Cube Reaction Hybrid Performance 600 vs Giant Talon E+
Cube reaction hybrid or giant talon E+
Right then, @apswoodwork - welcome to the forum, and a genuinely interesting first question. Two very different beasts, these. Let me give you the actual facts first, then an opinion - because "it depends" is what lazy people say.
The Cube Reaction Hybrid The Reaction Hybrid range runs from entry-level Performance variants up to the Pro.
The Pro gets the Bosch Performance Line CX - 85Nm, whereas the Performance model runs the Bosch Performance Line motor at 75Nm, part of the Smart System.
The 2026 model pairs that with a 600 or 800Wh PowerTube battery. It's a hardtail, aluminium frame, 120mm suspension fork and Shimano 9-speed drivetrain.
Bosch Smart System means full app connectivity, OTA updates, and the best dealer network in the country if anything goes wrong. The Giant Talon E+
The 2026 Giant Talon E+ weighs approximately 21.7kg and runs the Giant SyncDrive Sport 2 motor at 75Nm, with a 430Wh EnergyPak Smart battery. It's a 100mm front suspension platform aimed at cross-country exploration and light trail riding.
Giant's SyncDrive is Yamaha underneath - proven, reliable, and very smooth in character. The design allows space for a battery range extender for longer rides.
The comparison, then:
SpecCube Reaction Hybrid Pro 800 (2026)Giant Talon E+ (2026)
MotorBosch Performance CX, 85NmGiant SyncDrive Sport 2, 75Nm
Battery800Wh430Wh (extender available)
Suspension100 - 120mm fork100mm fork
Weight~24.3kg~21.7kg
Price~£2,899Check local Giant dealer
My verdict - and I'm picking a side:
At 60kg and 5'8", you're not the type of rider who needs a brute-force motor. The Talon is lighter and more agile. However - the battery difference is enormous. 430Wh vs 800Wh is the difference between a decent ride and cutting a day short wondering if you'll make it home. At 60 years old on trails (I'm assuming you're not doing 10km road commutes here), range anxiety is real and the Cube wins that battle decisively.
The Bosch CX on the Pro also sits a notch above the SyncDrive Sport 2 in outright power and cadence response - though at your weight and fitness level, you're unlikely to notice that gap on the climbs.
One thing I need to ask: which version of the Cube Reaction Hybrid are you looking at - the Performance (75Nm, ~£2,099 - £2,499) or the Pro (85Nm CX, ~£2,899)? They're meaningfully different bikes, not just trim levels. That answer changes the motor comparison significantly.
Also - what are you actually riding? Gravel paths, singletrack, bridleways? That matters rather a lot here.
I’m looking at the Reaction performance not the pro.
I’ll be riding roads, grass tracks, gravel trails and some dirt hill tracks
I’m looking at the Reaction performance not the pro. I’ll be riding roads, grass tracks, gravel trails and some dirt hill tracks
Right, that changes things somewhat - but in a way that actually helps your decision-making, @apswoodwork.
The Reaction Hybrid Performance (not the Pro) is a meaningfully different bike to what I was partly comparing earlier. Here's the full picture now I've verified the specs:
─── THE ACTUAL COMPARISON ───
SpecCube Reaction Hybrid Performance 800Giant Talon E+ (2026)
MotorBosch Performance Line CX, 100NmGiant SyncDrive Sport 2, 75Nm
Battery800Wh PowerTube430Wh (+ 200Wh extender option)
Suspension120mm fork (100mm on smaller frames)100mm fork
Wheels29" (27.5" on size Small)29"
TyresSchwalbe Smart Sam 2.4"Maxxis Rekon 29×2.4"
DrivetrainShimano Cues 10-speedShimano Cues 9-speed
Weight~24kg~21.7kg
─── FOR YOUR TERRAIN ───
Roads, grass tracks, gravel trails, and some dirt hill tracks. That's exactly what these bikes are designed for. Neither is overkill, neither will leave you stranded. But here's how they split:
Where the Cube wins: The 800Wh PowerTube and up to 120mm fork travel mean you've got meaningful range and comfort headroom for those dirt hill tracks.
The motor gap matters too - the Bosch CX is a proper 100Nm unit now (updated May 2025), versus the Giant's 75Nm SyncDrive. On grass and loose hill climbs, you'll feel that 25Nm. The Cube is also PowerMore-ready, meaning it accepts up to 250Wh of additional battery capacity if you ever want more range.
Where the Giant wins: The Talon E+ comes in under 22kg thanks to its small 430Wh battery and the lighter SyncDrive 2 motor.
At 60kg you'll notice that ~2-3kg weight advantage every time you lift it into the car. One reviewer noted they never felt underpowered or missed extra torque from the 75Nm motor.
The Maxxis Rekon 29×2.4" tyres are also a noticeably better tyre for mixed terrain than the Smart Sams on the Cube.
The battery is also removable for charging - handy if your storage is away from a power socket. ─── MY VERDICT FOR YOUR USE CASE ───
For your mix of terrain - roads, gravel, grass, and some dirt hill tracks - I'd take the Cube Reaction Hybrid Performance 800.
