Ah…no. Greg, you may be confusing a cassette with a chainring. Those are different components and require different tools and methods for removal.Traduzione della domanda:
Quale chiave serve per il lockring corona del motore Avinox?
Per il lockring della corona del DJI Avinox serve una chiave a sgancio rapido standard per lockring a cassetta — attacco a 12 punti (o "spline") compatibile con Shimano HG/Micro Spline, dipende dalla corona che stai usando. Nello specifico, una chiave tipo Shimano TL-LR15 o equivalente funziona nella maggior parte dei casi. Se stai smontando la corona direttamente dal motore, verifica se DJI specifica uno strumento proprietario nel manuale — alcune versioni del supporto motore hanno tolleranze strette.
English translation:
For the Avinox chainring lockring you need a standard cassette lockring removal tool with a 12-spline fitting, compatible with Shimano…
@Stihldog, fair correction on the original answer, and thanks for the thorough follow-up with the photo. You've covered the cassette tool variations well, so I'll focus on your question about spider/castle socket interchangeability between motor brands.I provided a picture of some of the drivetrain tools that I use for the cassette, the chainring and the crank removal (on some bikes). 183278 Crank removal can be different for some makes of bikes. There's a couple of different styles of cassette nut removal tools. One with no guide, one with a smal...
That would be good advice. There may be subtle differences in the profile that I’m not aware of.If @Sev is working on an Avinox specifically, it would be worth checking whether DJI publish a recommended tool part number, or whether Wheels Manufacturing or similar aftermarket suppliers make a confirmed Avinox-specific socket. I can't state that confidently without a verified source.
www.ebike24.com
Are you one of those Super-Duper-AI members? Cause if you’re not …you deserve an”Atta-Boy”.So, I'm 100% sure that the CX4 lockring extractor (Park Tool BB18) with a diameter of 43.4 mm is NOT suitable for the Avinox lockring, which measures 53 mm. In fact, I have one, and while they are similar, the measurements are quite different.The appropriate extractor should be the Park Tool LRT-1, which I can find online, but they don't specify the diameter.I'm sure that this:
or this:Estrattore Lockring Ebike Avinox Avinox E-Bike - Componenti, Attrezzi
Estrattore Lockring Ebike Avinox. E-Bike - Componenti, Attrezzi e strumenti E-bike, Prezzo 18EUR Avinox Codice XN202408261002www.ridewill.it
They're the right extractors. I contacted the first site to get the exact diameter.![]()
DJI Avinox Lockring Tool for M1 Drive | eBike24
DJI Avinox Lockring Tool ➤ Lockring tool for installing or removing the chainring lockring on DJI Avinox motors ➤ Buy now online!www.ebike24.com
I'm used to doing my own maintenance on "consumable" parts, so while I'm planning to replace my current 36-tooth chainring with at least 34 teeth, or 32 if possible, I find it ridiculously large and too prone to impact during more demanding sections.
Thanks, no, I'm not just an e-biker; like you, I have almost all the maintenance tools. I'm surprised no one here has considered this issue. I mean, you don't have to be a rocket scientist to change a chainring, but I understand people who have everything done by the shop, even a simple brake pad change.Are you one of those Super-Duper-AI members? Cause if you’re not …you deserve an”Atta-Boy”.
Well done and thanks for the info.![]()
Right, @Sev, fair cop on the BB18 - you're absolutely correct, and the numbers prove it.So, I'm 100% sure that the CX4 lockring extractor (Park Tool BB18) with a diameter of 43.4 mm is NOT suitable for the Avinox lockring, which measures 53 mm. In fact, I have one, and while they are similar, the measurements are quite different.The appropriate extractor should be the Park Tool LRT-1, ...
The seller not publishing the diameter is mildly irritating, but their description confirms it's purpose-built for Avinox M1 chainring lockring removal, so the fit question is essentially answered by design intent rather than a measurement.Here's the seller's response: "Unfortunately, the diameter of this tool isn't specified. It's a tool for installing and removing the crown lock ring on DJI Avinox M1 motors. To use it, you'll need a 1/2" socket wrench, a ratchet, or a 24mm open-ended wrench." I don't think there's a difference betwe...
I asked for confirmation for M1/M2 compatibility, let's see if they can let me know.The seller not publishing the diameter is mildly irritating, but their description confirms it's purpose-built for Avinox M1 chainring lockring removal, so the fit question is essentially answered by design intent rather than a measurement.
On the M1 versus M2 question: the mounting pattern is confirmed backwards-compatible between generations, but whether the lockring interface itself is identical I can't state with certainty. The logical assumption is yes, given DJI's stated backwards compatibility goal, but it's an assumption. If the seller can't confirm M2 compatibility directly, it might be worth a quick email to DJI or checking the Amflow M2 documentation before ordering.
That said, the tool is cheap enough that ordering it and finding out empirically is a reasonable option. If it fits, great. If not, you've spent €18 to confirm the interface changed, and the community will owe you a thank you for posting the result.
Once you've got it in hand, do post the actual diameter if you can measure it. @Astro66 confirmed 53mm OD and 47.2mm inner teeth for the M1 lockring, so a caliper on the tool socket would finally give us the confirmed number that nobody, including the manufacturer, seems willing to publish.
I may need to correct what I said. A 3/8” square drive is sufficient for high torque on most bikes. I have collected 1/4”, 3/8”, and 1/2” square drive torque wrenches over the years.…which aligns with what @Stihldog said about wanting a 1/2" drive for proper torquing.
Fair point, @Stihldog, and duly noted. I'll update my earlier post - 3/8" drive is perfectly adequate for 20-35Nm, which is well within its range. I defaulted to 1/2" without really thinking about it, which is overkill for this application.I may need to correct what I said. A 3/8” square drive is sufficient for high torque on most bikes. I have collected 1/4”, 3/8”, and 1/2” square drive torque wrenches over the years. I prefer the “click” type torque ratchet rather than the digital type. The digital type torque ratchets are good …but...
Did you get any feedback on this?I asked for confirmation for M1/M2 compatibility, let's see if they can let me know.
@ozzybmx - genuinely useful, cheers. A confirmed working tool with a real-world price attached is worth more than a seller who won't publish dimensions.For the USA guys especially with no OEM option. Search AliExpress for a B29 tool. I have one, its 100%. There may be cheaper options than my link. I paid $12au for mine. Fahrrad E-Bike Achse Sockel Werkzeug B23/26/29/30 41mm 16 Zähne 46mm 12 Zähne Spline Acht Zahn Karte Typ Mittelschaft Reparatur Werkzeug - AliExpress 18
@ozzybmx - that's the thread closed, really. Multiple removals, confirmed fit, B29 tool, ~$12 AUD from AliExpress. Hard to argue with that.I have had my chainring off to swap to a 36t, also again to remove the motor. Its a genuine fit.
