two leading culprits: 1. The satellite power switch has a dead internal battery
This is the sneaky one. The Shimano EP8 satellite switch contains its own internal battery, which isn't mentioned in the manuals at all. If the bike is stored for a while, this switch battery drains - and the bike won't power on even with a full main battery.
The switch battery only charges when the bike is powered on, so it can't top itself up from the main battery while the bike is off.
A bike shop can fix this by charging the switch through the PC dongle (SM-PCE02). This is almost certainly your issue if the bike has been sitting for any length of time.
2. BMS protection state / cell imbalance The cells in Shimano batteries are arranged in sets - if the BMS detects one set with a low voltage, it will shut down the battery entirely.
The gauge can still show full while output is disabled. What to do right now:
• Plug the charger into the BT-E8016 while it's still in the bike, then press the power button. Sometimes this wakes a latched BMS. • Take it to a Shimano dealer with an SM-PCE02 dongle -
if the battery is not recognising the drive unit, the dealer can diagnose this and reconnect the charging plug to resolve it, or escalate to a distributor.
• Ask them specifically about charging the satellite switch - they'll know the procedure. Basel gives you decent access to dealers who'll know the EP8 system. I'd go straight there rather than fiddling further - this one needs the diagnostic tool.
Note: if the bike operates normally with a different battery, the BMS shutdown diagnosis above applies specifically to your original battery or its connection/compatibility - the drive unit itself is fine, and the fault is isolated to that battery.
EDIT: Clarified that the BMS shutdown issue is specific to the original battery - if the bike works normally with a different battery, the drive unit is not at fault and the problem lies with the original battery or its connection/compatibility. Thanks @Zarazar for the heads up.
I don't think it is the satellite power switch as the bike runs fine with another battery - right?
@Zarazar - yes, you're absolutely right, and I should have caught that myself. Good spot.
If the bike starts fine on a different battery, the satellite switch has enough charge to power on. So that culprit is off the table. My mistake for raising it as "almost certainly your issue" - that was sloppy.
So we're back to the BT-E8016 itself. The 1-2 second flash then shutdown is the BMS cutting output the moment real current is demanded. The battery looks full but can't sustain the load.
What to do: • Try plugging the charger in while the battery is in the bike, then press the power button. Sometimes this tricks a latched BMS into delivering output again.
• Leave the BT-E8016 off the bike and off the charger for 15 - 20 minutes, then try again. Some protection states clear with time and a temperature drop.
• If neither works - and I suspect they won't - this needs E-Tube diagnostic. A Shimano dealer with the SM-PCE02 dongle can read cell voltages and BMS error logs. That'll tell you definitively whether it's a cell imbalance, a hard BMS latch, or something repairable.
The BT-E8016 is an older pack. If the cells are genuinely imbalanced, repair costs vs. replacement costs are worth having a frank conversation with the dealer about before they start work.
Trata-se de uma VEO Velo (marca suíça de Basileia) com motor Shimano Ep8 e visor Shimano SC6100.
O visor exibe a tela inicial por um ou dois segundos e, em seguida, desliga novamente.
Tempo parada ela entra em hibernação, trave a coroa e gire o motor ao contrário até ela ligar .
    673K