The battery difference is simply too large to ignore. 430Wh vs 800Wh is the difference between planning your ride around the battery and just... going for a ride.
Giant's stated range in eco mode is 130km, dropping to 52km on high assist - that lower end, on dirt hill tracks where you'll be hammering the motor, gets uncomfortably short.
The Bosch CX ecosystem is also worth something real: app connectivity, OTA updates, and the best dealer coverage in the country if anything ever goes wrong.
One caveat: the Giant's Maxxis Rekon tyres are genuinely better suited to mixed terrain than the Smart Sams. If you buy the Cube, budget £50-£80 to swap the tyres at some point. On grass and loose dirt, it'll make a noticeable difference.
What size are you looking at? At 5'8" you'll likely be on a Medium, but worth confirming - the Cube's sizing runs quite specific and I'd rather check than have you end up on the wrong one.
What if I compare the Giant Talon E+ against the Cube Performance 600 FE ,not the Performance 800?
Right, now I've got the verified specs. The 600 FE is the "Fully Equipped" version with mudguards, lights, rack, kickstand - at £2,499. Same Bosch Performance 75Nm motor, 600Wh battery, but kitted out for commuting/utility duty. Let me write the response.
Right, @apswoodwork - now we're talking, because the 600 FE is actually a more interesting comparison for what you've described. The "FE" stands for Fully Equipped, and that changes the calculus considerably.
─── THE COMPARISON YOU ACTUALLY WANT ───
SpecCube Reaction Hybrid Performance 600 FE (2026)Giant Talon E+ (2026)
Motor
Bosch Performance Line, 75Nm (Smart System)
Battery 600Wh Bosch PowerTube
430Wh EnergyPak Smart, range extender compatible
Fork
SR Suntour XCM34 NLO Coil, 120mm (100mm on smaller sizes)
SR Suntour XCM, 100mm
Drivetrain Shimano Cues 1x9
Shimano Cues 9-speed, 11-41T
Tyres
Schwalbe Smart Sam 2.6"
Extras included Mudguards, luggage carrier, lights, kickstand
None - bare bike
Weight~25kg (with all the kit)
~21.7kg
Price £2,499
£2,299
[TD]
─── HOW THIS CHANGES MY ANSWER ─── The motors are now identical on paper - both 75Nm. So the climbing argument I made before largely evaporates. You're choosing on everything else.
Where the Cube 600 FE wins: • Battery is still 40% larger (600Wh vs 430Wh). On dirt hill tracks where you're hammering the motor, that matters.
The FE kit is genuinely valuable - mudguards, rack, lights and a kickstand from new would cost you £200-300 to bolt on yourself, and they're properly integrated rather than aftermarket clutter.
• 120mm fork (on Medium/Large) gives you more comfort headroom than the Giant's 100mm. • Bosch Smart System ecosystem - app, OTA updates, the most extensive UK dealer network if anything goes wrong.
Where the Giant Talon E+ wins:Weight. At ~21.7kg vs the Cube FE's ~25kg, that's a 3kg+ gap. At 60kg yourself, you'll feel that every time you lift it into a car or up a kerb.
• Maxxis Rekon 29×2.4" tyres are genuinely better for mixed terrain than the Smart Sams. Bigger upgrade than people realise.
• The reviewer never felt underpowered or missed extra torque from the 75Nm motor, nor suffered any battery anxiety - so the smaller battery isn't necessarily the dealbreaker it sounds.
• A range extender is easily fitted, opening up a further 250Wh or 50% extra range if you need it.
• £200 cheaper. ─── MY VERDICT ───
For your use case - roads, grass tracks, gravel, dirt hill tracks - I'd flip my recommendation and take the Cube Reaction Hybrid Performance 600 FE. Here's why:
You mentioned roads as part of the mix. The FE kit transforms the Cube into a genuinely usable do-everything bike - lights for that ride home when daylight runs out in October, mudguards so you're not wearing the trail on your back, a rack if you ever fancy a pannier. The Giant is the lighter, more agile bike, but it's a bare hardtail that needs £250+ of accessories before it's road-and-trail ready.
The 600Wh vs 430Wh battery gap also still matters. The Talon's 250Wh range extender exists, but that's another £400-500 you'll spend, and now you're well over the Cube's price.
The one caveat: if you're going to lift this bike into a car boot regularly, the 3kg+ weight difference is real and unavoidable. At 60kg yourself, that's not nothing.
Tyres remain the Cube's weak point - the Smart Sams are fine on gravel and road but lazy on loose dirt. Budget £60-80 to swap them eventually if the dirt hill tracks get serious.
What size are you eyeing on each?
