All bikes using Avinox Motor
What about rumors of the community @Greg Watts as I remember Orbea and Norco is rumored to have avinox but in more gravity oriented bikes like 160-170mm travel? Are there any rumors among other brands?
Right, @bejotto - good memory, and those rumours are worth unpacking properly. On Orbea: the Avinox Wild is very much happening.
A dealer source confirmed the Avinox Wild is landing later this year, with an announcement expected around May and availability of the highest-trim builds from around August.
There's also a rumour circulating of a 180mm frame option, which would put it squarely in your gravity bracket. Nothing confirmed on travel specs yet, but Orbea aren't known for building timid bikes.
On Norco: sorry to disappoint, but the search results tell a different story. Norco is listed as a notable holdout - they have not announced Avinox-powered bikes as of the April 9th launch.
What they did just announce is the Sight VLT Bosch A - a new model featuring an aluminium frame, 150/160mm of travel, and a Bosch PX drive unit, shown at Sea Otter last week. So Norco is investing in eMTB, just not with Avinox. Yet.
For brands actually confirmed in the 160-180mm gravity category with M2/M2S now: the Whyte Karve EVO (180/180mm, M2S) is the standout, the Teewing Flux (180/178mm), Mondraker Zendit (170/165mm), Atherton S.170E (170/170mm), BH iLynx+ DL (170/170mm), and the Olympia Hekton 180 (180/180mm) are all real and in the database. The Forbidden Druid E runs both M2 and M2S across its four tiers, and the top two tiers get the M2S, the lower two the M2.
@Greg Watts
list every single bike uses the Avinox M2S motor combined with the new 700Wh battery and does not use the cable routing through the headset.
Put it in a table that compares them all. Prices are not required.
@Greg Watts
@Greg Watts Can't you answer the question, or don't such bikes exist?
@Rob Rides EMTB Is Greg on vacation, or am I phrasing the question wrong?
Think the bosses turned the bots off as they glitched the forum, can't remember where I saw this.
Anyone else know the answer about which bikes are spec'd with both 700w battery and m2s motor?
@wik — fair frustration, apologies for the delay.
The answer is partly that the combination is narrower than you might expect. The Avinox M2S paired specifically with 700Wh is still an emerging spec — most current M2S production bikes ship with 800Wh as the standard configuration. The 700Wh option is starting to appear in next-generation models but is not yet widespread.
M2S bikes confirmed in my database:
BikeMotorStandard BatteryHeadset Cable Routing
Mondraker SenderAvinox M2S (130Nm / 150Nm boost)800WhNo
Pivot Shuttle AMAvinox M2S800WhNo
Amflow PX CarbonAvinox M2S800WhYes — known criticism
On the headset routing specifically: the Amflow PX routes the motor power cable through the steerer tube, which makes fork removal fiddly. The Mondraker Sender and Pivot Shuttle AM avoid this. For other M2S bikes I do not have headset routing data captured systematically.
If you are asking because you have seen a specific bike advertised with M2S + 700Wh and want to know about routing, name the bike and I will dig into what the community knows about it. The 700Wh + M2S table may have very few entries because that exact pairing is not yet widely in production.
Atherton S.170E - Avinox M2S motor, 700Wh bat., no headset routing !
The new Amflow PX carbon - Avinox M2S motor, 700 Wh Bat.
Atherton S.170E - Avinox M2S motor, 700Wh bat., no headset routing ! The new Amflow PX carbon - Avinox M2S motor, 700 Wh Bat.
@wik - fair cop, and you're right on both counts. My database had the Atherton listed as M1 with 800Wh, which is wrong. Now confirmed:
The Atherton S.170E is M2S + 700Wh, and the cylindrical 700Wh battery was actually a deliberate design choice: Atherton built the frame around the 700Wh cylindrical battery for frame fitment and stiffness reasons.
That distinctive round downtube only works with that specific battery format. Full power spec is 150Nm / 1,500W peak, with 130Nm / 1,300W continuous.
No headset routing confirmed. Prices run from £6,999 (Build 3, RockShox Select/Eagle 90) to £8,999 (Build 1, Fox Factory 38/X2/SRAM X0).
One notable footnote: the first batch of 50 units sold out in under two hours. On the Amflow PX Carbon, confirmed M2S + 700Wh as you said.
The PX integrates 150Nm peak torque and 1,500W peak power, backed by the 700Wh battery with 220Wh/kg energy density.
The headset routing criticism I flagged previously stood for the older PL - I don't have confirmed routing data specific to the PX, so I won't repeat that claim without verification.
So the verified M2S + 700Wh + no headset routing list stands at two confirmed entries: Atherton S.170E and Amflow PX Carbon. I also spotted the Raymon Tarok in that same configuration: like the Amflow and Atherton, the Tarok uses the 700Wh battery.
That's a third M2S + 700Wh bike that wasn't on my radar - worth investigating further if you want to add it to your comparison.
  • Helpful
Reactions: wik
    Join 43,088
