sniffy
Had the same problem on my Turbo Levo, fitted 180mm forks, transformed the bike and stopped pedal strikes
No I have never measured the Q factor on any bike, but thanks for giving me the answer as it will save me the bother.
The rest of your post implies that you think I have a problem with pedal strikes, I don't. I was reacting to those that were saying that pedal strikes on an emtb were an issue. It hadn't been a problem for me and I was wondering why it was a problem for others. As always I try to learn and asked a few questions.
Currently, most of my miles are on relatively benign trails in the woods. But I have been all over; Peaks (Beast, Jacobs Ladder), Antur Stiniog, the French Alps to name only a few, and yes I've had the odd pedal strike. But as I said in my post - not enough to want to shorten my crank length.
PS I think you might find your cranks are already quite short at 165mm, they are on my Jam 2 anyway.
it leaves a rider who is overthinking the issue massively and pedailling into things more on one bike than the other
Possibly... just possibly... as he's going quicker towards said objects for less effort.
Maybe he could use that extra energy from decreased effort to concentrate on and read the trail ahead faster?
Different travel/sag/leverage curve/support in suspension also causes different bikes to compress different amounts. but this is irrelevant if we're talikning about a rider with good riding technique who's used to the bike
Steve
I'm sure you already know this, apologies if you have already mentioned it, but the Q factor on your Focus and all Shimano Steps bikes is the same as non e-bikes.
Not mine it isn't.
I finally got around to measuring the Q factor on my Focus Jam2 and my Whyte T30.
Focus 180 mm
Whyte 167 mm
I was surprised as I hadn't noticed any difference.
I had assigned the lack of knee pain down to the "e" in emtb. It never occurred to me that the wider Q factor might have something to do with it. But it's only a quarter of an inch per side, so maybe Q factor is nothing to do with it!![]()
Paragraph from MBR review.
"While all that is very clever, Shimano is claiming a number of benefits for the E8000 over its competitors. The first is that the system has a Q-factor (the distance between the tips of the crank arms) that’s identical to a standard chainset. This means a much more natural feeling pedalling position, something that’s immediately noticeable when setting off."
FFS. Do you own more than one pair of shoes?
And if so do you trip over every kerb/step wearing a pair with a 5mm thicker sole /insole?
The human body is amazing and self calibrated to avoid collision the more physical activity it does. Its the same riding a bike.
Ah.. sorry.
get a fatbike.
Fatbikes all have at least a 100mm BB shells and chainstay clearance for at least a 4" tyre means Q-factor is crazy wide.
put standard 26" wheels on it with 2.2 tyres. thus lowering the BB height by 2"
leave the 175mm cranks (all fatbikes seem to have) on it and fit big wide flat pedals.
Ride it every day for a week. everywhere you'd normally ride.
you won't get pedal strikes anymore.
now the Fatbike has served its purpose kill it with fire!
#NextLevelBollocks
I still get them with 170mm cranks in rocky sections and the shock set to open and while rare I'm thinking the 160mm cranks will help some. Setting the shock at the medium point does help a lot.For sure, when I started E-biking, I got more pedal strikes than before mostly due to as Dax says, I was pedalling through terrain that I either would have ratcheted through or stopped........
Now, with 155 cranks and a more "aware" technique they are a rare occurence.......
Blueskycycling.com here in the US has shorter shimano cranks arms, 160, 165, 170 and 175mm. I didn't know that the FC-8000 was available below 165 and ordered one for my Focus Jam2 C. Only $35.00 USD
I'll keep you posted. It says 160mm and 5 in stock but I just received a response that they are out and had to "re-order", lol. I'm expecting them to say only 165mm is available very soon and I'll just try to get those. Here is the link: Shimano Steps FC-E8000 MTB E-Bike Crank ArmsDo you have a link because when I look the 8000 and 8050 cranks are'nt available in anything less than 165mm and not at the prices you state!
Looking for a set myself.I was beginning to wonder if these even existed but here they are: 160mm FC-E8000 crank arms! Only about $35.00 USD.View attachment 22140