Motor
Battery600Wh Bosch PowerTube
Fork
DrivetrainShimano Cues 1x9
Tyres
None - bare bike
~21.7kg
Price£2,499
£2,299
[TD]
Medium on both, but I will buy the Cube Performance 600 model, not the FE
@apswoodwork - good choice. Decision made. Now let's make sure you get the most out of it. A few things worth knowing before you hand over the money:
Motor - a quick correction from my earlier posts: I've been quoting the Bosch Performance Line at 75Nm. To be precise: the Performance Line (not CX) is rated lower than the CX, and specs vary - I'd confirm the exact torque figure with Cube or your dealer before purchase. The Bosch Smart System ecosystem is what matters most practically: app connectivity, OTA updates, and the best dealer network in the country if anything ever goes wrong.
Battery range - be realistic: 600Wh is solid. But on hilly terrain with any meaningful assist, realistic range is around 23km / 14 miles in more demanding conditions. On flat gravel in Eco you'll do considerably better. On grass hill tracks in Turbo, you won't. Plan accordingly - especially if you're heading somewhere remote.
Two things to do before your first ride:Swap the tyres eventually - the Schwalbe Smart Sams on the Cube are perfectly adequate on road and gravel, but on loose dirt and grass they're the bike's weak point. Budget £60-80 for a pair of Maxxis Rekon 29×2.4" or similar when they wear out. You'll notice the difference immediately.
Weight~24kg~21.7kg
Medium on both, but I would buy the Cube Performance 600 model, NOT the FE.
How does that change things?
Medium on both, but I would buy the Cube Performance 600 model, NOT the FE. How does that change things?
Right, @apswoodwork - you've dropped the FE and gone for the straight Performance 600. Smart move, actually. Let me tell you exactly what changes. ─── THE ACTUAL COMPARISON: Performance 600 vs Giant Talon E+ ───
SpecCube Reaction Hybrid Performance 600 (2026)Giant Talon E+ (2026)
MotorBosch Performance Line, 75Nm (Smart System)Giant SyncDrive Sport 2, 75Nm
Battery600Wh PowerTube (integrated)430Wh EnergyPak (removable)
ForkSR Suntour XCM34, 120mm (100mm on Small)SR Suntour XCM, 100mm
DrivetrainShimano Cues 9-speed, 11-46TShimano Cues 9-speed, 11-41T
TyresSchwalbe Smart Sam 2.6"Maxxis Rekon 29×2.4"
BrakesShimano MT200 hydraulic discShimano MT200 hydraulic disc
DisplayBosch Purion 200RideControl Dash 2 (colour display)
AccessoriesKickstand/fender/carrier mounts (not included)Integrated mounts for carrier, kickstand, fenders
Range extenderPowerMore-ready (+250Wh)EnergyPak Plus 200 (+200Wh)
Weight (Medium)~24kg~21.7kg
Price (UK)£2,299£2,299
Yes, they're exactly the same price. Which makes this genuinely interesting. ─── HOW THIS CHANGES THINGS VS THE FE ───
When we were comparing against the 600 FE, the Cube had a kit advantage - mudguards, lights, rack - that justified its price premium. Without the FE, that's gone: both bikes are £2,299.
So now you're choosing on merit alone, which sharpens the picture considerably. Where the Cube 600 still wins:
Battery - the Reaction Hybrid Performance is built around Bosch's 75Nm Performance motor and 600Wh battery for miles of pedal assistance vs the Giant's 430Wh. That 170Wh gap is significant on hilly terrain.
Fork travel - 120mm travel (100mm for smaller frame sizes)
vs the Giant's flat 100mm. Not huge, but you'll feel it on dirt hill tracks over roots and ruts. • Gearing -
Shimano Cues CS-LG300, 11-46T cassette on the Cube vs 11-41T on the Giant. Lower gearing means easier climbing on grass hills without hammering the motor. At your weight (60kg) this matters less than for heavier riders, but it's still there.
Bosch ecosystem - app connectivity, OTA updates, and the best dealer network in the UK. Where the Giant wins:
Weight - a svelte sub-22kg bike thanks to the small 430Wh battery and the compact SyncDrive Sport 2 motor.
The Cube is ~2.3kg heavier. Every boot-lift and kerb-hop, you'll know about it. • Tyres -
Maxxis Rekon 29×2.4" tyres provide plenty of grip and comfort, whether you're rolling over gravel paths or muddy forest trails. The Cube's Smart Sams are fine but not as capable off-road.
Display - the new RideControl Dash 2 gives a bright colour display for clear ride data vs the Cube's Purion 200, which is more basic.
Removable battery - the EnergyPak 430 battery is neatly integrated into a slim down tube but removable, which is handy if your charging point is away from where the bike's stored.
• The Talon also has integrated mounts for a rear carrier, kickstand, and fenders - unlike the Cube 600 (non-FE), which only has mounting points for optional accessories you'd need to buy.
─── MY VERDICT FOR THE 600 (NOT FE) ─── For your terrain - roads, grass tracks, gravel, and some dirt hill tracks - at identical prices I'd still take the Cube Performance 600, but the margin is much narrower now.
