I cleaned everything, adjusted motor compensation bolts, put locktite on the threads in the bashguard/mounting plate, then anti-seize on the bolt shafts. It's been silent since.Did you use any carbon assembly on the motor mounts/bash guard atall?
Thanks. I greased my bolts maybe ill try copperI cleaned everything, adjusted motor compensation bolts, put locktite on the threads in the bashguard/mounting plate, then anti-seize on the bolt shafts. It's been silent since.
Have you tried tightening the chainring? That sorted mine out a couple of times on my EXE. For the Slash I had the shop redo the motor bolts and now it's silent. I think the chainring was part of it though as I tightened that up and that stopped some but not all of the creaking on the slash.Ive bought a new one, in the post. Im having real problems trying to eliminate the pedal creak.
Ill have another go at that, I have a new lockring to go with the bash guard.Have you tried tightening the chainring? That sorted mine out a couple of times on my EXE. For the Slash I had the shop redo the motor bolts and now it's silent. I think the chainring was part of it though as I tightened that up and that stopped some but not all of the creaking on the slash.
That sometimes happens on the very first use of the battery whilst the bms is learning the state of charge. Run it all the way down to the point where the bike shuts off, then charge it up to 100% and it should be fine after thatI’ve just bought a 2025 Trek Slash+ with a TQ HPR50 at a very good price. I haven’t charged it yet, and I only did a short ride to understand how the motor works, starting from home with the battery at 40%, which is probably the level it was charged to at the factory before being delivered to the dealer, many months ago.
What I don’t understand is why the remaining battery percentage seems to change from time to time, going from 30% to 40%, then to 50%, and then dropping again. It seems that when I use the motor in Turbo mode it goes down, and when I switch back to Eco it jumps back up to higher values.
Has this happened to anyone else?
Does the battery percentage only change in 10% steps?
Why is it so unstable?
Thank you for your help
Thank you so much!That sometimes happens on the very first use of the battery whilst the bms is learning the state of charge. Run it all the way down to the point where the bike shuts off, then charge it up to 100% and it should be fine after that
'Bottom bracket' noise
After a few hours riding I noticed quite a lot of 'bottom bracket'-like noise under big efforts uphill.
Can't be sure, but I wouldn't say so. I certainly couldn't recreate any noise simply by stomping on my pedals with the brakes on. But there was a consistent noise every crank revolution when I was pushing hard uphill unassisted.Like this?
The shop mechanic reckoned this was the culprit. He said they were considerably below the torque spec. He seems convinced he has solved the problem, and I certainly didn't detect any noise riding it home. Will only get a suggestion in a couple of weeks when I'm pedalling uphill in anger how long-term the fix is.Loose motor bolts
What exactly are you referring to here? When I search the service manual I can't find any reference to 'compensation'. Do you simply mean the connection bolts (M8 x 76.5 mm — 5289570) that go through the frame from the non-drive side, and screw into the chain guard on the drive side?Motor compensation bolts were not setup properly (Suggest you read the TQ manual)
Ah thanks. I was looking at the completely wrong service manual!I assume the HPR60 is the same as the 50, but here:
Page 15.
edit to add, mine were not setup properly and one of them seized, they are made from cheese so are easy to round off.
TQ support said I should warranty it, but the idiots I bought my bike from had a spare one laying around amazingly and replaced it for me.
The "Manual" thing is really a let down to me...I've been riding my Slash+ 9.7 for a month now. A couple points and my thoughts:
-I pulled the trigger on it because of the price. Two of my good riding buddies have light ebikes (a Transition and a Pivot) and i was already in the market for a non ebike in the same price range so it made sense.
-This is my first ebike, so take that for what it is.
Pros:
-Quiet drivetrain/motor
-Slash high-pivot platform and 170mm travel does what it advertises. I can throw this bike into whatever stupid situation i want, and its unfazed.
-Battery life is more than what i typically need, and power is fine for what it does honestly.
---(for example, i ride it 5.7miles up a 2000ft elevation gain paved road and it uses 1/3 of the battery. cuts the ride time more than 1/2 or a full 1/3 as well)
-component spec also does well (so far). Brakes work better than they deserve for the price point, and the suspension is better than what my 2019 Slash 9.8 had going on.
-Good looking
Cons:
-The Gen 6 high-pivot Slash platform is heavy. It also refuses to manual. (which i like to do thru bike park rollers ect.)
-I'm not a huge fan of cadence-based power, but this is a learning curve for a first-time ebike rider.
-Pedal/crank creak came in quick. Thanks to @Emailsucks98 for the pointers, i'll have to give them a try.
-During rough impacts the battery to motor cable in the downtube clanks against the frame. I'm going to put some foam liner situation, but ventilation is important down there so I'll have to be careful.
Takeaway:
I'm happy with the bike, but i personally want something more playful. (non high-pivot basically) It's not a perfect fit for me, but i feel like its worth what its priced and i'm loving it so far.
