Good points overall, and we’re aligned on more than you might think.
On the flexstay — fully agree, and honestly I was curious what you’d say. You landed exactly on 130, which is precisely where we’re at with that. We did try it at 150 but felt it was too close to the Paratu CP’s travel range and frankly not good enough to justify producing. So 130 it is, different rider, different brief. The Paratu CP runs a concentric pivot, proper four-bar, so none of the chatter and brake sensitivity issues you’re describing. Rear travel is adjustable at 145, 150, 160 and 165mm via shock stroke, and we run longer 230 eye-to-eye metric shocks for heat management and durability on a platform that’s working harder. Coil approved too — personally I prefer coil anyway. The weight penalty is a non-argument when you factor in what you get back in feel and longevity on a heavier, harder-hitting bike. You put weight where it makes sense, and low in the rear linkage is exactly that.
Frame-only is actually our default — it’s how we prefer to sell. We’re a smaller operation and we’re not going to pretend we can nail everyone’s spec wishes with a complete build. We don’t want to put together a kit someone pulls apart the day it arrives. We like custom builds ourselves, and our kits are set up for exactly that. Suspension-wise you can run DVO or Öhlins now, RockShox coil coming later.
On battery — noted, cell technology is moving fast and it’s something we’re watching closely
I had missed your meaning on the first sentence — re-reading it now. Alex his test looked to be without the range extender cable installed so he could be sure to get home. The numbers he reached are far from impressive in my opinion and from my own experience, as even though I am a bit lighter I am not much lighter at 85kg.Good points overall, and we’re aligned on more than you might think.
For now I have my experience with the older bike with BikeDrive AIR 40Nm 280W and the 250Wh battery and with this bike I personally can easily beat those numbers. I have it as an enduro setup with Jade X coil, that bike is 18.5kg yet I have frequently done over 1000m and at some days even 1200m and always around 27-32km distance with in the end some battery % left. I do not ride it in mode 3 turbo all the time as it’s nonsense — it has modes, they serve a purpose. On the climbs I use them, on steep downhills I don’t as it’s in mode 1 eco, and if I have an aligned descent I can save battery by just turning the modes to 0 meaning it’s a pedal bike. This is something you learn when you own a bike like this. I know that Alex his bike has a fixed setting and I assume it’s the same as the sample I have been riding with the 360Wh battery, yet with that bike I can also do better numbers than he shows. With the Maxon the key is finding your sweetspot for rider input which I usually have at 200W and I assume his is set at 150W — I will check that with Maxon. Tomorrow I will get our first engine delivery and will immediately rebuild my current bike with the new engine, battery and HMI to see what settings they have as standard.