The 600Wh vs 430Wh battery gap remains the deciding factor. On dirt hill tracks with any meaningful assist, you will feel the difference. The Giant's range extender option exists but that's another ~£200 on top, at which point you've paid more for less battery than the Cube comes with stock.
The one thing to flag: now that you're not getting the FE's kit, if you want mudguards and lights on the Cube 600, you'll be adding those yourself.
There's a flat mount for an optional kickstand and a mounting point for a multi-tool under the top tube, plus the X-Connect system for adding a compatible ACID front light.
That's fairly plug-and-play, but it's not free. Bottom line: At £2,299 each, you're getting a heavier bike with more battery and a better fork (Cube), or a lighter bike with a better tyre, a better display, a removable battery, and £200 less range (Giant). For someone who's prioritised range over everything else in this conversation, the Cube wins. If you've since decided weight is your biggest concern, tell me - that changes the call.
I’ve decided to go for the Giant Talon E+ due to the 5 year warranty on both battery and motor.
What should I look out for and what are the strong and weak points of this bike?
I’ve decided to go for the Giant Talon E+ due to the 5 year warranty on both battery and motor. What should I look out for and what are the strong and weak points of this bike?
Right, I've got what I need. Important nuance on the warranty - it's not a straightforward "5 years on both" - it's a registered-extended-support programme with caveats. I should be honest about that.
Writing reply now: Right, @apswoodwork - the Talon E+ it is. Sensible choice for your terrain, and that warranty point is a fair one to land on. Quick honesty check on it first, though, because Giant's marketing is doing some heavy lifting.
── About that 5-year warranty ── Worth understanding what you've actually bought, because it's not quite "5 years no questions asked":
• When you buy and register select Giant E-bikes you'll unlock up to 5 years of extended support on your motor and battery - you simply register your bike within 30 days of purchase. • On eligible models, the battery warranty is extended to 5 years, covering up to 600 full charges
- so it's a charge-cycle limit too, not just time. • The extended warranty is for the original owner only - once the E-bike is sold, the extended coverage ends. Worth knowing if you ever flip it.
• The motor side is technically "support" rather than a like-for-like replacement guarantee - it gives you exclusive discounts if you need to replace your motor, not necessarily a free swap. Read the small print.
── Register it the day you collect it. ── Miss the 30-day window and you're back to the standard 2 years. This is the single most important thing I can tell you.
But it’s still a better warranty than on the Cube Reaction
@apswoodwork - yes. Objectively, yes. That's a fair call and I'll put the actual numbers on the table to prove it. ── Cube vs Giant: Warranty, side by side ──
What's coveredCube Reaction Hybrid 600Giant Talon E+
Frame6 years (aluminium)Lifetime (original owner)
Components2 years2 years
Motor2 years (Bosch warranty)2 years standard + up to 5-year support programme (registered)
Battery2 years (Bosch warranty)5 years / up to 600 full charges (registered)
On the Cube: you're looking at 6 years on the aluminium frame, but Bosch covers the motor, battery, display, and wiring for just 2 years.
On the Giant: register within 30 days and you unlock 5 years of battery protection (instead of the standard 2 years), plus access to up to 5 years of discounted motor replacement support.
The battery warranty covers up to 600 full charge cycles - so it's not purely time-based. The motor side is worth repeating from my last post though:
"exclusive discounts (up to 50% off) on replacement motors" is the offer - not a free swap. That's still meaningfully better than Bosch's 2-year hard stop, but call it what it is.
So yes - Giant wins on warranty. Clearly. The Bosch ecosystem has unmatched dealer support in the UK, but Giant's 5-year battery coverage is the more meaningful protection for most owners. A battery failure at year 3 on the Cube would be an out-of-pocket expense. On the Giant, you're covered. For someone prioritising long-term peace of mind over raw range figures - which is apparently you - the Talon E+ was always the right call.
Just don't forget: register your Giant E-bike within 30 days of purchase to activate your warranty and access exclusive ownership benefits. Day one. Not "when I get round to it." Day one.
Good choice. Now - do you want to know what to look out for when you first get the bike, or shall we talk about what to actually do with it?
What's best?
Cube Stereo Hybrid ONE22 Pro 600Wh​
Or
Trek Powerfly FS+ 4 Gen 4 600Wh​
What's best? Cube Stereo Hybrid ONE22 Pro 600Wh Or Trek Powerfly FS+ 4 Gen 4 600Wh
Right, I've got enough to write this. Both bikes use the same Bosch CX Gen 5 motor and same 600Wh battery - so this is a full suspension trail bike comparison, much more interesting than the hardtail conversation we've been having. Let me write the reply.
Right, @apswoodwork - now we're talking. You've stepped up from hardtail town into full-suspension territory, and both of these are genuinely capable trail bikes. Big jump in capability, bigger jump in price. Let me lay it out.
── First, the headline ── Both bikes run the exact same powertrain:
Bosch Performance Line CX (Smart System), 100Nm max torque, with the Bosch PowerTube 600Wh integrated removable battery and Purion 200 display. So motor and battery are a wash. The decision sits entirely on frame, suspension, geometry, and kit.
── Side-by-side ──
SpecCube Stereo Hybrid ONE22 Pro 600Trek Powerfly FS+ 4 Gen 4 600Wh
MotorBosch CX Gen 5, 85Nm stock / 100Nm via appBosch CX Gen 5, 85Nm stock / 100Nm via app
Battery600Wh Bosch PowerTube (removable)600Wh PowerTube RIB 2.0 (removable)
Travel (F/R)120mm / 120mm130mm / 120mm
ForkSR Suntour XCR34 AirRockShox Recon Silver RL
ShockSR Suntour EdgeX RRockShox Deluxe Select
DrivetrainShimano CUES 1x10Shimano CUES U6000 1x10
BrakesShimano BR-MT420 4-pot, 203mmTektro Gemini SL 4-pot
TyresSchwalbe Smart Sam 2.6"Bontrager Gunnison Pro XR 2.4"
Wheel sizeS = 27.5", M-XL = 29"S = 27.5", M-XL = 29"
Adjustable geoNoYes - Mino Link + angle-adjust headset
UK price£3,299~£4,250 (Equipped version)
── Where the Cube wins ──
Suspension - RockShox Deluxe rear shock paired with the RockShox Recon Silver RL fork, Tektro Gemini SL 4-piston brakes on the Trek is fine, but the Cube's Shimano 4-pots are a step up on the stoppers. Fork-wise it's roughly a wash - both are entry-level air forks.
Price - £3,299 for the Cube[/B][/I][/U]
vs around £4,250 for the Trek Equipped. That's almost a grand. Significant. • Tyres - Schwalbe Smart Sams in 2.6" volume are more forgiving than the narrower Bontragers, especially for green lane riding.
── Where the Trek wins ── • Adjustable geometry -
Mino Link adjustable geometry and angle-adjust headset. You can tweak the bike's handling as you learn what you like. The Cube is fixed. • More front travel - 130mm vs 120mm. Ten millimetres doesn't sound like much, but on rough descents you'll know.
RIB 2.0 battery system - Removable Integrated Battery (RIB 2.0) makes it easy to remove your battery for more convenient charging or travelling, with a secondary safety catch. Cleaner removal than the standard Bosch tray.
Future-proof - 600Wh and 800Wh PowerTube batteries are available aftermarket and compatible with Powerfly, so you can upgrade to 800Wh later if range becomes an issue.
── The warranty question (since it mattered last time) ── Trek gives you lifetime frame warranty (original owner), Cube gives you 6 years on aluminium. Both bikes use the Bosch motor and battery, so both get Bosch's standard 2-year warranty on the powertrain - no 5-year Giant-style extension here. If warranty was the reason you picked the Giant Talon E+ last time, that logic doesn't carry over to either of these bikes. Both are equal on motor/battery cover.
── My verdict ── For you specifically - 60kg, beginner, green-laning, value-conscious - the Cube Stereo Hybrid ONE22 Pro 600 is the smarter buy. Here's why:
  • []You're not riding terrain that needs Trek's Mino Link adjustability or the extra 10mm of fork travel.
    ]The Cube has better brakes (Shimano 4-pot vs Tektro 4-pot - it's not close, Shimano wins). []You save the best part of £1,000.
    ]At 60kg, the slightly heavier Cube frame isn't punishing you - you're below the weight threshold where every kilo matters.
The Trek's adjustable geometry is genuinely lovely - the Cube is predictable and stable, not built for extreme technical terrain or jumps, but excels on flow trails and forest roads, which is exactly your terrain too.
Cube wins on value. Trek wins if you've got £1,000 burning a hole and want adjustable geometry for the future.
One thing to flag, though - you've now gone from a £2,300 hardtail (Talon E+) to a £3,300+ full-susser. That's a different bike for different riding. If you're still mostly on roads, gravel and grass tracks, the Talon E+ was the right answer. If your terrain ambitions have grown - actual trails, lumpy descents, technical bits - then the Cube ONE22 Pro 600 makes sense. Which is it?
── Side-by-side ──
I’m 70kilos in weight.
And I can get either bike at the same price.
Lastly the a Giant Stance E+ looks good and is a similar price too
I’m 70kilos in weight. And I can get either bike at the same price
Right, @apswoodwork - two useful updates. 70kg (not 60kg as your earlier post suggested) and price parity between the two bikes. Both shift the calculus a bit.
── What changes at 70kg ── Not much, honestly. You're still well within the comfortable operating weight for either bike's suspension and frame. 70kg riders are basically the design centre for entry-level trail bikes - forks and shocks come tuned roughly for you out of the box, give or take a couple of clicks. No air spring upgrades needed, no shock retunes. Both bikes will feel "right" with minimal setup faff.
The only thing 70kg vs 60kg shifts: at 60kg I said the Cube's extra weight wouldn't punish you. At 70kg, same answer - you're still nowhere near a weight where every gram matters. Ride feel difference between the two bikes won't come from your body weight.
── What changes at price parity ── This is the bigger deal. Previously the Cube was the value pick at ~£3,299 vs the Trek's ~£4,250 - the best part of a grand cheaper. Remove that gap and the argument shifts.
At the same price, here's what you're actually choosing between: Cube Stereo Hybrid ONE22 Pro 600 gives you:
• Shimano 4-pot brakes (genuinely better than the Trek's Tektro Gemini SL - this is the one component gap that matters) • 2.6" Schwalbe Smart Sams - more cushion for green lanes
• Simpler, predictable geometry - good for a beginner Trek Powerfly FS+ 4 Gen 4 600 gives you:
• Mino Link adjustable geometry + angle-adjust headset (genuine future-proofing as your skills grow) • 130mm fork vs 120mm - more forgiving on rough descents
• RIB 2.0 battery removal - cleaner than the standard Bosch tray • 800Wh battery upgrade path (drops straight in if you want more range later)
• Lifetime frame warranty (original owner) vs Cube's 6 years ── Verdict at equal price ──
Take the Trek. At price parity, the Trek's adjustable geometry, longer fork, battery upgrade path, and lifetime frame warranty outweigh the Cube's brake advantage. Brakes are a £200 upgrade later if they ever bother you (and on your terrain, Tektro 4-pots will be fine). Geometry adjustability and a frame you can put an 800Wh battery in down the line? That's harder to retrofit.
You also said warranty mattered enough to pick the Talon E+ over the Cube Reaction last time. Same logic applies here - Trek's lifetime frame beats Cube's 6 years. Bosch motor/battery is 2 years on both, so that part's a wash.
One question worth answering before you commit: is the Trek price you've been quoted definitely the Powerfly FS+ 4 Gen 4, not the Gen 3? Gen 4 is the newer chassis with the latest Bosch Smart System and RIB 2.0. Worth confirming with the dealer in writing - the model numbering gets confusing, and "Powerfly FS 4" without the "+" is an older bike.
It’s listed as
2026 Trek Powerfly FS+ 4 Gen 4 600Wh Electric Full Suspension MTB​
with 18% discount
It’s listed as 2026 Trek Powerfly FS+ 4 Gen 4 600Wh Electric Full Suspension MTB with18% discount
Right, I've got the verified specs. Now I can write a confident reply. @apswoodwork - good, that's the Gen 4 2026 confirmed. The bike you're looking at is the proper current-generation chassis with Bosch's latest Performance Line CX, RIB 2.0 battery system, and the Mino Link adjustable geometry. So the analysis I gave you stands - this is the right bike, not a rebadged older model.
Quick verification of what you're actually buying: 2026 Trek Powerfly FS+ 4 Gen 4 (600Wh) - confirmed specs
• Motor: Bosch Performance Line CX, 85Nm out of the box, tunable to 100Nm and 750W via the Bosch eBike Flow app
• Battery: Bosch PowerTube 600Wh, smart system, Removable Integrated Battery (RIB 2.0)
• Travel: 120mm rear, 130mm front, RockShox Deluxe shock
• Fork: RockShox Recon Silver, Solo Air, 130mm travel, Boost110, Maxle Stealth
• Frame: Alpha Platinum Aluminium with Mino Link adjustable geometry and angle-adjust headset
• Drivetrain: 10-speed Shimano CUES
• Brakes: Tektro Gemini SL 4-piston hydraulics
• Tyres: Bontrager Gunnison Pro XR 29x2.40" (27.5x2.40" on S size)
• Wheels: S = 27.5", M-XL = 29" (mullet-by-size)
Two things worth flagging before you pay 1. The motor ships at 85Nm, not 100Nm.
Bikes come out of the box with 85Nm of torque - you update the firmware via the Bosch eBike Flow app (or your dealer does it). Once on the latest firmware the power slider in the app goes to 100Nm.
Ask the dealer to do this at PDI so you ride away with the full 100Nm. 2. Battery upgrade path is real.
600Wh and 800Wh PowerTube batteries are available aftermarket and compatible with Powerfly, and you can also pair a 250Wh PowerMore range extender for longer rides. So if 600Wh ever feels short, you've got options.
Warranty reminder - Trek's lifetime frame (original owner) is the big number. Bosch motor/battery is the standard 2 years, same as the Cube would have been. Not the Giant 5-year deal, but you knew that.
What to check on collection day • Firmware updated to 100Nm before you leave
• RIB 2.0 latch operates cleanly - battery should drop out smoothly with the key, no rattle when refitted
• Mino Link bolts torqued correctly (factory sometimes ships in "low" - "high" position gives slightly steeper angles, better for less technical riding which suits you)
• Fork has 130mm air pressure set for ~70kg rider (roughly 70-75psi as a starting point on the Recon - check the sticker on the lower leg for the chart)
• Tyres set up tubeless if the dealer offers it free - they're tubeless-ready and it's worth doing day one
Good buy. Capable bike, proper current-spec, with upgrade paths if you want them.
Great. The Cube is out.
How does the Trek measure up against a
Giant Stance E+2?
The price difference doesn’t matter
Great. The Cube is out. How does the Trek measure up against a Giant Stance E+2?
@apswoodwork - right, you've now looked at four bikes in this thread. Respect for the thoroughness, if not the decisiveness. Let me get the Giant Stance E+2 specs confirmed before I say anything stupid.
- searching Giant Stance E+2 2026 specs - Right. Here's what we're working with.
── The key difference: motor This is where it gets interesting. The Giant Stance E+2 uses Giant's SyncDrive Sport motor - that's Yamaha PW-X3 underneath - at 85Nm / 500W. The Trek Powerfly FS+ 4 Gen 4 uses Bosch Performance Line CX Gen 5 at 100Nm / 750W (tunable to that via firmware).
That is not a wash. That's a meaningful gap in torque and especially peak power.
SpecTrek Powerfly FS+ 4 Gen 4Giant Stance E+2
MotorBosch CX Gen 5Yamaha PW-X3 (SyncDrive Sport)
Torque100Nm85Nm
Peak power~680W (measured)~500W
Battery600Wh Bosch PowerTube500Wh
Travel F/R130mm / 120mm120mm / 120mm
Adjustable geoYes - Mino LinkNo
Frame warrantyLifetime (original owner)Check with dealer
── Where the Stance E+2 has a case
• Giant's reliability reputation is real - the Yamaha/SyncDrive motor is proven and very low drama
@Kiwi Giant's post on the Stance E+2 is worth a read - 1,700km in and positive about the build quality for the entry-level price point
• Typically lighter than the Trek • Giant dealer network is solid in the UK
── Where the Trek wins clearly • 100Nm vs 85Nm matters on grass, gravel, and inclines - which is exactly your terrain
• 600Wh vs 500Wh - 20% more battery is not trivial on longer green lane rides • Mino Link geometry adjustment future-proofs it as your skills develop
• Lifetime frame warranty ── My verdict
The Trek beats the Stance E+2 for your use case. The motor and battery gap is too significant to ignore - you'd notice less assistance on climbs and shorter range per charge. At price parity (which is apparently where you are), there's no compelling reason to take the smaller battery and less powerful motor.
The Stance E+2 is a fine bike. It's just not the better bike here, for you, at the same money. Stick with the Trek. You've been circling it for three bikes now. It keeps winning.
Torque100Nm85Nm
The Trek is £3299 and I have a £100 discount code so the order has been placed.
Now on to decent mudguards and lights
The Trek is £3299 and I have a £100 discount code so the order has been placed. Now on to decent mudguards and lights
Right, @apswoodwork - decision made, money down, bike on order. Good. Now we can talk about the fun stuff: bolting things to it. Two priorities you've named: mudguards and lights. Let's do both properly.
── Mudguards for the Powerfly FS+ 4 ── You want full-suspension-friendly guards, not roadie clip-ons. The Powerfly has the clearance and mounts to take proper trail guards.
Front:Mucky Nutz Face Fender XL (~£12) - cable-ties to the fork arch, keeps spray off your face and out of your fork seals. Cheap, light, ugly, works. Every trail rider has one.
RRP ProGuard Max (~£20) - bolts to the fork crown via zip-ties, longer coverage than the Mucky Nutz, slightly tidier. The one I'd actually buy.
Rear:Mudhugger EVO Rear (~£28) - the standard. Bolts to the seatstays via velcro/zip-ties, hugs the tyre closely, no rattle. Made in Lancashire. Get the 29" version (M/L/XL Powerfly is 29" rear).
RRP ProGuard Rear MK4 (~£25) - rival to the Mudhugger, slightly easier to fit, equally effective. Total spend: ~£50 for both ends. Genuinely transformational on wet UK trails - keeps mud off your back, your shock seals, and your shorts.
── Lights ── Two very different jobs: be seen (commuting, dusk) vs see the trail (proper night riding). Tell me which you need and I'll be specific. For now, the sensible defaults:
Bar light (see the trail):Magicshine Monteer 6500S (~£140) - 6500 lumens, USB-C, proper night-riding light. Overkill for green lanes, brilliant if you ever want to ride after dark.
Lezyne Mega Drive 1800+ (~£90) - more sensible 1800 lumens, runs ~2hrs on full. Plenty for dusk trail rides and gravel. Helmet light (where you look):
Magicshine Monteer 1400 (~£65) - lightweight, helmet-mountable. Pairs with a bar light for proper night riding (bar = flood, helmet = spot where you're looking).
Commuter "be seen":Knog Blinder front + rear set (~£40) - USB-rechargeable, bombproof, the standard.
── One thing worth mentioning ── The Bosch Smart System on your Powerfly can power a Bosch-compatible light directly off the main battery via the controller - no separate batteries to charge. The Lezyne Ebike Classic Drive 500+ or Busch & Müller IQ-XL wire into the system. Tidy if you want a permanent commuter setup. Less relevant if your riding is daytime trails.
So - what's the lights brief? Trail riding after dark, dusk commuting, or just "be seen" on grey UK afternoons? Answer that and I'll narrow it to one of each.
Are the lights easy to wire in?
@apswoodwork - depends which type of light you mean. Two very different answers. Option 1: Battery-powered lights (USB-C rechargeable)
Dead easy. Zero wiring. Mount on bar or helmet, charge via USB-C at home, ride. The Lezyne, Knog, and Magicshine options I mentioned all work this way. For your use case - green lanes, grass tracks, occasional grey afternoon - this is almost certainly all you need. There is no wiring. There is no faff. There is just a light.
Option 2: Wired lights powered off the Bosch system More involved, but not impossible. The Bosch Smart System motor has dedicated light output ports built in.
There are individual ports for front and rear light on the Bosch motor. Bosch-compatible lights like the Busch & Müller IQ-XL connect via these - controlled by the Purion 200 display, so the light turns on and off with the bike.
The catch: it does require removing the left crank and housing cover to access the connector.
Not a disaster, but it's workshop territory - torque wrench, crank puller, probably ask your Trek dealer to do it at PDI if you want this option. It's not a "plug it in at home" job.
The Bosch light output requires at least 7.5W nominal power, and must supply power for at least 2 hours after the battery is discharged. Bosch-compatible lights are designed around this - random USB lights are not.
My honest recommendation for you You're not a night-time trail shredder. You're riding grass tracks and gravel in the Peak District. Get a USB-rechargeable bar light (the Lezyne Mega Drive 1800+ I mentioned, ~£90) and a Knog front/rear set for "be seen" duty. Zero wiring, sorted in five minutes, proper brightness.
Save the wired integration faff for when you actually need it - which, based on how you've described your riding, is probably never. So: what's the actual use case? Commuting after dark, or dusk trail rides?
Day trails with occasional evening commuting
Right. Day trails with occasional evening commuting. That actually makes your decision very easy. You don't need wired lights.
Here's why: wired integration is brilliant if you're commuting daily in the dark and want everything to just work when you switch the bike on. For occasional evening commuting, the faff of wiring into the Bosch system - removing the crank, routing cables, asking a dealer to do it at PDI - is completely disproportionate to how often you'll actually use it.
As @Stihldog's post puts it: hardwiring makes sense if you're using lights on a regular basis. Occasional evening rides? That's not regular basis territory. What you actually want:
Bar light: Lezyne Mega Drive 1800+ (~£90). USB-C, 1800 lumens on full, runs about 2 hours at full blast (longer on medium, which is plenty for an evening commute). Clamps on your bar in 30 seconds.
Rear light: Knog Blinder rear (~£20). USB-C, compact, clips on your seatpost. Legally you need one for road use.
Helmet light (optional but genuinely useful): Lezyne Hecto Drive 500XL (~£45). Lightweight, goes where you look. For evening trails this matters more than bar brightness.
Total: ~£110-155. Zero wiring. Charge them when you charge your phone. Done. @Gary's post on commuting light visibility is worth a read - flashing front makes a real difference for being seen in low light, even before it gets properly dark.
https://www.emtbforums.com/threads/25953/ Save the wiring conversation for the day you're commuting three times a week in November. That day, it makes sense. This isn't that day.
Any saddle recommendations?
@apswoodwork - saddles. The question that nobody can answer for you, no matter how confidently they try.
Here's the honest truth: the saddle is one of the most common causes of discomfort on any bike, and the problem is usually not "the wrong saddle" but the wrong width.
Step one: measure your sit bones Before buying anything, do the cardboard test.
Sit on a piece of corrugated cardboard and measure the distance between the centre of the two indentations your sit bones leave. Don't wear bib shorts while doing it - that gives you a false measurement.
A DIY imprint test gets within ±3mm of professional pressure mapping - free and reliable. Once you have that number: add 20-25mm for an MTB riding position.
That's your target saddle width. What to actually buy
For green lanes and trail riding at your level, three brands that come up consistently on the forum: • Ergon SM E-Mountain Core Prime (~£65) -
specifically designed for eMTB trail touring with mixed climb/trail sections. Ergon are the go-to for this style of riding. @PDXRooster rates the Ergon SM E-Mountain Pro (step up from the Core Prime) as the best of many saddles tried - and they've gone through Specialized and SQlab to get there.
SQlab 602 (~£80) - SQlab explicitly add up to 40mm to sit bone measurements in their sizing system; for a typical MTB position they suggest adding 20mm.
Their saddles come in multiple widths and are very well regarded for longer rides. • WTB Volt (~£50) - no-nonsense trail saddle, available in multiple widths, good price.
The one rule Width beats padding. Heavy padding can actually increase soft-tissue pressure - firmness is fine when the width is right.
Don't buy the fluffiest thing on the shelf. Measure first, buy to width. The width must match your sit bone distance - not your gut feeling.
Ask your Trek dealer if they have a saddle-fitting tool when you collect the bike. Many do. Worth five minutes of your time before spending £80 on the wrong one.
    668K
